Rather than pull Powertrain yesterday, I spent some more time cleaning and putting things in order. Threw away a set of spark plugs I removed from the E60 in 2017. Gave 2 boxes of scrap steel and one smaller box of copper wire to my neighborhood scrap guy. Then I decided I needed to see the car with all four tires on the ground. A little eye candy motivation, you know? In the process I'd be able to measure halfshaft lengths and verify my leaf spring adjusters would put my ride height where I want it.
first, a rough check of halfshaft length at full droop:
several Toyota and Lexus models share both the 01X inner joint bolt pattern *and* the C5 outer joint spline, so I'm hoping for an off the shelf halfshaft solution. Catalogs list compressed length; shortest I can find is 92-96 ES300 at 21.75", followed by 99-03 RX300 at 22.25", then 01-05 IS300 at 25.3". I'll start by test-fitting the shortest one and go from there.
So I continued assembling rear suspension to check out my spring preload / ride height adjusters. I set them at finger tight in full droop for maximum stance bro, then remembered that I don't have any tires mounted on C5 rims. Doh! No worries, not turning back, I'll throw on the E92 rears (255/35 on 18x8.5 ET37, vs C5 275/40 on 18x9.5 ET65). Next hurdle: floor jack trapped under rear cradle, *and* fender lip was resting on tire. No prob, use other jack under rocker, unweight suspension and crank up 2 turns on adjusters. Fender lips no longer resting on tires, wheel arch 25" from floor. Juicy.
Even with 20mm more width, the C5 tire will have 15mm better clearance to fender lip thanks to that +65 offset. I guess it's time to mount up the tires I bought 3 years ago.
Front had its own challenges, and I've determined that the Cragar Super Trick skinnies just aren't going to work for me. Front fenders are sitting on the treads, that's how bad the offset is off.
As with the rear, the floor jack was trapped under the crossmember. Need to see where the C5 front tires (245/45 on 17x8.5 ET56 iirc) land.
She's not quite a GT40. Roof peak is about 50-51" at what is pretty dang close to design intent ride height.
