3 4 5 6 7
Pete Gossett
Pete Gossett MegaDork
5/30/18 7:41 p.m.
Snickety snick snick...
I got the shifter rebuilt today, based on the condition of the remaining pieces I’m surprised it worked before.
Pete Gossett
5/31/18 7:02 a.m.
I went out to the garage this morning & figured out what was up with the coil harness connector...
Apparently the old plug broke off inside the coil-end of the harness.
Dirtydog
Dirtydog HalfDork
5/31/18 8:40 a.m.
I guess it's supposed to look like this.
Pete Gossett
5/31/18 9:12 a.m.
In reply to Dirtydog :
Correct, that’s the chassis-side plug, and the orange part in your pic is what got stuck in the coil-side part of my harness.
Pete Gossett
6/2/18 8:07 a.m.
I figured out why the engine wasn’t level. On the driver’s side motor mount, much like sex, in my exuberance to get it into the hole I didn’t notice it was in the wrong one... When I couldn’t reach the starter terminals at all I realized I needed to level the engine, thus leading me to this discovery.
Dirtydog
Dirtydog HalfDork
6/2/18 8:36 a.m.
Ah yes.  The wrong hole recipient, will always gently remind  of placement.  One less concern.  Now on to wring issues.
Crackers
Crackers Dork
6/2/18 12:21 p.m.
That's kinda E36 M3ty. You'll have to drop the subframe again, won't you?
You've just got all kinds of stuff stuck where it doesn't belong. LOL
Pete Gossett
6/2/18 12:57 p.m.
In reply to Crackers :
Fortunately I was able to loosen the 3 driver’s side motor mount bolts & pry it into the hole, set the engine down, then tighten the bolts.
I got everything in the engine bay connected(I think), with the exception of the fuel feed & return lines. The oil, coolant & PS fluid is in, and the clutch is bled.
Remaining is: connect fuel lines, replace fuel filter, possibly drain tank(?), change diff fluid, install driveshaft, bolt in the downpipe, hook up the battery...then check for leaks, oil pressure & fire when I crank it over.
Dirtydog
Dirtydog HalfDork
6/2/18 4:49 p.m.
Kinda nice when you catch a break now and then.  Sounds mighty close to firing it up.
Pete Gossett
6/3/18 11:59 a.m.
Getting closer, need to sort out an electrical issue & install the driveshaft.
Stampie
Stampie UltraDork
6/3/18 12:05 p.m.
In reply to Pete Gossett :
The true definition of a flying Miata.
Indy-Barely Functional-Guy
Indy-Barely Functional-Guy UltraDork
6/3/18 1:40 p.m.
Snicker.....
Pete Gossett
6/5/18 7:23 a.m.
I got the driveshaft installed this morning & exhaust bolted up...except for a stud on the front of the cat that snapped off. I’ll live with an exhaust leak for now, since replacing the whole exhaust is on the short list.
I did a bit of electrical troubleshooting too, but didn’t find anything conclusive yet.
Pete Gossett
6/6/18 6:27 p.m.
It’s alive!
I need to get one of the boys to hold down the brake so I can torque the crank pulley bolt, then install the undertray & related hardware, check the lights, bolt on the plate & take it down the street and back. Hopefully that’ll be Friday.
Then I can check my eyeball alignment & see what other problems need dealt with before bolting the interior in.
Then I need wheels/tires/exhaust, then...
Dirtydog
Dirtydog HalfDork
6/6/18 7:27 p.m.
Give the man a ceeegar!  Good for you.  Glad it's running.   Now on to the then.....file.
Pete Gossett
6/8/18 7:31 p.m.
Stanced out bruh...
Per my iHandy Level app that’s -4.5* left and -5.4* right. I also checked it with my $0.99 dial angle finder, which showed ~ -5*. This seems odd since most STS cars can’t get more than -3.5* without offset bushings, even when using the same extended lower BJs I am?
Front ride height is ~4” from the bottom of the pinch welds, rear is ~4.5”. Both measure within the range of other STS cars, though I want to level it out. The front is raised as high as it’ll go, so I may need to swap the ISC upper mounts from front to rear to get more range.
