4 5 6
talon2k3
talon2k3 New Reader
4/15/24 10:16 a.m.
All of this is epic. Can't wait to hear it.
GrayWolf
GrayWolf Reader
4/29/24 3:18 p.m.
Dusterbd13-michael
Dusterbd13-michael MegaDork
4/29/24 9:41 p.m.
Thats fantastic!!!
dculberson
dculberson MegaDork
4/30/24 6:28 a.m.
Hell yes!! Sounds like a smooth beast!
Piguin
Piguin Reader
5/1/24 1:04 a.m.
Way too civilized sound for that potential...
This is going to surprise so many people...
GrayWolf
GrayWolf Reader
5/5/24 8:43 a.m.
Team meeting
Do you think it's worth the effort to bend up metal to tie the edge of the fan and the factory shroud together?
Indy - Guy
Indy - Guy UltimaDork
5/5/24 8:47 a.m.
GrayWolf said:
Team meeting
Yes.  The air will take the path of least resistance
GrayWolf
GrayWolf Reader
5/17/24 8:12 p.m.
Sorted
High temp closed cell foam
Fabbed up trim cover piece
GrayWolf
GrayWolf Reader
5/18/24 5:08 p.m.
Coolant system doneish
When air filters go on it's gettin serious
I ordered a new fuel cell and such i'm just not happy with the factory fuel tank setup with the body lift, but it's cool because I can use it in the Hellcat HMMWV.
So once I drop that in I need to wire the pedal and shifter along with the trans controller. Once that's happy I can get the driveshaft made and make sure I have brakes then we can see if it will move on its own.
5/18/24 7:27 p.m.
"... in the Hellcat HMMWV"
say what?!?!
5/18/24 8:17 p.m.
Hey, as long as the engine is no taller than an LS1, it'll fit smiley
For the monster I built, I did need to raise the engine up, since I had to move it to the right for oil filter/driveshaft U joint clearance reasons, and then up so the A/C compressor would clear the frame.  (Still had to notch the frame slightly and I think AM General made the frame out of wrenches for as "easily" as it could be cut or bent.  I went through four or five cutoff disks to make a 8" long slice and I needed to heat it significantly to get it to get mooshed down)
A Mopar won't have that issue.  In my case an LS6 intake manifold was a hands thickness from the windshield so there was no way a blower would have fit.
GrayWolf
GrayWolf Reader
6/2/24 5:28 p.m.
Let's do the thing
Radium 22 gallon fuel cell with a twin pump surge tank
About there should do it
Make a patch
Im pleased with how it's turning out
GrayWolf
GrayWolf Reader
7/8/24 8:09 p.m.
Pretty close to moving under its own power
4 5 6
fDFXQePbPEoI4paFRA1ylRZ27KdiSQM2RlaV8pR8x64B6NUPFq8RWgCcehKtv2wt
