Big. Weekend.
Ian came into town this weekend to help get more hours under the f-dat belt. So big update here, I'll try to keep the words to a minimum.
1st I spent about 2 hours making a chain guard. Start with 2x2 square tube.
Cut out a C shaped section.
Cut triangles (accidentally make them too large - a bit more foresight here would've been slightly better).
Make a front bracket.
Weld the triangles that were cut out back in, after having bent the piece the right amount.
Drill and tap a hold for the back, weld the front to the tab, boom, done. Note that I may need to slot the rear hole a bit if the chain stretches and I need to re-tension it. Oh well.
Next we got on to adding the rear wing and muffler support. This is a super nice piece that came from the AMC spirit build and from behind a drag racer's shed before that. It is almost freaky how well it fits the F-DAT. Held it up in the right position with carefully placed bungies:
Then made the bottom attachment points.
Next, mount the muffler to it. The below are BACK SEAT BRACKETS FROM THE SAAB UTE CHALLENGE CAR. Ian told me this is the kind of good luck you have when you are a packrat extraordinaire. I told him not to encourage me. The rubber isolators from various CBR brackets fit the bill perfectly in the large holes at the top of the saab brackets.
Cutty cutty, drilly drilly, rivnutty rivnutty, better to be lucky than good is what my mom always says. Also, the angle of the exhaust means that hot and high energy exhaust gasses will be getting blown directly on the bottom of the wing. Excellent!
While I was working on the wing and exhaust mounts. Ian was busy with stuff like mounting the windshield, making a bracket that prevents chafing on the radiator hose, wiring the clutch switch, and doing a nut and bolt job on the entire car.
I handed him a sharpie and asked him to mark every fastener with it's size. This is a racecar after all, and any time we can save on serviceability is good time in my mind.
Ian even was kind enough to spent time to get those brake hoses perfectly zip tied back.
With that, we bolted on the wheels and rolled it outside for it's maiden (sans body) voyage. Nose cone was quickly added for reasons that will soon become apparent.
I drove once around the block, and then Ian took a turn. We didn't wind it out as I happen to like that my neighbors don't ask any questions about what I do in my shop. Here are some things we learned from the first outing:
- Parking lot turning (radius and solid rear axle) are not a strength
- The shifter wasn't tightened appropriately - Ian asked me to do it like 4 times while doing the nut and bolting and I never did it
- It sounds awesome!
- Brakes work
- Launching from a standstill is very easy in 1st, easy in 2nd, and quite possible in 3rd. Really not an issue. Throttle pedal works brilliantly. Clutch lever just like the bike. Ian has never even ridden a motorcycle and had no issues.
- The sprocket can shift a little bit on the axle - eeeeeesh
- Cannot. wipe. smile. from. my. face.
Between Ian and I we added about 25 hours of work on Saturday. But we had a running and driving car. 391 hours!
