bigfranks84
bigfranks84 Reader
12/25/18 8:12 p.m.
Idling
https://youtu.be/O6iORGz8QNw
First drive
Rear shocks are rattling, got to look into that.
https://youtu.be/DiCxKxzicMQ
bigfranks84
bigfranks84 Reader
12/26/18 9:50 p.m.
Random info.
If you want to fit a 15in wheel it will fit with a slight smoothing of the calipers.
bigfranks84
bigfranks84 Reader
12/29/18 8:01 p.m.
Drove this around the block (about 1.5 miles). Zip tied the front end on.
Fixed the rattle in the back.  Forgot about the broken shock mount. Fixed that and the rear sway bar was loose. And but some spacers for the bilsteins to keep them from moving on the lower mounts.
Need get the alignment closer. Just eyeballed it after changing the inner and outer tie rods.
But drove pretty good.  Throwing a p2006 code again. I may have pull the sensor to far when I zip tied it up out the way.
vAhnQuha61AWD4Cqx9oV6Y446t4AilipTMMFpdgV1irLftDnsMDKHGLUnytwTvJ4
