loudandproud
loudandproud New Reader
1/2/20 1:49 p.m.
Sorry for the multipost Picture dump. Bring the thread up to speed here.
I got this truck 10 years ago from my Grandfather when he passed away. I documented me doing a partial restoration on it then.
The truck has been sitting for a couple years, so I decided it was time to dig back in. Go big or go home. Its not a dedicated drag racing truck, but I am going to try to run some times with it.
Truck Specs Currently:
1992 C1500 Work Truck RCLB
350 H.O. Crate
Vortec Heads
Comp Beehives
Threaded Rocker Studs
Valve Guide converted
Scorpion 1.6 Roller Rockers
LS7 Lifters
Comp Pushrods
Comp XR282HR Camshaft
Double Roller Timing Set
Edelbrock RPM AirGap
.015" Head Gasket
.030" Decked Heads
Long Tubes
750 Holley
HEI
Original 5 speed trans with updated Clutch.
275/55/15s
The Plans:
Convert Truck to RCSB
Full 2x4” by 11 guage CNC bent rectangular tubing frame
1-5/8” .083” Chromoly Cage (NHRA 8.5 Sec spec)
Tied cage sections through the firewall and back glass that will stiff the truck up.
Front Suspension;
Wilwood Pro Series Spindles
Fox Body Manual Rack
Wilwood 15” Hat mounted Rotors, 6 piston front brakes
QA1 Coilovers
Splined, Through Chassis anti-roll bar with 5 location to vary stiffness
Adjustable chamber
Adjustable Upper Control Arm mount location (roll center)
Adjustable Toe
Adjustable AntiDive
Rear Suspension:
3 Link Design (doesn’t bind)
Ford 9” Center Section, maybe a winter's 5063 if I come up with the cash.
Grand National (the racing league, not the Buick lol) full floater bearing ends.
QA1 coilovers
PanHard Bar design (**** tons of adjustability in the brackets, perks of being able to just draw it and cut it out)
Same antiroll bar as on the front.
Motor:
Gen 5 Aluminum 5.3
Stock Crank
Howards Billet Rods
Diamond Pistons
Built to spin 7500 rpm
Twin Turbo
ECU:
Leaning towards a MaxxEcu
Transmission:
Its a surprise.
The above is the wish list. Im sure it will change as i go along but that is the idea. I recently started actual work so check it out.
loudandproud
1/2/20 1:50 p.m.
[video=youtube_share;fJF90473l-M]
loudandproud
1/2/20 1:53 p.m.
I got my fixture plate made up for the lower control arms. Looking nice. The 3D printed bits have tabs on the bottom that locate their position in the plasma cut slots. Next week I will be picking up some tubing and will be taking the virgin run on my JD2 bender.
The steering rack is on. It's a quick ratio fox body rack... I plan on running an electric assist column. If it sucks I'll convert to hydraulic later.
Moving along...
https://www.youtube.com/watch?v=Ld_nIAMZnJQ
loudandproud
1/2/20 2:03 p.m.
Last week I got the cross shafts for the lower control arms. I couldnt fit standard bolts in past the steering rack, and I didnt want to pull the rack in order to adjust the lower control arm lengths.
Completed the lower control arm fixturing as well. My 3d printer is going on the fritz. Yay!
I got my tubing bender set up and some 1.25" DOM ready to go.
Lower control arms will be done soon.
https://www.youtube.com/watch?v=uVjocf_lJ3U
RacetruckRon
RacetruckRon HalfDork
1/2/20 2:17 p.m.
Solidworks designed CNC plasma cut frame - Check
3D printed Jigs - Check
Ridiculous truck with LS - Check
I think we have another deranged engineer with a thing for sport trucks.  Welcome to the asylum.
loudandproud
1/2/20 2:31 p.m.
In reply to RacetruckRon :
Happy to be deranged and be here!
I like it better off my meds.
loudandproud
1/2/20 5:59 p.m.
More pic dumps.
I ordered and picked up the steel to start building out my frame table.
The frame table will be made of 2x4 .120w tubing, bolted and shimmed together (in order to remove the chance of warping the main rails).
I started getting the corner braces made.
The are .25" Plate, plasma cut out, then bent into 90° corners with 2" .120w Angle iron mitered in. Just need to get them welded up.
