Patrick (Forum Supporter)
6/19/20 7:38 p.m.
Professor_Brap (Forum Supporter) said:
PO booger welded/screwed radiator brackets on to fit the intercooler and move radiator over. Had to remove them to fit ac lines.
once they where removed there was a big ass crack and holes.
had to take care of that
Hey i have the same welder
Professor_Brap (Forum Supporter) SuperDork
6/19/20 9:26 p.m.
In reply to Patrick (Forum Supporter) :
It's my go to body panel welder.
6/19/20 9:28 p.m.
I got mine at TSC when i was probably 18.
6/20/20 12:53 p.m.
New map sensor did the trick. Check wiring, old sensor and new sensor. Old sensor didn't produce signal. Think this is why.
Next on today's docket is Killin the cel on a 300k neon
6/20/20 4:42 p.m.
So black rt popped a code for downstream o2 of range.... Have some time and energy, so decided to make a home made defowler.
Car went on a quick 50 mile jaunt and no codes and everything seems good.
6/21/20 1:37 p.m.
Had to tig the pump housing, and retap a pipe plug and we are back in business.
6/22/20 7:10 a.m.
This is what "Mondays" look like.
Bent-Valve (FS)
Bent-Valve (FS) Dork
6/22/20 8:11 a.m.
Argh.
I feel your pain. All you need on Mondays is to get to work, not more work.
6/22/20 8:33 a.m.
In reply to Bent-Valve (FS) :
Got brushes being dropped off on lunch, gonna fix it in the parking lot at work. I walk into work, 20min later someone has a fork lift sunk to it's belly in mud.
6/23/20 4:38 p.m.
Who let me on marketplace
6/23/20 6:57 p.m.
Pumping fuel out to replace pump. Had good pressure at idle, was about 10lbs low at WOT and higher rpms  Got it down to the perfect level of fuel to drop tank
6/25/20 6:08 a.m.
5min and tank is out
10 min later old out, new in
Still not fixed, still going lean, got injectors on the way.
6/27/20 7:06 p.m.
Drive belt, new asbestos brake shoe, and fix the rear locker and she's good to go again. We'll have a update on Omni later tonight
6/27/20 7:32 p.m.
After having the engine and trans together and apart 5 times we are getting somewhere
Behind there is what gives my gray hairs.
1st attempt with through the top, 2nd and 3rd where through the bottom
It's in, now all the cussing starts.
7/1/20 7:36 a.m.
Sorry for E36 M3ty pic, but progress.
7/1/20 8:02 p.m.
Things are happening.
Bent-Valve (FS)
7/2/20 8:13 a.m.
Your not about to, well,  a picture is worth a thousand words....
Or something like that are you?
Nope. Hes coming south to help me clean.....
7/6/20 7:07 a.m.
I can't say if I have done or have not done that before with a mustang, but I can say no one said anything.
7/6/20 7:08 a.m.
Been a crazy few days. Sunday at one point every car but the focus didn't run
7/7/20 2:05 p.m.
Did someone say junk cam magent and car still runs like hammered ass
7/7/20 9:58 p.m.
Kitten just wants to go for a ride.
7/8/20 8:17 p.m.
Step 69 in rich-lean-rich-lean-rich issues.
7/9/20 3:56 p.m.
Weekend prep
That mower coming here for stampie?
ilKB8n8tRNhvqn7jwp7BTogQ6cvO8tmC45VtsRATfUhM8PWkoqY133Nozjm8kYon
