Due to the layout of my garage, I had to think very hard about how to best do an engine swap. Normally I just pull the car straight in, but the area where the front of the car would be is a mess of intact tiles, broken tiles, concrete, fake wood floors, and the hydraulic line for the lift. Not exactly the ideal place to be messing around with an engine on a hoist. That meant I had to back the car in, which didn't leave much flat space in front of the car due to the driveway sloping away from the house. I definitely didn't want my engine to roll down the driveway on the hoist either! With that now clear, it should hopefully make a little more sense why I chose to pull off the whole front end of the car, minus the condenser.
Last shot of the old motor intact in the car:
![](http://i72.photobucket.com/albums/i161/95maxrider/BMW M3/2017/Motor swap/Removing the motor/IMG_8322_zpsit2z9lkx.jpg)
Most of the front came off pretty easily:
![](http://i72.photobucket.com/albums/i161/95maxrider/BMW M3/2017/Motor swap/Removing the motor/IMG_8364_zpspdkxmuxz.jpg)
Thankfully Josh came over to help with the extraction, and I'm so thankful he did, because manuevering around the steering shaft was quite a pain. We had to use a ratchet strap to pull the motor towards the PS to get it to clear:
![](http://i72.photobucket.com/albums/i161/95maxrider/BMW M3/2017/Motor swap/Removing the motor/IMG_8401_zpsuunkfrn1.jpg)
But it finally came out. Success!
![](http://i72.photobucket.com/albums/i161/95maxrider/BMW M3/2017/Motor swap/Removing the motor/IMG_8403_zpskdvfki7q.jpg)
Ok, now the real work begins....
![](http://i72.photobucket.com/albums/i161/95maxrider/BMW M3/2017/Motor swap/Removing the motor/IMG_8404_zpstazgzylf.jpg)
One of the first things I did was separate the trans from the motor. I was greeted by what appeared to be a nearly worn out clutch disc...
![](http://i72.photobucket.com/albums/i161/95maxrider/BMW M3/2017/Motor swap/Clutch and flywheel/IMG_8429_zpsijyfpscb.jpg)
![](http://i72.photobucket.com/albums/i161/95maxrider/BMW M3/2017/Motor swap/Clutch and flywheel/IMG_8428_zpsf4mgzbrb.jpg)
And a mystery flywheel that needs to be resurfaced:
![](http://i72.photobucket.com/albums/i161/95maxrider/BMW M3/2017/Motor swap/Clutch and flywheel/IMG_8433_zpseywjdte7.jpg)
![](http://i72.photobucket.com/albums/i161/95maxrider/BMW M3/2017/Motor swap/Clutch and flywheel/IMG_8431_zpstdxemoki.jpg)
The pressure plate also looked a little tired...
![](http://i72.photobucket.com/albums/i161/95maxrider/BMW M3/2017/Motor swap/Clutch and flywheel/IMG_8422_zps94fkfs7p.jpg)
Since this was an unexpected surprise, and I'm still reeling from buying a used motor, I've been scrambling to figure out the cheapest, but still reliable way to get this thing buttoned up. At this point, I'm pretty sure that I have an Ebay/GripForce Stage 2 kit in the car, and after all I've read, I'm thinking about getting the same setup, just new. They're cheap as hell and seem to get good enough reviews, at least in the E36 application. I considered the E34 M5 clutch route, but could never be sure it would work with my flywheel. I considered the UUC setup for about five minutes before I started reading reviews. The stuff on BW is all out of my budget.
As of right now, I still haven't even ordered all my other parts, because I keep finding more things I want to "do while I'm in there". Famous last words. Because if I keep going like I'm inclined to, I'll never come out. I was this close to ordering new rod bearings until I read more about doing them properly, and I just don't think I'm up for it. I will probably be installing a baffled oil pan since my pan gasket is leaking real bad on the new motor. Oh, and of course the reinforced Z3 oil pickup tube, because I'm in there!
The input and output shaft seals for the trans look dry, and I'm not super interested in replacing them if they're fine. Is that foolish? The PO of the new engine said he replaced the rear main seal, and it appears pretty dry, but again....I'm already in there. But $100 ain't chump change either. Too many decisions.....
