ditch dug for power to shed, now I can run the big buzz box out there. Tractor made quick work of smashing the dirt back in the hole
Took it to the car wash since it has been filthy for months.
Airdamn back on white trash, and white trash got washed.
Ac took a E36 M3 on the black car, did some quick diag and found a green fuse.
Getting the motor more and more dressed. PO loved clear silicone.
On a baby kitty brake, the water pump was held on by 5 bolts and clear silicone
tabbie the black rt has been running worse and worse the last few days. Started with common issues, cam sensors and magent. Magent and sensor was roached. Still ran poorly when done
Did a compression test 170 across the board, plugs looked fine, has correct fuel pressure, plug wires ohmed out fine. Gonna pull upstream 02 and take a look at the cat, got a sneaking thought it might be my issue.
Professor_Brap (Forum Supporter) said:In reply to Bent-Valve (FS) :
Got 2 at powdercoaters, one black, one red.
Which one is going on this block?
BTW I had good luck with the HF powder gun and an old oven when I was building paintball markers. It takes very little to get set up to powdercoat smaller items.
Bent-Valve (FS) said:Professor_Brap (Forum Supporter) said:In reply to Bent-Valve (FS) :
Unsure yet, got another stripped with a few trips through the buzz box, might polish it.
If I had the room I'd do some home powdercoating.
In reply to Professor_Brap (Forum Supporter) :
how do you like that ultrasonic cleaner? where did you get it?
metty said:In reply to Professor_Brap (Forum Supporter) :
I love it, when working on old crappy cars it makes cleaning much easier. Got my first one off ebay, got this big one off marketplace.
Been a crazy few das fixing everything.....
Iris: had a front caliper lock up so had to rebuild it.
White trash: would go from high idle to ideling down for no reason. Messed with it for a while, never really got it to act up again.
White wagon: had to fix ac had 2 bad o rings and recharge the system.
Tabbie: got her good to go again from the and take manifold, then had leaky injector seals got those replaced. Then the feed line ruptured.
Seems like all the cars wanted to break at once. I did get some nice seats for glh along with the big center console and tower and all its accessories.
Ran the dog E36 M3 out of the generator last night due to a power outage. She got a little warm
As I was putting stuff away, I need to do a shed clean out sooner rather than later.
