dannyzabolotny
dannyzabolotny Reader
5/16/22 1:57 p.m.
Hey all,
I figured I'd start a thread to keep track of progress on this 318ti I just picked up... I've owned a bunch of other BMW's, mostly 5's and 7's, so this is me coming back to something that's pretty small and light. In stock form it weighs 800lbs less than my E34 525i/5!
The car is a 8/95 build, with an OBDI M42 engine and a 5-speed. It has a hair under 200k miles at the moment, and is Alpine White with the gray-ish cloth interior. It's a slicktop with pretty much no options and manual seats, which is an excellent starting place for a track build.
I bought it from my friend who had gotten it running and did a bit of work to it, including replacing a bunch of rotten fuel hoses under the intake manifold, the fuel pump, and the AFM. Prior to that, the car had sat abandoned at a shop that did a lot of work to it for the previous owner.
Here's how the car looked when I picked it up— it's on wheels that my friend let me borrow because the factory steelies had such bad tires that they didn't hold air at all.
Looking over the car initially, I noted the following:
- New shocks all around, with KYB's in the rear and Sachs in the front, though the front shock mounts have cracked quite a bit from the car sitting.
- New control arms in the front
- Control arm bushings look to be not great
- Driveshaft has been rebuilt by a good local driveshaft shop
- Trans mounts are collapsed and cracking apart
- Brake pads and rotors appear to be relatively new, though a bit rusty from sitting.
- AC compressor has no belt and no lines going to it, because somebody was previously in the process of removing the AC system... you know, because racecar.
- It has the later M44 electric fan retrofitted in place of the mechanical clutch fan, a nice touch.
- It has a 4.44 LSD, which is absolutely insane and utterly useless on the highway, so I'll definitely be replacing that pretty soon.
Upon the initial test drive, the car started overheating in less than a mile, that's a good sign, right? I pulled over and let it cool off before driving it back to my friend's house where I assessed the cooling system. It never got past 3/4 so I wasn't too worried. I noted that the upper radiator hose felt cool to the touch while everything else was quite hot, so there was probably some blockage in the system.
Scrounging together parts at my friend's house, we found a new-in-box M44 water pump from his last E36 318i, a good used thermostat from a 525i, and some RTV. Along with some basic hand tools, we had enough to fix the car right then and there.
Removing the upper hose from the thermostat housing, I immediately found the problem:
Both the upper hose and the thermostat housing outlet were blocked solid with chunky, crystallized coolant. The coolant was pink because the car had been worked on by a VW shop. It was actually kind of a relief to find something so obviously wrong.
After removing the thermostat housing, I was happy to see that the coolant blockage was only on one outlet, and that the thermostat itself looked fine. I pulled the thermostat out anyways, just to check behind it, and it was just normal clean coolant back there.
The water pump fought me quite a bit coming out, and a piece of it actually broke off because of how crusted up it was... but eventually after some rubber mallet action I was able to get the crusty old water pump out.
Everything went back together without any drama, and I filled the system with distilled water and some cheap blue coolant I bought at Walmart. It'll need a proper flush in the future anyways to get the pink crap out, but I just needed it to work for a bit. The heat worked great in the car, and the cooling system was able to be bled without any issues. The electric fan worked correctly as well, turning on the low and high speeds accordingly. With everything done, the coolant temp gauge now sits at a hair under middle, which is fine by me.
Driving the car 25 miles to my shop, I realized just how awful that 4.44 diff is... the RPM's are insane even at normal cruising speeds (75-80).
Aside from the diff nonsense, the car drove great, with the M42 pulling hard and the transmission shifting super smoothly. It's such a light little car, I can't wait to drive it more once it's sorted. My goal with this car is to have fun at HPDE and eventually move into TT/TA. Previously I was using my E34 525i/5 at HPDE, and even with only 189hp (crank) I was able to keep up with a lot of people in HPDE3 in NASA AZ.
Yes, I plan on keeping the 4 cylinder, before anybody asks. I like the weight balance and I love the way the little 4 banger sounds when you push it.
dannyzabolotny
5/16/22 2:00 p.m.
