9 10 11
bmw88rider
bmw88rider UberDork
4/9/24 3:04 p.m.
In reply to HaveBlue83 :
Yeah. Those are pretty slick. They have a lot of fun stuff there. I miss my trips to the KL breaker yards and auto salons.
I'm probable going to go with these: https://www.verus-engineering.com/shop/jc6-hood-louver-kit-1884?category=68#attr=89
Just need to measure it out and see if that is a good size for the hood.
HaveBlue83
HaveBlue83 Reader
4/9/24 5:37 p.m.
Front end alignment and wheel balancing to correct some lil issues :)
HaveBlue83
HaveBlue83 Reader
6/30/24 12:59 p.m.
Took it out for C&C. Now home in the new garage
wheelsmithy (Joe-with-an-L)
6/30/24 5:46 p.m.
You are winning at life. Impressive in every way.
HaveBlue83
HaveBlue83 Reader
9/15/24 12:39 p.m.
Buffed the whole car and took it to a car show and c&c.
​wink
former520
former520 HalfDork
9/15/24 6:18 p.m.
Impressive project, great work and looks fantastic!
HaveBlue83
HaveBlue83 Reader
10/1/24 10:48 p.m.
Heard a noise 2 weeks ago, got it home fine and parked it. Its a clanging noise when pushing clutch all the way in.
I got the Talon on the road, swapped cars, and pulled the trans out :). This is trans #7 and its lasted about 3 years now. It now appears toast inside LOL.
The clutch was all new in 2016. It survived a bad clutch fork finger explosion and im happy to report that it didnt trash everything inside on this time either.
Im now in winter build mode, and this car will be going auto and paddles (as long as i dont give up and i do it correctly πŸ˜†)
bmw88rider
bmw88rider UberDork
10/2/24 10:19 a.m.
I guess I should knock on wood or add more power as I've ran my Mirage on the track a ton over the last 2 years and my transmission has looked great.
Just pulled it apart to refresh the LSD plates and was very happy with how it looked inside.
I've thought more than once on Auto and flappy paddles for consistency. What controller setup are you using?
HaveBlue83
HaveBlue83 Reader
10/2/24 12:14 p.m.
In reply to bmw88rider :
Over 300whp level they just dont hold long, and they were all 100-150-200k miles on them. And totally stock. The trans blows before the clutch does lol. My turbo makes a LOT of midrange Tq. Before the redo i dynoed @ 371whp,353wtq. Its just fun and the trans were $125-250 for a long long time.
I will be using a forced four shift box and either evo x or a maxima style paddle setup
HaveBlue83
HaveBlue83 Reader
10/2/24 10:21 p.m.
Ok so.......i have to do waht I normally do.....put things in this car that aint neva been in there before. There is no manual for this feature. Theres no how-to. Imma just do it, somehow.
6 bolt motor, 2g AUTO trans, in a 4g Mirage.
Letuce began:
And i need to use a tq arm to the rear roll stop mount since the 2g is way above the mirage.....
GOOGLE-FU! I actually found one! Old blue drag car was redone to auto awd.
https://www.dsmtuners.com/threads/93-mirage-evo-clone-drag-build.451813/
HaveBlue83
HaveBlue83 Reader
11/14/24 7:13 a.m.
Auto swap didnt go as planned. It wouldnt really fit. Might fit all assembled to the motor but for now i gave up
Car is prepped for winter storage mode, garage isnt heatedyet
bmw88rider
bmw88rider UberDork
11/18/24 9:03 p.m.
Too bad about the transmission not working. I just found a mostly rust free 95 Eagle DL myself. Don't know what the engine plans will be for sure but I do have everything to build a forged 4G93T in the basement so leaning that way. Adding to the Eagle family of cool cars.
HaveBlue83
HaveBlue83 Reader
1/5/25 2:01 p.m.
4g93T isnt bad at all tho! Good market for parts with them and lancers.
The summit has been sleeping, i get heat in the garage final hookup up this week, then i kight be able to try to do some work on it. I have a ton of cleanup to do in the bay and underside.
The trans situation....i decided im going to go get new synchros, visit a buddy with knowledge, and throw synchros in a decent trans and semi retire the car for nice days, c&c, and nice day rips. The auto swap didnt seem to pan out so im not gonna force it and make a monster.
Im still here, just took a break to grt my machine shoo drywalled and heater prep.
HaveBlue83
HaveBlue83 Reader
2/24/25 4:37 p.m.
HAPPY SPRING!
LETTUCE BEGIN CLEANUP
HaveBlue83
HaveBlue83 Reader
2/24/25 6:33 p.m.
Yeah now this is what i waited to do all winter :). Its all surface bubbled rust under the paint that i knew about. Testing into it. I love being back on a car! That was a long a$$ winter!
HaveBlue83
HaveBlue83 Reader
3/11/25 8:24 p.m.
I was able to get a lot cleaned up and primered so it doesnt flash rust. Its doing the pa weather 73 then 40Β° swings so as it gets nicer i will do more!
Ill need new harness zip tie clip in connectors. I found them on amazon so im removing as i need to. Im not trying to gut the entire bay and make it perfect. Its not a show car but i DO want all the rust grime and grease removed. Im not in a rush, the talon and spyder are turn key. Summit deserves a break. Its been going strong for 13 years.
Slowly working around. Theres so much caked on trans and engine oil under the floorpan LOL. 10 years of front main leaking and a few leaky transmissions. Its coming off with a scraper cheeky. I just come out and tinker for an hour or 2 after i foy my RC planes and stuff. Having 2 running DSMs makes it not such a rush.
HaveBlue83
HaveBlue83 Reader
3/19/25 6:52 p.m.
I found some stuff! 0.0
Das rusty lol. I knew about the rear but the front i was unaware! YIKES. Whatever, its a clean up so im doing just that.
I got some pigtails and got sections orlf the harness unplugged so i can access the frame more. Just enjoying my personal day off today :)
9 10 11
FkqNc4B78kNRs19KbpkEcUF4PG6uqkFI4IejSb6hL8ZEeN4QHSosAe2TSbRxaN2l
