4 5 6 7 8
EricM
EricM UltraDork
7/7/24 2:29 p.m.
Crenshaw said:
You've probably figured this out by now, but those axle bolts (and a bunch of other random hardware on a 944) are "triple square" or "cheesehead", not torx, and are obviously very easily stripped, especially if someone tries to remove them using a torx socket....
Well, that explains a lot, lol, thanks, I didn't know that.
Looks like I'm tool shopping, again.
EricM
EricM UltraDork
7/8/24 3:09 p.m.
EricM
EricM UltraDork
7/8/24 3:44 p.m.
3D printed speaker grill, made out of ABS for a test fit.  If the sizing is correct then we will emboss "DRAGON" on it and print it in vinyl or some other material that will withstand the heat of the car sitting in the sun.  And obviously paint it black.
EricM
EricM UltraDork
7/8/24 3:46 p.m.
Probably get this one set up and going and print it with this.
EricM
EricM UltraDork
7/8/24 10:48 p.m.
fit is perfect, now to print in rugged material.
EricM
EricM UltraDork
7/11/24 8:57 p.m.
I've broken an 11mm wrench, stripped a 19mm caliper bolt, and can't get the rear brake pads out.  I'm pausing for tonight
7/12/24 11:00 a.m.
Does not look like a red door to me.
GoLucky
GoLucky Reader
7/12/24 3:24 p.m.
In reply to EricM :
Can you print a dragon silhouette into your speaker grilles?
EricM
EricM UltraDork
7/12/24 11:10 p.m.
GoLucky said:
In reply to EricM :
The plan is the word dragon, but I'll see if I can get an actual dragon on there. Maybe use the circuit to make a dragon stencil
EricM
EricM UltraDork
7/20/24 11:27 p.m.
The only thing left attached to the underside of the car is the gastank.
EricM
EricM UltraDork
7/20/24 11:31 p.m.
Jegs put our motor on backorder so we canceled there and went with Summit. "Should" ship as early as Monday.  Chevy says if we show them a paid invoice they will send us a $350 rebate. That's enough to pay for the starter. The ECU and sensors we already got from Jegs will all still work, obviously.
Also ordered Caribou seats and sliders in the same order.
EricM
EricM UltraDork
7/20/24 11:33 p.m.
The shocks are dead.
EricM
EricM UltraDork
7/25/24 1:09 p.m.
So, this was left in the driveway
and it revealed to be this:
Recon1342
Recon1342 UltraDork
7/25/24 4:38 p.m.
In reply to EricM :
Aluminum block?
EricM
EricM UltraDork
7/25/24 5:15 p.m.
Recon1342 said:
In reply to EricM :
Aluminum block?
LS376/525. Aluminum block Aluminum head Ls3 with a hot cam straight from GM performance parts.
EricM
EricM UltraDork
7/25/24 5:50 p.m.
golfduke
golfduke Dork
7/26/24 7:49 a.m.
Jeez you guys are NOT messing around~!  I love it.
EricM
EricM UltraDork
7/28/24 6:40 p.m.
Partially unwrapped seats.
EricM
EricM UltraDork
7/28/24 9:12 p.m.
All the pieces
EricM
EricM UltraDork
7/31/24 5:46 p.m.
The License plates came today :-)
RandolphCarter
RandolphCarter Reader
8/1/24 12:00 p.m.
I'm embarrassed to admit it took me several weeks to get the joke.
EricM
EricM UltraDork
8/3/24 4:55 p.m.
Cleaning, sanding, decreasing
EricM
EricM UltraDork
8/28/24 4:49 a.m.
docwyte
docwyte UltimaDork
8/28/24 9:43 a.m.
Why'd you go with shorty headers?  Kooks makes long tube headers for this specific swap and they're the bomb.
EricM
EricM UltraDork
8/28/24 10:32 a.m.
We plan on a 3 inch single pipe and these allow for that.
4 5 6 7 8
zY4YyI7vzFunfeDBztKs4aMR2ORRRQC8eb4IuRAO8SBqBHXtYQHDUW9DtfbsDiVe