While poking around the car, I noticed the parking brake did absolutely nothing, which makes sense since neither of the cables were hooked up. I tried hooking up the cables but found them to be too short, eventually figuring out that they are E36 non-TI parking brake cables, which wouldn't work. I've got the correct cables on order, they should be here later this week.
In the meantime, I threw my Apex wheels on the TI, since I had to give back the style 9's I was borrowing from my friend. It actually looks great on the Apex ARC-8's, which makes sense considering they're E36 spec wheels that I've been using on an E34.
The car definitely needs to be lowered, but it already looks a lot more aggressive with just the wheels.
Last week I was able to find a 3.64 open diff locally in the correct small-case E30 size. While it sucks that it's an open diff, 3.64 will be a much more practical ratio; plus I can always combine it with my 4.44 LSD to make a 3.64 LSD in the future.
Old 4.44 diff:
Very easy diff removal.
I did have to swap the output flanges to fit the axles, but that was super easy to do since they just snap in. With the flanges swapped, the diff bolted up super happily.
While underneath the car, I also found the source of my exhaust leak, which I'll have to get welded up at some point.
The trans mounts weren't look great, so they got swapped out.
Before:
During:
After:
Taking the TI on a road test, I immediately noticed how much more usable all of the gears were. It felt a lot more natural to have a 3.64, as it makes the gear spacing feel a lot closer to my E34 (which has a 3.23). The main benefit, however, is the much improved highway RPM:
4k at 80mph isn't ideal, but compared to the 5k I was cruising at before, it's a huge improvement. The replacement diff is nice and quiet as well.
Next up will be installing the new parking brake cables, shoes, and hardware. After that, I'll finally be able to reinstall the interior and give it all a good cleaning.
trigun7469
trigun7469 UltraDork
5/16/22 2:09 p.m.
Body looks clean
buzzboy
buzzboy SuperDork
5/17/22 3:58 p.m.
I bought my M3Ti with 3.73LSD and hated it. I found a 325es for it's beautiful 2.93LSD and swapped that. 3kish at 80mph is lovely, althought I've got 240ft*lbs which helps. Was the 4.44 swapped in? Or was this a factory auto?
And I must say how much better TIs look without the heckspoiler. I pulled mine off and think it's so much sexier
dyintorace
dyintorace PowerDork
5/17/22 4:51 p.m.
Great start. Hilarious to see 8-series wheels on it in the first picture! laugh
dannyzabolotny
5/17/22 11:38 p.m.
trigun7469 said:
Body looks clean
It is! Zero rust, just kinda bad paint. It's white which means I can ignore the bad paint for a while, plus I can find other stuff like side skirts and bumpers in white without too much difficulty.
dannyzabolotny
5/17/22 11:39 p.m.
The 4.44 was swapped in, as the car is a factory manual based on the VIN. The stock ratio would have been 3.45 so 3.64 is close enough. I intend to keep the 4 cylinder so the slightly shorter gearing is fine by me.
dannyzabolotny
5/17/22 11:40 p.m.
I know, right? The most flagship wheels on the basest car in the lineup!
dannyzabolotny
5/18/22 12:48 a.m.
The parking brake cables finally arrived today... they were special order Genuine BMW parts, at like $54 each. A bit pricey, but I wanted working parking brake cables and didn't feel like waiting for a 318ti to come up in the yards.
Removing the existing parking brake cables and putting them next to the new ones, it was clear that the old cables were far too short. Here's the comparison between E36 parking brake cables and 318ti parking brake cables:
Installing them went pretty easily, the joys of working on rust-free southwest cars!
After adjusting the parking brakes at each wheel and then at the handle, I was rewarded with a tight, immensely satisfying parking brake that locks the rear wheels in 3 clicks. I love it when a plan comes together.
I know it's silly to get so excited about a working parking brake, but I have pretty high standards for all my cars and require every single thing to work before I do any fun/performance mods.
BlueInGreen - Jon
BlueInGreen - Jon UltraDork
5/18/22 8:52 a.m.
Slick top 318ti! You have excellent taste in old BMWs.
I like the 4 cylinder too
dannyzabolotny
6/17/22 2:09 a.m.
