Here is the video from the dyno, check it out here
I ordered a carbon center dash panel back in July and it finally arrived, can't wait to install it. I have now driven the car 3500 kms (2174 miles) and it's been mostly smiles all the time. I am chasing down little noises here and there and small leaks, too. The initial biggest noise was a weird frequency coming from the area of the transmission, which I figured was a pinion angle issue. Changing the pinion angle would change the speed that the noise would be at its worst but didn't eliminate the noise. I finally figured out that the engine was angled down towards the back too much (5 degrees) and lifting that up has cured THAT noise. Now there's a different noise because the headers are now right up against the floor as a result of lifting the back of the motor up (GRRR). I can fix this with a little welding and will wait for the winter to tackle that. The McLeod hydraulic throwout bearing has been disappointing, it leaks already so the trans is going to have to come out to fix it, another item that will wait for winter. The axle seals leak and they have been replaced 3 times now so there is a design flaw going on there. It's manageable, though, I just have to wash off the dribble of fluid every time I wash the car. Otherwise I am enjoying owning it and driving it and feel like big man on campus when I drive it around. The car breaks necks and is fun to drive.
Pulled the exhaust off and removed the transmission so I can replace the throwout bearing. Took only 1.5 hours, helped by the stands I made to raise my Quick-Jack up another foot.
In a classic case of project creep or maybe it's "while you're in there" I have decided to build 180 degree headers for the Camaro. Attached is a picture of the current underside of the car and after correcting the angle of the engine for proper u-joint angles, the headers are right up against the floor. I had plans to alter the collectors to clear the floor and I also realized that I can incorporate the trans mount into the torque arm crossmember. Then I realized that with a few extra tubes and some welding, I can built 180 degree headers that will make the car sound even better. I'll try to get the tubes equal in length but it will be a challenge. Correct me if I'm wrong but I think I just need to take the two center cylinders from each side and cross them over to the other side?
In reply to loosecannon :
They're called 180-degree headers because the exhaust pulses are grouped such that they are 180 crank degrees apart. I don't have a more clear way to put it in words, so I'll make up a visual.
lets say your firing order is A B C D E F G H
Write it like this:
A C E G
B D F H
those are the groupings you want
so on a classic SBC with firing order 1-8-4-3-6-5-7-2, the groupings are 1-4-6-7 and 8-3-5-2
Depending on your EFI system flexibility, closed loop fuel control might be jacked because the LH o2 sensor is seeing exhaust from 1-4-6-7 instead of 1-3-5-7, and RH o2 is seeing 8-3-5-2 instead of 8-4-6-2
AngryCorvair (Forum Supporter) said:In reply to loosecannon :
Write it like this:
A C E G
B D F H
Thanks for sharing that. I think i jumped head first into what I thought was a great idea but now I think I made a mistake. My friend owns a very good speed shop and he tells me that what I want to do has the primary tubes too long and too unequal in length, so I will not get the sound I am looking for and will actually lose top end power. He suggests I do a 4 into 2 into 1 on each side but I did not order the right parts for that from Stainless Headers. Now I have to try and cancel all the parts I ordered
Yep, 4-2-1 aka tri-Y work well. The cylinder pairing should be chosen to make the exhaust pulses as close to 360 crank degrees apart as possible (for most uniform scavenging). Again using Gen1 SBC as example 1-8-4-3-6-5-7-2 we need to split up the 8-4 and the 5-7.
For 8, we could pair with 2 or 6. Pairing 8 with 2 gives pulses 540 and 180 apart. This leaves us with 4 and 6 together, which are also 180 and 540 apart. Pairing 8 with 6 gives pulses 270 and 450 apart, and leaves us with 2 and 4 together which are also 270 and 450 apart.
For 5, we could pair with 1 or 3. Following the same logic as before, we'd pair 5 with 1 to get 270 and 450 separation, vs pairing 5 and 3, which would give separation of 180 and 540.
I cancelled my order for the 180 degree header supplies but my new seats and seat belts arrived so I installed those. I am quite pleased with how nice these seats are
I just released a video about the seats and belts a few other things. Here it is
What hydraulic TOB are you moving to next? I've heard good things about Tilton according to a shop owner who's installed a number of them.
loosecannon said:I had my second autocross with the "finished" Camaro. This time I started with lower tire pressures and the shocks set where I had them last time. My first run went great and I set a competitive time immediately, and it was clean! My next run was quicker but I clipped a cone in a narrow chute (picture attached). The chute was in theory wide enough to go straight through, however, approaching it in a straight line was very difficult for bigger cars like mine. Anyways, I got a temp warning buzzer and looked to see my engine temp at 215 F. I have two big fans on the rad and only 1 of them has ever been needed to keep the car cool. The second one only comes on when engine temp exceeds 207 F or when the AC is on. Well, it didn't come on today and I don't have the tools at the track to diagnose but it seems like a short somewhere so I disconnected it and carried on, spraying the rad between runs. The car felt great on the track, I was able to throw it around and it never did anything weird and didn't even lock up a tire once. I finished 2nd in class (by only .2 seconds) and was only 4 seconds off the top raw time for the whole event (an SSP Porsche Cayman GTS) 75 seconds vs my 79 seconds. I was quite disctracted by the fan issue so I couldn't get my head in the game but I still think I did pretty good and I love the car even more now
From 7/4/23 post, I see u have 2 fans in one shroud. There's no point in having fans come on at different temps.
