8 9 10 11 12
SRPe_Matze
SRPe_Matze Reader
2/2/23 8:01 p.m.
SRPe_Matze
SRPe_Matze Reader
2/5/23 12:41 p.m.
SRPe_Matze
SRPe_Matze Reader
2/5/23 3:25 p.m.
GPS Cover Test. ...... No....
step 2 with Carbon
step 3: Version 3
Positiv Carbon , Negativ PVC and Finisch Positiv GFK .
2/6/23 4:52 p.m.
Totally love this build–very inspiring.
Thank you for sharing.
SRPe_Matze
SRPe_Matze Reader
2/6/23 5:40 p.m.
Thanks.
SRPe_Matze
SRPe_Matze Reader
2/10/23 9:06 p.m.
SRPe_Matze
SRPe_Matze Reader
2/11/23 5:07 p.m.
SRPe_Matze
SRPe_Matze Reader
2/14/23 6:05 p.m.
SRPe_Matze
SRPe_Matze Reader
2/21/23 6:59 p.m.
bumpsteer
bumpsteer New Reader
2/21/23 8:39 p.m.
Thank you for continuing to provide automotive pornography for us with this thread.
SRPe_Matze
SRPe_Matze Reader
2/23/23 7:48 a.m.
Yes
TXratti
TXratti Reader
2/23/23 2:20 p.m.
What tool do you use for trimming carbon parts usually?
SRPe_Matze
SRPe_Matze Reader
2/24/23 4:34 p.m.
I have been working successfully with the Fein swing saw for years.  bi-metal saw blade and Delta grinder 60 or 80 grit for grinding.  the waiting times are long.
SRPe_Matze
SRPe_Matze Reader
2/28/23 3:22 p.m.
SRPe_Matze
SRPe_Matze Reader
3/2/23 3:34 p.m.
SRPe_Matze
SRPe_Matze Reader
3/5/23 4:00 p.m.
for me as small as possible and perfect
Xratti
Xratti Reader
3/6/23 9:32 a.m.
In reply to SRPe_Matze :
Is the GPS antenna cover made of carbon fibre or fibreglass? Carbon blocks radio signals that it would need to connect to the GPS satellites (applicable any antenna cover)
SRPe_Matze
SRPe_Matze Reader
3/6/23 7:42 p.m.
the GPS cover is made of plastic
SRPe_Matze
SRPe_Matze Reader
3/8/23 7:30 p.m.
bigger, more effective
SRPe_Matze
SRPe_Matze Reader
3/10/23 9:00 a.m.
make the negative
SRPe_Matze
SRPe_Matze Reader
3/13/23 6:11 p.m.
negative in the beginning
BigIron
BigIron New Reader
3/13/23 7:37 p.m.
SRPe_Matze said:
Any chance you could pass along the dimensions for the hub mount only on your spindle? I assume you are using the Corvette SKF race hubs.
What is the diameter of the hole the hub fits into?
And, what is the diameter of the hub mounting bolts? Meaning 3xradius as a wheel bolt pattern is described.
I'm designing some spindles for my own build, not a Corvette btw, and would like to use the SKF hubs as I've heard nothing but good things about them.
Awesome build. Look forward to seeing it on track.
SRPe_Matze
SRPe_Matze Reader
3/13/23 7:57 p.m.
BigIron
BigIron New Reader
3/13/23 8:01 p.m.
Thanks! I had looked for that but apparently my google skills are lacking.
SRPe_Matze
SRPe_Matze Reader
3/14/23 6:12 p.m.
8 9 10 11 12
Birthdays
FPAd81BIep0gBAbodlTZ2BN293P7XxmAmpGIIQVElZxeyyA6z3og6FacFOzmIY0M
