Dusterbd13
Dusterbd13 SuperDork
1/16/15 6:57 p.m.
Ls1 camaro discs. Did it in the elky. berkeleying fantastic brakes.
I have a spare set ..
tuna55
tuna55 UltimaDork
1/16/15 8:33 p.m.
Dusterbd13 wrote: Ls1 camaro discs. Did it in the elky. berkeleying fantastic brakes. I have a spare set ..
Hey quit giving those away!
hehe
curtis73
curtis73 UberDork
1/17/15 12:10 p.m.
Then how did you hang calipers? Or are you talking the whole kit and caboodle?
At Summit today I picked up an SSBC rear disc conversion for the rear. Originally $1000, got it for $300. Also got a Flex a lite fan and shroud kit for $125 (not sure 3300 cfm will be enough for the engine).
Dusterbd13
1/17/15 2:08 p.m.
Turned down the drum hubs, biught flyinbye brackets, used calipers, pads, abutments, and rotors. Bolted together. Somewhere early in the elky thread is specifics.
And tuna, I have a few. ..
curtis73
curtis73 UberDork
1/17/15 3:52 p.m.
So you have some already machined and ready to go? This could get interesting.
dropstep
dropstep Reader
1/17/15 5:56 p.m.
had a really nice driver quality 67 lemans come in too work over the summer. guy was slowly finishing the chassis with just about every bolt on piece anyone made too make one handle. I was shocked too open the hood and actually see a 389 tri power. i love the old multi carb set ups but even i know there not the most practical!
Dusterbd13
1/17/15 6:30 p.m.
No spare brackets or hubs. Though the hubs can be remedied fairly easily.
curtis73
curtis73 UberDork
1/17/15 8:06 p.m.
Ok. I can get brackets and it looks like hubs just need to be massaged to fit the rotors.
I'll bet if I dig hard enough I could find a PDF template for the brackets. Thanks for the heads up on that Dusterbd.
Duke UltimaDork
1/18/15 12:16 p.m.
In reply to dropstep:
389/3x2 is also an older setup than 1967 - that combo was discontinued in 1966. A '67 should have had 400/4b. Funny that he's restomodding the suspension but went backwards for power.
curtis73
curtis73 UberDork
1/19/15 4:53 p.m.
I heard a rumor that there were a couple 400 tripowers that made it to the streets as a dealer option. Dealers who had tripower setups on the shelf sometimes tossed them on 400s in 67 for a price. Any validity to that rumor?
dropstep
dropstep Reader
1/19/15 6:13 p.m.
Duke wrote: In reply to dropstep: 389/3x2 is also an older setup than 1967 - that combo was discontinued in 1966. A '67 should have had 400/4b. Funny that he's restomodding the suspension but went backwards for power.
he purchased it with the driveline already installed. its not even close to numbers matching as it also has the wrong ratio 4 speed and a ford 9" rear. he wanted something he wasn't afraid to log lots of street miles on.
Duke UltimaDork
1/20/15 7:11 p.m.
In reply to curtis73:
None that I ever heard of, but that doesn't mean anything. GM and Mopar of that era are rife with "1 of none" cars that came from the factory, or at least off the showroom floor, with supposedly-unavailable option packages and setups.
oldeskewltoy
oldeskewltoy SuperDork
1/20/15 7:21 p.m.
Totally irrelevant sidebar....
Duke wrote: In reply to curtis73: None that I ever heard of, but that doesn't mean anything. GM and Mopar of that era are rife with "1 of none" cars that came from the factory, or at least off the showroom floor, with supposedly-unavailable option packages and setups.
I know a 1969 hardtop mustang with a 302 Boss, a 3 spd, and a 3.50 final drive!!! And yes it came from the factory that way!!! Met the guy when I was in the Mustang restoration field 20 years back... he was a line employee back in Metuchen, and that is what he wanted...
curtis73
curtis73 UberDork
1/24/15 9:30 p.m.
Update today.
I pulled the carb apart for two reasons. It was leaking at the top gasket so I replaced it. I also suspected that the accelerator pump wasn't pumping, and that assumption turned out to be correct. The carb had been very recently rebuilt and was spotless inside, but the plunger of the accelerator pump was a little stiff so I replaced it.
The radiator had a few pinhole leaks. I was going to pull it and have it brazed, but I thought that it would probably end up with 20 more pinholes in the next year so I bought a good aluminum radiator. Its a 3 core polished piece from Champion and so far I'm ridiculously impressed. The welds look fantastic, the polish is perfect, and the billet neck is a nicely done piece of work.
I'm going to replace a few vacuum hoses that have turned into glass, and replace the valve cover gaskets. I put a few quarts of ATF in the transmission and it shifts fine, but Duke warned me of a pretty sizeable leak at the output shaft. I did find a TH350 to put in, but the guy can't promise its good and he wants too much for it.
Here is a picture of the radiator. Disregard the fan... that won't go in until later.
Duke UltimaDork
1/27/15 1:42 p.m.
Ahhh, the accelerator pump... That makes sense too. I had suspected the vacuum advance.
curtis73
curtis73 UberDork
1/31/15 3:43 p.m.
Vac advance was crapped out too.
Took it around the block today for its first drive with mom and dad!
mbruneaux
mbruneaux New Reader
1/31/15 4:24 p.m.
curtis73 wrote: Vac advance was crapped out too. Took it around the block today for its first drive with mom and dad!
Beautiful
Woody
Woody MegaDork
1/31/15 5:32 p.m.
Everything about this continues to be awesome.
fasted58
fasted58 PowerDork
1/31/15 6:42 p.m.
glad you included your parents
never can spend enough time w/ the folks
curtis73
curtis73 UberDork
1/31/15 7:12 p.m.
I even put the top down for a bit today. Froze my butt off, but it was worth it.
XLR99
XLR99 Reader
1/31/15 7:38 p.m.
That's hardcore! Very cool (literally).
Duke UltimaDork
2/2/15 8:45 a.m.
curtis73 wrote: I even put the top down for a bit today. Froze my butt off, but it was worth it.
Just be careful of that back window in the cold. But yeah, I used to drive around a lot in late February (any time it was above about 50, and sunny) with the top down and the heat cranked. It's actually more enjoyable than, say, August.
curtis73
curtis73 UberDork
2/2/15 4:53 p.m.
I had it in the garage working on some stuff with the shop heat on so it was nice and warm when I put it down.
I have a picture somewhere of me and the ex driving cross-country in my E30 cabrio. We made a pact to drive the whole way with the top down. In Baker CA it was 104, then crossing over Vail CO it was 32. We did it. Somewhere in Illinois we got some rain and I found out that the interior stayed mostly dry above 80 mph.
Dusterbd13
2/2/15 5:34 p.m.
Ill have a spare set of tube upper control arms pretty soon....
curtis73
curtis73 UberDork
2/2/15 8:09 p.m.
Dusterbd13 wrote: Ill have a spare set of tube upper control arms pretty soon....
Want.
mR2hWmNB4J1bFzd6E21Mfwigk509aImg1FlJAsExO67ip312oShcIwsfRx09dKRR