Reason being that the first fan to come on draws approx 80% of it's air thru the rad and 20% of it's air BACKWARDS thru the inop fan then across to the op fan.
There's high pressure behind the op fan and lo pressure inside the shroud, that 20% (which is obviously hot) goes around in a circle in and out of the shroud.
That's why those rubber flaps are used ... to stop recycling in traffic/low speeds thru the high speed slots that are under the flaps. Obviously impractical to install flaps on the inop fan.
Jim in Oz.
In reply to OzRaceFan :
You are right and I can't believe it never occurred to me. Anyways, it's a very simple wiring change to kick them on at the same time. I've been chipping away at the winter improvements and they are nearly complete. I combined the torque arm mount and the trans crossmember into one piece, saving weight and clearance for the exhaust. I also got a set of steelies and all season tires for moving it around (or taking to the painter, as an example). They are wider that the tires the car came with but looks so skinny compared to the fat boys I usually run
I took the car back to the painter and he relocated the mirrors so the vent windows are now functional. He also improved the panel gaps and polished the car in preparation for the big car show coming up in a couple of weeks. I built new door bars that are lighter and stronger that the old ones and they clear the door panels. In the process of changing spark plus, I discovered that the coils are really old so I put new MSD coils and wires on it.
The guy who organizes the big World of Wheels car show saw the Camaro out on cruise night last year and approached me. He said he had never seen a first gen Camaro like it and he really wanted it in the show. Well, he gave my car prime spot and didn't charge me for it so the Camaro is in the show alongside a Porsche 550 Spyder replica that I did all the plumbing and electrical on. They have me in the Pro-Touring category and looking at all the other cars in the class, mine is for sure the only one that actually gets driven, nevermind raced.
That's awesome! Also well-deserved, imho. You've put a lot of love into this car.
Ok so I was only thinking I had a chance at winning my category (Pro-Touring) because there wasn't many cars in that class. Well, I guess I set my sights too low because I won the International Show Car Association award for Best Overall Street Car, which includes all the street legal cars in the show-WOW!!
I think you're going to have to clear off a full shelf for all the trophies coming your way!
Congrats!
loosecannon said:Ok so I was only thinking I had a chance at winning my category (Pro-Touring) because there wasn't many cars in that class. Well, I guess I set my sights too low because I won the International Show Car Association award for Best Overall Street Car, which includes all the street legal cars in the show-WOW!!
Not a surprise! This is easily one of my top 3 favorites cars of all time. Absolutely inspirational
180 degree headers absolutely do work even though the primaries are "too long". For a front engine, under-floor header car, they aren't all that much longer than the ones for mid engine or side-exit exhaust.
FWIW there was a thread on speed-talk where they took a NASCAR engine (about as highly developed as a pushrod engine is going to get) and replaced its headers with a set of 8" long stubs that dumped at right angles to a 4" pipe, no collector or anything. Just to see what would happen. Made about the same power within the measurement accuracy of the dyno.
Under engine 180 degree headers look like a real pain to fabricate and work around, so it seems like you just really have to want that sound.
Immediately after the show, I took the car to our local Xpel installer (Protex) to get PPF and window tint installed. They took some amazing pictures of it and I'll share them here. I don't think I'll ever get used to the attention this car gets. People will jam on their brakes and turn around to come look at it and ask questions. Anyways, Rodan, Piguin, aircooled, TravisTheHuman and dean1484 (hope I got everyone) have been re-creating Casper the Camaro as a Mod for Assetto Corsa and it is amazing to me how accurately it drives in the sim. I guess it's all just math like a good suspension simulator but after plugging in all the numbers for car weight, suspension design, spring rates, roll bar rates, horsepower, etc it drive like how my car does. At first, the car didn't feel as fast as my car because it would only spin the tires a little in first gear and my car will spin them hard through first and second and well into third. So, I tried it on the 400 meter drag strip in AC. I tried and tried but the best I could get was 12.9 seconds. Where the real car, on an unprepped surface with no launch control got a 12.0 or a 12.1 at over 120 mph. I tweaked the horsepower until I can now get 12.1@124 mph in AC. Also, on a road course like Nurburgring, the balance was perfect but as is typical in real life, it pushes on an autocross course. I made the rear anti-roll bar adjustable so I can reduce understeer when I autocross it. Here is a picture of the Mod car they have created, plus some pics of the actual one.