I’m going to give it a better alignment too. I just kinda looked at it & adjusted until the hubs were mostly pointed straight ahead.
I took it for a short drive through the neighborhood - after using a c-clamp to close up my exhaust leak somewhat. There were no problems with the car, though a Yukon almost blew a stop sign & parked on top of me...fortunately I saw her ahead of time & stopped in the middle of the intersection to wait.
Pete Gossett
6/8/18 7:33 p.m.
Also - it feels *really good* to drive a stick shift again after more than 2.5 years.
Dirtydog
Dirtydog HalfDork
6/8/18 8:54 p.m.
Looking good.  It's fun finding the power band you like.  I just drove my son's new to him 89 TBird Super Coupe.  First time I've driven a stick in,  umm, decades.
You know, some tape and rattle can white, might doll up the beak on that.
Pete Gossett
6/8/18 10:30 p.m.
Plastidip is the working plan, but that probably won’t be until next year.
Pete Gossett
6/9/18 10:19 a.m.
I took the Miata for a “real” test drive this morning, after getting it aligned a bit closer & bolting on the hood. The first stop was 2-miles to the gas station to fill it with premium so I can set the timing later. From there it was 3 more miles to McDonalds.
Bee as my copilot.
While sitting in the slow moving drive-thru line the temp gauge started climbing up to about 3/4. The line was slow enough I just shut the car off between movement, and by the time I was about 1/2-mike down the road back home the temp had already dropped. I never heard the fan kick on, so I’ll have to check it & the relays.
I also smelled a bit of oil, but didn’t see anything under the hood. I’ll check for any drips/puddles underneath later, but the oil pressure held steady so it’s hopefully nothing major.
I did wring it out a couple times. It’s certainly not fast, but it pulls steady & smooth, and the exhaust actually sounds decent. The chassis is nice & tight, and the only rattles were from the windows, which need attention anyway. The idle dips really low when I’d let off the throttle, but it came back up & never died.
So far, so good. Mostly.
Ovid_and_Flem
Ovid_and_Flem Dork
6/9/18 11:17 a.m.
Oil smell is left over from the many blown C4 front seals. It is the bane of your existence forevermorecheeky
Pete Gossett
6/9/18 7:04 p.m.
In reply to Ovid_and_Flem :
Haha!!! Possibly...
I replaced the blown turn signal bulb this afternoon & also discovered the right headlight was cracked/blown. Fortunately I have a pair of headlight assemblies from a Mariner Blue car, and when I went to pull a bulb from them I discovered they’re Hellas - hell(a) yes! So I swapped in both bulbs so they match.
I verified the radiator fan works when I jumper the diagnostic terminals, and the thermoswitch is new, so I think it might not be grounding through the coolant neck. I still need to figure that out.
I took it for another drive this evening, Wendy’s this time, and it still seems to run & drive fine. I was able to toss it around a corner just a bit, and even on these crappy old all-seasons there was no drama.
Dirtydog
Dirtydog HalfDork
6/9/18 7:07 p.m.
You and your buddy buzzing around town, eh?
Stampie
Stampie UltraDork
6/9/18 7:25 p.m.
Great you got this one going. So is the budget Challengable?  Going for 1st in autocross?
Pete Gossett
6/9/18 7:45 p.m.
In reply to Stampie :
Sadly, no. It could have been if I’d not bothered with the timing belt/water pump/gaskets/motor mounts/etc., but I didn’t really want to pull the engine back out again.
Also, I’ve never once been able to build a car the way I want to - I’ve always run out of time/money/skill/tools/patience - on every single car. I realized that unlike the Vette, the Miata is a car I can afford to do that with. It’ll still take me several years to build it fully the way I want it, but that’ll work well w/my schedule, and I can use/race/tweak the car during that time.
3 4 5 6 7
PhIvzQpDUeW9276CeCpfmpbZrukBo2DgR0FQKwdI8qfIw2wiPGgKGtAyFeL9StvH