Picking up where I left off, I got around to cleaning the trash out of the interior and reinstalling the center console. Of course, all of the hardware was missing, so I had to deploy my bin of spare screws and bolts to put everything back together correctly. This is why I keep all the hardware from every car I part out!
Now I've got window switches and storage cubbies and semi-usable cupholders, what a luxury!
Earlier today I passed 200k miles. Not a huge accomplishment since I bought the car with 199k, but still a fun milestone.
After that I got to fixing the AC, as the triple-digit temperatures in the Phoenix summer make it a necessity for survival.
Out came the crusty old compressor, condenser, receiver drier, and all of the lines. Somebody had previously started removing the AC components (because racecar) so the entire system was open to the atmosphere for the better part of 10 years. Thankfully there was no corrosion due to the dry climate, so after cleaning each of the lines and blowing them out with compressed air, they were ready to be reused (with new o-rings). The compressor, receiver drier, and condenser were all replaced with new ones.
Along with all of that, I also installed a new AC belt tensioner and belt.
The system was then put under vacuum for most of an hour, to draw all the moisture out. After that, it was left alone for 30 minutes to test for leaks. I used new o-rings on every single connection, so it kept perfect vacuum the entire time. With that, I charged the system, and got the vents to blow around 40ºF in ambient temps of 90ºF or so in the shop. Driving around, it stays around 40º, even while sitting at lights on a 112º day.
Good car! Next up, have to get it emissions tested and registered. And then do something about this awful old tint, it's so bad that I can't see out the back window, it's nearly opaque.
iansane
iansane Dork
6/17/22 10:47 a.m.
Nice little ride!
I have a small case 4.10 lsd I'd sell ya for cheap. But it sounds like it's higher than you'd like to go.
dannyzabolotny
6/17/22 11:37 a.m.
iansane said:
Nice little ride!
Yeah, I've got a 4.44 LSD that I took out, 4.10 isn't a huge improvement. I'm alright with the 3.64 that's in there now, ideally I'd love to find the stock 3.45 LSD so I can get as much highway fuel economy as possible.
Justjim75
Justjim75 SuperDork
6/19/22 12:40 a.m.
I'd love a 4.10 lsd, but I doubt it fits my 01
dannyzabolotny
6/19/22 3:44 a.m.
With the AC working nicely, I put about 200 miles on the 318ti the other day just to see how it would do, and for the most part it did great! I also found that the M42 revs to about 6800 before hitting a limiter, neat.
Upon parking the car at my shop for a few hours I discovered some puddles underneath the diff and transmission. Looking underneath the car, I discovered the diff was leaking pretty badly:
In about 15 minutes I had the diff out, and found the side seals to be completely destroyed, probably from me shoving output flanges into a diff that had been sitting for 10 years. Easy fix though.
With the side seals replaced, I took it as an opportunity to easily service the fluid, so I drained out the minuscule amount of fluid that was still in the diff and replaced it with some Liqui-Moly 75W90 that I had laying around at the shop.
Moving onto the transmission, I found a similar mess:
With the diff out, it was trivial to just unbolt the driveshaft and move it out of the way so I could access the leaky output seal and leaky selector rod seal.
New seals went in without much drama, and I cleaned things up a bit.
Of course I couldn't resist replacing all the shifter bushings while I was there, so it got those too. All the bits were pretty inexpensive and readily available so why not?
Everything went back together nicely, and I was left with a diff and transmission that didn't leak anything. The transmission also got its fluid changed out, since it was low from leaking it out. It was about 3 hours of work for all of this stuff, not too bad.
jfryjfry
jfryjfry SuperDork
6/19/22 6:28 a.m.
You breezed through the seecfor shaft seal replacement but that took me a lot of time and a lot of hair-pulling to get that seal out on mine.
did you replace the shifter itself?   The ball on the end is integral and wears as well so doing EVERYthing is a bit of cash.
jr02518
jr02518 HalfDork
6/19/22 9:51 a.m.
What fluid are you using in the gear box?
dannyzabolotny
6/19/22 11:21 a.m.
