SRPe_Matze
SRPe_Matze Reader
7/15/23 10:11 a.m.
Next well-considered step and long-chosen company: Production half driveshaft left/right in very special tough steel with eroded teeth
Grunion
Grunion New Reader
7/15/23 2:00 p.m.
Beautiful work! Please let us see it run?
SRPe_Matze
SRPe_Matze Reader
7/16/23 12:59 p.m.
I can't manage my planned rollout for summer/autumn 2023. there are still too many small and large jobs to be done. Everything moves slowly and the biggest enemy is time. I hope for completion in spring 2024. Videos and photos will continue to provide information.
SRPe_Matze
SRPe_Matze Reader
8/4/23 3:58 p.m.
Air scoop for a double airduct. first simple attempts did not succeed. now CAD and negative mold are used.
SRPe_Matze
SRPe_Matze Reader
8/6/23 3:40 a.m.
SRPe_Matze
SRPe_Matze Reader
8/18/23 1:47 p.m.
first attempts with vacuum processes. Test with 1.5mm / 2mm thick. I need more to test ...... now make it again in nice with 1.5mm.
SRPe_Matze
SRPe_Matze Reader
9/5/23 5:13 p.m.
SRPe_Matze
SRPe_Matze Reader
9/5/23 5:24 p.m.
for Maximum Camber and Caster /  New Upper Control Arm Front and Rear
SRPe_Matze
SRPe_Matze Reader
9/6/23 5:26 p.m.
less high. new attempts are started.
SRPe_Matze
SRPe_Matze Reader
9/22/23 5:21 p.m.
successful 2nd version. Something that doesn't exist worldwide for double airduct / 2x 3 inch
SRPe_Matze
SRPe_Matze Reader
9/22/23 5:32 p.m.
Steering column extended even further to achieve optimal arm bend
You can also get out without removing the steering wheel.
Rollcage in planning
SRPe_Matze
SRPe_Matze Reader
10/8/23 8:40 a.m.
Hose connector quick release mounted 4x for easy removal of the axle.
A problem is always the shock absorber and tie rod, so I changed the shock absorber base. There is also space for the new half drive shaft. Now everything is very close together but doesn't touch.
Pirelli v. Michelin : 305/645-18 and 325/705-18 v. 27/65-18 and 31/71-18
10/8/23 1:36 p.m.
Wow. Just wow. I love this project.
SRPe_Matze
SRPe_Matze Reader
10/8/23 4:51 p.m.
Thank you thank you . I'm sorry that I'm not finished and ready to go yet, but everything takes time, money and important/right decisions. I want to be unique and perfect and later drive worry-free. All my customers and those who want to become customers should be able to look forward to the best quality of their products. My plan was rollout in 2023 after 8 years of construction from the start of building the racing engine. It's not easy, but when I'm done, I'm done. 2024 ?????
SRPe_Matze
SRPe_Matze Reader
10/12/23 9:43 a.m.
ready to go. Now I can have the A-arms made at the top and then nickel plated.
SRPe_Matze
SRPe_Matze Reader
10/15/23 4:08 a.m.
SRPe_Matze
SRPe_Matze Reader
10/15/23 4:41 p.m.
By the way, I built the chassis skates myself. Cheaper and exactly what I need. The centering pin on the skates and 2 holes in the white Teflon to prevent the skates from twisting are still missing.
DrMikeCSI
DrMikeCSI Reader
10/15/23 5:59 p.m.
Beautiful skates.
I guess I didn't realize the car didn't have a roll cage.
SRPe_Matze
SRPe_Matze Reader
10/16/23 6:36 a.m.
So far I haven't been able to decide on an optimal rollcage solution. The market doesn't offer anything suitable for my ideas. Now I'll build it myself. All space in the car is now available. It's a slightly different approach for me, but for me it's better.
SRPe_Matze
SRPe_Matze Reader
10/18/23 6:55 p.m.
finished: nickel-plated and assembled.
SRPe_Matze
SRPe_Matze Reader
10/19/23 5:17 p.m.
The left is also fully assembled
Self-built preheater with 14kw water heater and control/timer with 700W engine oil heater. the racing engine needs to be preheated.
produce larger negatives for new carbon parts with little effort
SRPe_Matze
SRPe_Matze Reader
10/21/23 5:26 p.m.
finished as negatives. The back is laminated.
SRPe_Matze
SRPe_Matze Reader
10/25/23 6:36 p.m.
SRPe_Matze
SRPe_Matze Reader
10/26/23 6:42 p.m.
SRPe_Matze
SRPe_Matze Reader
10/27/23 4:52 p.m.
Birthdays
UgMv1jABEmuob0fROSkcJjmdQAMguFhLBWEz81WBw4JaKwE6RQ9VXB8tB6sa4xUY
