Zoldier
Zoldier New Reader
1/28/20 2:38 p.m.
Picked up this 2001 Audi TT last night for $1300. Runs and drives okay. My wife got a new job and doesn't want to drive her Boxster GTS there because of the bad roads so I figured this would be a fun car for her to drive there.
Seller said it needs a head gasket but I'm going to diagnose that further. It sputters when building boost but other than that it idles and drives fine. Doesn't seem to overheat. Let's see what I find as I unbox this thing.
Vigo MegaDork
1/28/20 2:41 p.m.
Sputtering only in boost is likely ignition related. No codes? If you're not getting a code to narrow down which cyls then just crush all your plug gaps to .020" and see if it improves. If it does it's 100% ignition related.
Any pics of this thing?
Zoldier
Zoldier New Reader
1/28/20 2:47 p.m.
Just pulled codes. Three are related to misfire so I'll tackle those first but it does seem to have a bit of coolant in the oil.
Zoldier
Zoldier New Reader
1/28/20 2:48 p.m.
Damn. Why aren't my pics loading. Let's try this again.
Vigo MegaDork
1/28/20 2:49 p.m.
I'd buy that for $1300 right now. Cool!
Robbie
Robbie MegaDork
1/28/20 2:54 p.m.
Yeah, these have really grown on me over the years. Cool.
Zoldier
Zoldier New Reader
1/28/20 5:57 p.m.
Need to get the Corvette project off the lift before I dig into this one so I started poking around a bit. Found a nice surprise underneath. Some H&R Street Performance SS Coilovers.
de80q
de80q Reader
1/28/20 11:09 p.m.
Seems like a good find.  I see the secondary air code is there too.  Make sure all the lines for that are in good shape.  They are know to fall apart if I remember correctly.
1/28/20 11:25 p.m.
They've always had excellent style, a real case of a show car escaping on to the streets.
westsidetalon
westsidetalon HalfDork
1/29/20 12:13 a.m.
Very cool. Been contemplating a Challenge or rallyx budget TT as of lately, they're definitely out there.
Zoldier
Zoldier New Reader
1/29/20 6:36 a.m.
In reply to westsidetalon :
Yeah. A challenge build crossed my mind but my wife would kill me. I bought a SVO Mustang for that last year but haven't got to it.
Stampie
Stampie UltimaDork
1/29/20 6:42 a.m.
In reply to Zoldier :
TT is cool but do you have a build thread on the SVO?
tip
tip New Reader
1/29/20 7:56 a.m.
I'd want to see the fuel trim % values but I'd throw a known good MAF on.  Plus 4 new coils.
Also check the large vacuum lines under the intake for leaks.
All common weak spots on the 1.8T
Zoldier
Zoldier New Reader
1/30/20 12:01 p.m.
In reply to Stampie :
Not yet. I'm going to start one on the 87 corvette first since I need to get it out of the way. This one is mostly a restoration though. Not much going into it performance wise. Once I get that off the lift and get the TT head gasket replaced I'll start one on the SVO. Also have two other cars in line.  Lol.
BrianC72gt
BrianC72gt New Reader
1/30/20 1:26 p.m.
With Secondary Air Injection codes, look for frayed, brittle & crumbling vacuum lines covered with a braided cloth.  Is it 3.5mm or 5mm?  Don't recall.  They used it to send actuating signals all over the place.  Why use electrons when vacuum is more analog Rube Goldberg?  Plan on replacing all of it.
Ross Tech's VCDS aka VAG-COM is your friend.
KnLetTmeCOYbamuIifMC9KYuTbB41mua4GBK3i6mQLlkqXk3JWDbqbmEWjSWslR1
