Mr_Clutch42
Mr_Clutch42 Reader
5/6/14 1:38 p.m.
I've read several build and project threads and I am finally able to do my own (and not too lazy to upload photos).
<img src=" photo DSCN3757_zpsa27b0669.jpg" />
Mr_Clutch42
Mr_Clutch42 Reader
5/6/14 1:44 p.m.
I ordered quite a few parts that need to be replaced. They haven't arrived at my house yet.
<img src=" photo DSCN3758_zps7226dcf2.jpg" />
I haven't ordered new tires yet.
Yup, it's on jack stands and has been sitting for a few months.
<img src=" photo DSCN3761_zps63be56ae.jpg" />
Mr_Clutch42
Mr_Clutch42 Reader
5/6/14 1:49 p.m.
Something's missing in the engine bay...
<img src=" photo DSCN3759_zpse6bd88f2.jpg" />
There it is, the old radiator. The car has about 140,000 miles and I believe that this is the original radiator.
Matt B
Matt B SuperDork
5/6/14 1:50 p.m.
Wow, that thing must have been sitting for awhile to accumulate rotor rust on such an epic scale.
Mr_Clutch42
Mr_Clutch42 Reader
5/6/14 1:52 p.m.
Yeah, I live in North Carolina, and we get good rainfall here in the winter and spring.
Giant Purple Snorklewacker
5/6/14 1:57 p.m.
You are not in over your head... taint nuthin' to all that.
Good luck. Post up pics and ping if you need help sorting anything.
Mr_Clutch42
Mr_Clutch42 Reader
5/6/14 2:16 p.m.
I don't make much money at all (hence the title), and this is just the beginning...
MadScientistMatt
MadScientistMatt UltraDork
5/6/14 2:19 p.m.
Mr_Clutch42 wrote: There it is, the old radiator. The car has about 140,000 miles and I believe that this is the original radiator.
And it actually has both the inlet and outlet still attached?
(Mine lasted until 160,000 miles before one of those popped off.)
wbjones
wbjones UltimaDork
5/6/14 3:24 p.m.
Mr_Clutch42 wrote: Yeah, I live in North Carolina, and we get good rainfall here in the winter and spring.
where you in NC … I live in the western end of the state
Mr_Clutch42
Mr_Clutch42 Reader
5/6/14 3:33 p.m.
I live in Eastern NC.
dj06482
dj06482 Dork
5/6/14 3:36 p.m.
https://grassrootsmotorsports.com/forum/grm/e36-cooling-system-overhaul-notes/13016/page1/
Mr_Clutch42
Mr_Clutch42 Reader
5/7/14 2:54 p.m.
I had to pop the tie rod ends with PB blaster to pop them off the knuckle (I think that's what it's called).
New parts! They came in a day earlier than I expected. It feels a little like Christmas.
Mr_Clutch42
Mr_Clutch42 Reader
5/7/14 3:23 p.m.
The check engine light said that one was faulty, so I'm just gonna replace both of them.
I like the foam padding they use. But, I should have got a picture of it without the plastic on it.
Mr_Clutch42
Mr_Clutch42 Reader
5/7/14 3:26 p.m.
I needed a new steering rack too. I used an aftermarket one from Advance Auto Parts but it was faulty out of the box. The Bimmerfest forums recommended The Rack Doctor.
Mr_Clutch42
Mr_Clutch42 Reader
5/7/14 3:30 p.m.
It's set in place for now.
Mr_Clutch42
Mr_Clutch42 Reader
5/7/14 3:36 p.m.
Here is another shot of the beautiful craftsmanship they provide. I also need to buy more coolant, distilled water, water wetter, and a hose for the coolant overflow tank. I forgot about some of the supporting items/purchases I need.
Mr_Clutch42
Mr_Clutch42 Reader
5/8/14 6:18 p.m.
Basic cooling system items. I actually needed to use a slightly larger coolant line due to the Mishimoto inlet. It took much longer than I thought just to get that small line through the fan shroud.
I took out the faulty steering rack. I still have the receipt so I will get a replacement and sell it on craigslist.
Mr_Clutch42
Mr_Clutch42 Reader
5/8/14 6:23 p.m.
The coolant system is all buttoned up (except for that one screw) and mostly filled . I hope that reservoir line unkinks when I bleed the system. Damn universal lines.
Mr_Clutch42
Mr_Clutch42 Reader
5/10/14 11:20 a.m.
I installed the new rack yesterday. It was a pain in the you know what due to the design. I ordered new tie rod ends since I ripped the old ones while taking them off. I also installed a new power steering reservoir since the filter inside is non serviceable.
Mr_Clutch42
Mr_Clutch42 Reader
5/14/14 2:24 p.m.
Now I need some help. The exhaust manifold nut was seized, even when I used PB blaster and an impact gun. I tried to cut the stud off but I didn't have the clearance to cut off the stud in half the other direction.
Mr_Clutch42
Mr_Clutch42 Reader
5/14/14 2:32 p.m.
I cut the exhaust maybe 2/3 of the way through but it is thick. I used a 4" angle grinder and a 7" angle grinder is cutting in the other pipe more than cutting the rest of the one side off. I have a reciprocating saw and that doesn't seem to have the cutting power for this. Should I try to borrow a plasma cutter or an oxy-acetylene torch?
M3Loco
M3Loco Reader
5/14/14 2:34 p.m.
DRILL IT! That's how I removed a broken lug.
Good Job!
Tom_Spangler
Tom_Spangler Dork
5/14/14 2:37 p.m.
Mr_Clutch42 wrote:  photo DSCN3783_zpsd6ceeee2.jpg
Take this with the appropriate grain of salt, but I've always heard that the M5x motors should only get genuine BMW coolant. That's what I used in my E36 M3. Maybe others will chime in.
Mr_Clutch42
Mr_Clutch42 Reader
5/14/14 2:57 p.m.
I tried to drill a broken stud and it didn't work. I only did it once. I would need to buy or borrow a drill too.
Beagle
Beagle Reader
5/15/14 9:25 a.m.
Sawzall should cover that - try new metal blades. Milwaukee or DeWalt sell decent blades, if your sawzall won't pull the blades you have, try a higher teeth per inch count (like 24) and use something like wd40 to keep them from overheating. Oh... goes without saying, but good goggles!
edit - looking at the top picture with the stud, that looks like a good place for the grinder, go at it parallel to the flange from the bottom?
NomeLLwZKtEhKoDNtejQaZpAzVKunPoRU8qCDD4wcPHGJ1HWYfq5FRrRuY3WQURu
