Bristol Forests Rally 2022
Race Day
Since Parc Expose was the night before, the rally started from the service park at Bristol Motor Speedway:
The first transit out was awesome, a long twisty road the locals apparently refer to as "the snake" which we had to remind ourselves wasn't a stage so we could just cruise and not eat the tires too much.
SS1 was called Copperhead Rd, and apart from being a little bit wet it was just a nice, flowing 4.5 miles of twisty stuff- notes were perfect and we started coming up to pace pretty quickly, although not as quickly as some of our competition and landed 4th in L2wd timewise. Everything felt great though!
SS2 was the rough one of this rally, called Southern Loop Lite, and at over 8 miles of varied surface, nasty bumps, and big rocks it was a tough one to find time on. Cyr (class leader after the first stage) broke down midway through, and while we ran a respectable 3rd place L2wd time McGee jumped out ahead with a fast run through the rough stuff. More than the others, this stage evolved as cars went through it and took different lines, making the notes a little less precise as rocks moved around and big cuts took pieces of the road away.
SS3 was called Holler Puts, and it was a little less rough than the previous one and around half the length with more open terrain- the fastest average speeds of the rally were here, and there were a few proper hairpins in the mix too. Eckstein, who had been running second in class, broke down near the finish while we managed to come through with a L2wd stage win, moving us into second in class behind McGee.
SS4, Countersink, was the longest at nearly 9 miles, smooth, dry, and had a fast tarmac section in the middle which required a big shift in pace from the many tight gravel corners that made up the rest of it. This one felt great, and we managed to make up another 10 seconds here before heading back to service.
Back at service, EvanB, Justin, and Pat checked over the car as we ate some sandwiches, things were determined to be just fine, and before we knew it we were ready to head back out. Adam Brock's Volvocame in on a trailer needing a water pump, and Evan and Justin immediately began dismantling it; Pat and Cam produced a spare water pump from Cam's daily driver 240 and they were hard at work as we left for another loop.
Those 4 stages repeated again, and we ran a fast time on SS5 Copperhead Road with one crucial mistake- I hit a cone. No, this isn't rallycross, but there was a chicane on the stage where the cones were worth 15sec each and I came in too hot and managed to tank the inside cone on the second element. This will be important later.
SS6 was Southern Loop Lite again and we did much better than the previous time, but still couldn't keep up with McGee in the mud and rocks- the skidplates really took some punishment here. If I'm remembering the order of events correctly, on the transit after this one we lent Cessna some tools to tighten his steering wheel since it was falling off.
SS7 Holler Puts went well again- I think this is the one where we passed the aircooled 911, although I could be mistaken. I just remember going "oh my god we passed a 911!" after squeezing by. Another L2wd stage win brought us within 5 seconds of McGee for the class lead, and Brolin was right behind us on times and climbing in the order too.
SS8 Countersink had an interesting delay at the start- Yuvali had managed to spin off the road on the very first corner, so we had to go around his 318ti immediately after launching.
This didn't slow us down much, and we were feeling great until we started to encounter some serious dust, eventually catching James' Fiesta running on a flat- we passed him going into an L2- with plenty of handbrake, I can't wait to see the in car from that one. After we got by we were still running in some serious dust though, the car ahead must not have been far, and on the very last corner before the finish line I overcooked it driving nearly blind and slid off the road onto the berm, luckily with just enough traction left to drag the skidplate back up and get the front wheels in a position to aim us down the road, backing over one of our mudflaps in the process. Despite this nearly disastrous goof up, we managed to pull into the L2wd lead on this stage.
Back at service, the car went up in the air and Evan, Justin, and Pat set about making sure we hadn't hurt anything with our little unplanned parking incident. Everything seemed ok if a little squished here and there, so we headed back out for the final loop of those same stages yet again, transiting behind the 911 and enjoying the view:
On SS9 Copperhead Rd we took great care not to hit any of the pieces of the chicane, and ran ever so slightly than McGee on... what is this, did I forget how to drive? Partway through the stage it became obvious that it had rained on this side of the mountains, and things were getting SLICK.
At the SS10 Southern Loop Lite start we asked the volunteers- did it rain here? We had had clear skies all day but it had apparently dumped rain for nearly half an hour, and the conditions showed it. We survived, nearly slid off the road once, but lost a lot of time to both McGee and Brolin, driving arguably too conservatively, although our rear tires were also getting pretty bald by this point so who knows. McGee moved back into the lead and Brolin bumped up to 3rd right behind us on the road.
SS11 Holler Puts was, by all appearances, nearly dry, and we had time to make up. This one went extremely well, we pushed hard, and we managed to pull back nearly 30 seconds from McGee at the expense of a few more hard skidplate hits.
We didn't have live results for this event, but the ballpark math said we were very, very close behind McGee. SS12 was do or die time, and we knew he'd be trying just as hard not to lose any time to us.
This was the fastest we had run the whole rally, the notes were perfect, the car was perfect other than some nearly cooked rear tires, the road was dry, the dust was minimal- we were flying... and then, a little over a mile from the finish, the stage was cut short. One of the leading Subarus had had a turbo fire and threw the SOS, so although the fire was out by the time we got there we still had to stop, meaning we (and McGee) would get issued the same time for this stage. I was pretty unhappy with this and pretty certain that we had lost our shot at the class win, I just had no idea what the margins would be. To be honest, I would trade our times for the rest of the event just to know how we would have stacked up against the rest of the field with a full run here, the pace felt so good.
The finish was at the Bristol Dragway, so we drove down there, met up with our friends, and traded stories while we anxiously waited for results.
What results? Well, remember that 15sec chicane penalty?
Yep, I managed to cone away a stage rally class win.
That said, it was a great fight all day, and a well earned win by McGee- the cone wasn't the only incident, we had to back up twice to get back on the road, there were plenty of other places (including the scrubbed final stage) to make back that deficit but the cone really put a point on it.
Lots of friends brought home hardware too, with Downey winning 02wd, Gondyke winning NA4wd, and Brolin 3rd in L2wd. Not bad!
So that puts us, thanks to our out of region carryover points from Sno*Drift, in the lead for the Eastern Regional L2wd Championship. What a day!
This was a real chance to push ourselves and the car on the same stages repeatedly, and it felt great on those last couple especially. I'm hoping we can carry what we learned here into future events and go even faster.
