2 3 4
preach
preach UltraDork
6/28/24 6:08 p.m.
In typical GRM fashion I pretty much bought the first non Opel part for this Opel. Some E36 M3 you cannot pass on. I pick it up Monday.
For $200 I am getting the proper side Lamborghini Gallardo (sp?) header to put the turbo in front of my engine. $200 is a damn steal (from my research a couple years ago).
Stumbled in on it when I picked up my Cayman. The mechanic had to buy a pair of the headers and wanted rear dump for his Audi. Said he'd sell me the other one cheap. Boom Pow sold!
Stoked.
Best part is after the repair of the Cayman I have a couple grand to spend on Opel stuff.
6/29/24 11:03 a.m.
In reply to preach :
Got the Boom Pow Surprise there.
preach
preach UltraDork
7/1/24 5:35 p.m.
preach
preach UltraDork
7/25/24 6:59 p.m.
The look I am after shown by the white car...
preach
preach UltraDork
7/25/24 7:09 p.m.
Yeah...goals.
preach
preach UberDork
9/27/24 4:50 p.m.
$150
Indy - Guy
Indy - Guy UltimaDork
9/27/24 6:25 p.m.
What flavor am I looking at there?  I don't recognize it.
preach
preach UberDork
9/27/24 7:04 p.m.
2007 Rabbit(Golf) 2.5l 5cyl. Basically 1/2 of VAG v10s. Header is from a Lambo.
So stoked!
11GTCS
11GTCS SuperDork
9/27/24 7:31 p.m.
I'm starting to see what you're up to and I like it.  What options are there for a RWD transmission with the I5?  Adapter plate?
preach
preach UberDork
9/27/24 8:15 p.m.
Research needed but an audi 6pd can become a transaxle. A bit of a good machinist is needed.
EDIT: If you look at the boostbrothers link they make most of the conversion for the body snatcher plan.
preach
preach UberDork
9/29/24 6:21 a.m.
Pressure washed the engine and putting it in the shop today. Knowing me it will take another year for an update, but I'd love to get down on it.
9/29/24 6:54 a.m.
preach
preach UberDork
9/29/24 11:45 a.m.
Had to drive out from under it. Probably have not used the hoist in a decade...
preach
preach UberDork
10/5/24 5:03 p.m.
Finally had time to get back to this. Been on 12hr, 04-16, shifts for a couple weeks so I took this weekend off.
Not much has changed, since even filling the cyl with oil it still doesn't go up high enough to put it on a stand. Add to that that one cannot find m12-1.75 and m10-1.50 threaded rod/allthread here on the weekends.
No central bolt on the crank and I have zero clue how to pull the plugs on this engine, but if I knuckle on to the pulley I can rotate the crank a bit and I think I found compression in either direction. 100% rebuild anyway but hopefully do not need to sleeve it.
Having a fit, in my own really mellow way, I decided to use my little window of time and started cutting off all of the wires and hoses. This may berkeley me later but a stand alone and all new stuff will remedy that.
Since I need a hydraulic ram for the hoist anyway I may buy the air over hydraulic one from the hammer store. Not sure as I do not pull many engines now-a-daze. Kind of a reason to use my IG compressor that is new to me...
Dying to find stuff and time to get this on the stand and get the heat shield off of the header and get it mocked up on the engine.
I hate/love 5cyls.
preach
preach UberDork
10/5/24 5:07 p.m.
I cannot wait to have a side by side pic of my factory Cayman header and the Lambo one. Porsche fails in comparison if I am right.
preach
preach UberDork
1/31/25 6:23 p.m.
For AC:
I am hoping to get out to the cold shop this weekend, since I actually have it off, and swap the piston on the crane so I can at least pop the 07k oil pan off and see if I save some $$ on a forged crank. Some 07ks had one from the factory, some didn't.
An Audi forged crank for a 5cyl needs to have modifications to get installed into a VW block and had an 8 bolt flywheel flange vs a 6 bolt. The 6 bolt needs a friction plate between them so it does not loosen the fasteners (umm loctite?) and it costs $1300 last I looked. If I get a forged 6 bolt with my $150 engine I will be stoked! My hopes are not up though. Seems like a craps roll to get one forged.
The state of my shop, in the cold, is not great either. I tore apart 20% of the car and it is everywhere. I have not had much time to get back out there an unberkeley everything. I am also trying to find the rare freaks of Opel crap to sell/give the stuff to. Weird it is rare. I'd rather not metal dumpster it for crap if folks can use it.
This spring, I need to get out and see the condition of my Westfalia that has been in storage for a long time. If it sells (barely any rust and a newish tent, etc), it will fund the hard parts of this. But batteries, and varnished fuel, etc from sitting.
I hate the phrase "hat car" but this is going to be one of them. My plan it to do the swap to a 944 and make it function, then swap the shells for glory.
Mostly I need to get over my life, quit being a bitch, and hammer down.
1/31/25 7:55 p.m.
since i don't know if you respond better to positive or negative reinforcement, i'll just say I believe in you, you berkeleying twat.
2 3 4
l1xgLImFZYjbuxeCGoDtMpnBLNqnVn4XDFouYfx529Cik1ZS80cajRYGHmNjaW9X