Got 75% of the passenger side LCA built. I have the coil over mounts cut out, but need to get them bent and welded in.
BirgerBuilder
BirgerBuilder Reader
1/2/20 6:20 p.m.
Bill Mesker
Bill Mesker Reader
1/2/20 6:25 p.m.
Welcome to the batE36 M3 berking craziness known as Grassroots Motorsports. Glad to have you along!
nocones
nocones UltraDork
1/2/20 6:41 p.m.
Ooh this is pretty!
Patientzero
Patientzero Reader
1/2/20 7:51 p.m.
This thread makes me happy.  I have kicked around the idea of making my own frame for my '79 C10.  Following.
Patientzero
Patientzero Reader
1/2/20 7:53 p.m.
I saw you are using LS7 lifters in a SBC?  I know the lifter bore is the same but what is keeping the lifters located?  In a LS you use the plastic trays or go to a lifter with the dogbone.
loudandproud
1/2/20 8:22 p.m.
In reply to Patientzero :
Factory Roller Dog bones and Spider Plate.
1SlowVW
1SlowVW Reader
1/3/20 8:51 a.m.
As a fellow gmt400 owner I'll be watching, looks like you have some fab skills!
But why convert to short bed? I love my long truck.
TheV8Kid
TheV8Kid Dork
1/3/20 2:57 p.m.
Welcome! It's been fun following the insanity! Keep up the good work bud!
loudandproud
1/3/20 3:01 p.m.
In reply to 1SlowVW :
Mainly weight and handling. The engine is going to be set back almost 7" from the factory location and main components will be moved to the bed for the sole purpose of moving the weight bias rear ward. Shortening the wheel base is the easiest way to get more rear end weight bias. I'll be slightly shorter than the factory RCBS wheelbase. Ill be at 116.75", factory is 117.5". Tighter bed gap, Front wheels 1/4" back, rear wheels 1/4" forward.
ebonyandivory
ebonyandivory PowerDork
1/3/20 5:33 p.m.
1SlowVW
1SlowVW Reader
1/3/20 6:36 p.m.
In reply to loudandproud :
So call me crazy, why not mount the engine in the front of the bed/under the back of the cab with a  rearward facing dog house.
I'm only asking because I've thought about it. May not be enough room with a trans and a short bed. My fab skills aren't there yet...but looking at your stuff it would seem possible.
Run_Away
Run_Away Dork
1/3/20 6:41 p.m.
Awesome.
How come you're moving the front wheels rearward as well?  I'm used to 4x4 guys moving them forwards for tire clearance with the cab and approach angles.
loudandproud
1/3/20 8:10 p.m.
I looked at multiple options. I was seriously entertaining the Dobbertin Performance corvette setups, but if you do the measurements, it doesnt work in a RCSB well at all.
I did consider a corvette trans, rear, suspension and torque tube setup but decided against it because of where am trying to work to power wise long term.
loudandproud
1/3/20 8:12 p.m.
Run_Away said:
Awesome.
I'm moving the front back 1/4" and the rear forward simply to soak up the shorter wheelbase without looking weird in the fender wells. It will not result in a significant difference.
loudandproud
1/3/20 8:16 p.m.
Tonight I started laying out the cage in CAD. I went out to the truck and started to take some measurements. It's the rough layout only right now. The main purpose was to see where the cage falls in relation to the cab mounts and the outriggers on the chassis.
I'm currently in a holding pattern until my frame rails are delivered.
I ordered then from Boling Bros in CA. They should be here in a week and a half. The rails will be very similar to the rails in their IG post below:
loudandproud
1/3/20 8:30 p.m.
I also 3D printed some balljoint plumb bob holders to get a real exact measurement on the ball joint relationships to each when the crossmember is dead square.
Its tighter than 1/16" total spread. I'll call that good.
Patientzero
Patientzero Reader
1/4/20 12:20 a.m.
What 3d printer are you using?
loudandproud
1/4/20 5:43 a.m.
Prusa mk3s. Mainly PETG filament
HFEFxB62nMkbUvVR70hFd23ZZkTf7CIuYHLUV18qZ7eECm5V16upjZH5lOoq4iO2
