In reply to Jaynen :
Probably just indicative of needing a valve cover gasket. Check the pcv system as well and make sure everything is working ok.
While you have the cover off, you should probably change the cam position sensor O-ring. Those tend to leak oil on the heater hoses.
Jaynen
SuperDork
11/7/17 12:25 p.m.
Changed the map sensor out this morning and the CEL is gone. So one step closer to street legality
Jaynen
SuperDork
11/7/17 4:48 p.m.
Airbag light still coming on after installing this
http://www.projectgla.com/main/product/mazda-miata-airbag-defeat-srs-cancellation-for-aftermarket-steering-wheel/
Not sure what I am missing its flashing 2 then 6 which I think is control unit/drivers side airbag
Check both airbags to make sure they are actually connected, and actually airbags. If you need a pair to plug in to rest, let me know. I ain't that far from you after all.
Jaynen
SuperDork
11/7/17 6:22 p.m.
There was definitely an airbag in the NB wheel I removed it and put the plug i linked above into it and then put it back unplugged but its blinking the same as before so not a different error or whatever
Jaynen
SuperDork
11/15/17 4:42 p.m.
Car has paper plates need to reset all the drive readiness stuff to get it tested. Ordered a new AC and PS belt, valve cover gasket, cam o seal thing, and heater core hoses.
Do I need to drain the radiator to change the heater core hoses? Probably do an oil change anyway but same thing with the valve cover gasket I assume it doesn't need to be drained since its just the top of the motor
Jaynen
SuperDork
11/24/17 7:16 p.m.
Readiness finally triggered now diagnosing PO420 which could be downstream o2 or cat
Yes. Drain radiator.
Flush system with a hose while you are at it. Amazing amount of E36 M3 came out of all 3 of mine.
Jaynen
SuperDork
11/26/17 9:22 p.m.
Changed the plugs and plug wires found oil in some of the cylinder further indication I need to do the valve cover gasket which I did already order
Coparts fees take the fun out of buying from them
Jaynen
SuperDork
11/29/17 12:28 p.m.
Right? definitely more than I expected but still overall I think was a "good" albeit not amazing deal
On a Miata you don't really need to drain the radiator nor the oil to do either repair. However, I'd recommend a coolant change if you are unsure of its history. These cars don't have great cooling systems so I think anything you can do to help is worth it. Check the plastic of the radiator as well...if it's turned brown it is likely a time bomb.
Jaynen
SuperDork
12/24/17 5:03 p.m.
Hardtop and rollbar acquired as well as seat and mounting brackets a la harddog. Hoping the bolt to floor bracket, and hard dog hardcore hardtop is plenty for passing broomstick test
![](https://scontent-dft4-2.xx.fbcdn.net/v/t35.0-12/25993103_10154893473871876_1044229540_o.jpg?oh=582c3260c9d48b712e849b4fd7fcee90&oe=5A427FFD)
Jaynen
UltraDork
2/25/18 4:53 p.m.
Car just returned from its first event. I felt like it acquitted itself well and reminded me again why Miata's are some much awesome. This event was a two day event at VIR which is an amazingly beautiful course. Day 1 was Full Course, Day 2 was Grand course
![](https://scontent-atl3-1.xx.fbcdn.net/v/t31.0-8/28238775_10155040803371876_2365882364959964774_o.jpg?oh=f67c55b371b4f6b1ba2248da81eaa491&oe=5B442DA9)
![](https://scontent-atl3-1.xx.fbcdn.net/v/t31.0-8/28235566_10155040803511876_6424423364852140185_o.jpg?oh=d8bb76541471ade82b9a0e82704678b6&oe=5B1A8759)
![](https://scontent-atl3-1.xx.fbcdn.net/v/t31.0-8/28238984_10155040803391876_2809944670050473240_o.jpg?oh=571fbcd994729eafa16ce4e6702e9909&oe=5B46265A)
![](https://scontent-atl3-1.xx.fbcdn.net/v/t31.0-8/28336418_10155040803386876_8564324387073802605_o.jpg?oh=4e43d0bf978e411c6bcea131003dbbde&oe=5B1ADEED)
Jaynen
UltraDork
6/15/18 1:23 p.m.
Broke an alternator belt and popped the radiator heading to CMP so time to upgrade :(
I've got a brand new aluminum one down and Albemarle...