The selector rod seal is easy once you've done em a few dozen times, you just remove the selector rod + selector rod joint and then use a thin screwdriver to gently pry it out.
Fair point, I did not replace the shifter and there is indeed still some play on the shifter ball itself. I still need to figure out what I want to do in terms of getting a short shifter. I also couldn't buy a shifter on such short notice, I literally ordered the parts from SSF the minute I started pulling things apart, and they showed up when I was about an hour into the job.
dannyzabolotny
6/19/22 11:22 a.m.
Some cheap ATF from Walmart, because it's what I had. Will likely switch it to Redline D4 in the future, but this works for now.
collinskl1
collinskl1 Reader
6/21/22 9:01 a.m.
I can vouch for Redline D4. I have just over 40 hours of track only runtime on it in my ti racecar, and it still looks, feels, smells brand new. Haven't run a taste test though...
Their 75W90 in my differential is similar, but I do have a bit of clutch plate material floating around after the same time interval. It was clean at 25 hours though.
I run Mobil 1 Euro spec 0W40 in the engine and haven't had any issues with it, changed every 15ish hours.
dannyzabolotny
6/21/22 12:38 p.m.
Redline D4 was great in my last 525i's ZF, but in my current 525i ZF, it seems to prefer MT90 for whatever reason.
No limited-slip in this diff unfortunately, which also means no clutch particles, haha.
dannyzabolotny
6/21/22 12:38 p.m.
Of course my throwout bearing exploded the day after I had put everything back together. Such is life!
So it all came apart again. Everything went pretty easy actually, so I wasn't too bothered. As soon as I pulled the transmission, it was incredibly obvious that the throwout bearing had absolutely nuked itself. No wonder it was making awful noises and the clutch pedal felt terrible.
The clutch disk and pressure plate looked fine, but since I was there, I figured I would replace everything anyways. I'm glad I did, because the dual mass flywheel was completely shot, like I could rotate it like 20º in either direction quite freely.
The rear main seal was leaking a bit too.
It got a new rear main seal, new flange gasket, and a new pilot bearing.
The transmission itself (a Getrag 220) was pretty gross, so it got a good cleaning.
The cleaned-up bellhousing got a new clutch pivot pin, clutch fork clip, and a new Sachs throwout bearing.
I had a good used Valeo single-mass flywheel + clutch kit from an M50 car at the shop, so I installed that. From everything I've read, it all bolts up and works correctly with the stock 318ti slave cylinder + throwout bearing.
With everything back together, the 318ti drives amazingly well. The single-mass M50 kit works perfectly, with a nice clutch feel, minimal chatter, and smooth operation. Downshifts are so much easier now that everything is actually functioning as intended.
In the midst of doing the clutch job, I also acquired some new wheels for the car— a set of style 68's from an E46. They came with good tires and were a pretty good deal for 6 wheels (4 fronts, 2 rears), so it was a no-brainer. Now I can continue using the Apexes as dedicated track wheels while having a simple set of OEM wheels for daily driving.
collinskl1
collinskl1 Reader
6/22/22 1:06 p.m.
I know you're working off a lift, but how hateful do you think a trans pull would be from jack stands?
I haven't had mine out, but know there is some throw out bearing noise, and I'd like to get eyes on the clutch as well.
dannyzabolotny
6/22/22 1:32 p.m.
It wouldn't be too bad, I've certainly done my fair share of transmission removals on jack stands. As long as you have a jack to support the transmission, the physical removal should be relatively straightforward. The only pain there is accessing all the bellhousing bolts, but tilting the engine/trans down and using a very long extension makes it easy enough.
paul_s0
paul_s0 Reader
6/22/22 5:27 p.m.
By accident I stumbled upon your 2 E34 threads on other forums as I was trying to research a bit (researching how bad an idea it would be to daily an E34) and thought the name seemed familiar.  Nice to see a TI getting some love, I had an early M42 powered ti a while ago, I never really gelled with it though, I enjoyed the E36 325TDS more for some reason.
QBRQ4vwRVikTm8UfOB0ysOt1oqjUHoctVEBeb6Yz4LNuYTgrOCJdLsW6KcnCUEjQ
