fidelity101
fidelity101 UberDork
11/22/23 3:43 p.m.
After much debate and measuring and random thoughts, it was time to give up on my RX8 ideas. It just didn't make sense and was going to cost way too much money. So I managed to sell the rolling shell...
a truck with a winch is a godsend, time to swap trash for trash. SWMBO won't let more yard cars stay there so only 1 inop at a time means rx8 had to go bye bye.
 and associated parts along with some spare Rx7 parts to come up with enough cash to save this car:
it was conveniently located near my parents house in the Chicago area so being that is thanksgiving week and I was already coming here with my truck, it made sense to drag the trailer along for the ride as well, in the end it only cost me a little bit of gas money however this car has no title so there is going to be some interesting things that will need to happen to get that resolved and registers but we are far from having this on the road so that will wait.
It is in rough shape and as far as I can tell it hasn't been rally raced since 2003. It is in dire need of rust repair inside but has some redeeming features being the rear end of the car is in good shape, doesn't appear to have been rolled (yet), front has some
tiny gas tank but looks to be very intact, unlike the floor:
passenger area is held together by paint, inner and outer rockers are gone, you can see air through them:
engine bay looks to be fairly solid but lots of paint flaking off
lots of work ahead, no real time table but should be fun as these were 2000lbs in original trim so several hundred pounds lighter than the current rx7 and if we can put together a 160-200hp motor for cheap this should scoot pretty good but before we get there it needs a floor and preparations for a suspension overhaul.
Ideally the stock welded diff axle on 13s isn't going to work great as we cant fit brakes or cant find tires but some fabrication and various FC parts for the front end will work as will a shortened 8.8 ford solid axle and convert it to a 4 link, ideally I can find some Ford Econobox rally parts and adapt it, we will need to do a lot of modification to the floor to fit ourselves in this small car but that has been done before and will be done again, if we had to cut the floor out anyways this makes for a nice opportunity as this car basically fell into my lap.
the bolt together cage parts are pretty laughable, safety has come very far for Rally since this has hit the stages but still has some ways to go given the immense challenges of the sport.
Key project goals:
  • install Floor
  • Title (if no title, I can't register it then it will just become a rallycross car versus a stage rally car)
  • map out history
  • Performance/Rally Readyness
irish44j (Forum Supporter)
11/23/23 10:59 a.m.
fidelity101 said:
Finally someone will have a rally car older than mine :) Yeah, I know there are a few others running ARA, but not many! I'm excited to see this build :)
fidelity101
11/23/23 12:56 p.m.
I cant make an fc 500lbs lighter but this should be
fidelity101
11/30/23 10:19 a.m.
so some quick digging and comparison:
so the ideas are floating around now
IRS or 4 link rear?
AWD or RWD?
Boost or N/A?
Cheapo Deluxe or go home and go broke?
or the ultimate frankenstein spare parts car? (part rx8, part subaru, part FC rx7)
either way everything requires a lot of fabrication
EvanB
EvanB MegaDork
11/30/23 10:29 a.m.
4 link, RWD, NA, Cheapo Deluxe
darkmedievaltimes
darkmedievaltimes New Reader
11/30/23 10:49 a.m.
Another option to consider if you want to retain a smaller diameter wheel is a Datsun truck rear end. My dad had one in his 73 Corolla and it measures 50" drum to drum IIRC. It was sourced out of a Datsun 520, thick axles, aluminum 3rd member. You just need to change the PCD and mounts.
Jim Pettengill
Jim Pettengill HalfDork
11/30/23 11:54 a.m.
An RX3 can work.  Back in the paleozoic Rod Millen won the New Zealand rally championship with one before he went to the UK, then to the US.  I think some people ran Mk. 1 Ford Econobox rally suspension in them.  Back in the 70s and 80s when I was competing (in Corvairs!) there were a couple in California and the Pacific Northwest.
fidelity101
11/30/23 12:21 p.m.
why do I need two rx7s rally cars though, granted the rx3 will be far lighter (likely) thats the existential problem I have. I had issues when I had my turbo rx7 and the rally car, both were too time consuming so I sold the tubo car to cover the costs of a title chase in 2019.
hobiercr
hobiercr UltraDork
11/30/23 12:35 p.m.
If you swap out the rear axle, lmk and I'll take the RX3 one off your hand. Swapping to an 8.8 and RX7 front struts will also get you a 5x114 bolt pattern which opens up wheel options from the stock 4x110.
Can't wait to see this build progress!
fidelity101
11/30/23 12:38 p.m.
Yeah this is a stock Rx3 rear axle, it has a welded open diff in it currently, regardless of what I am gonna do with the car, I don't see this rear axle staying in the car.
hobiercr
hobiercr UltraDork
11/30/23 2:14 p.m.
In reply to fidelity101 :
For my GLC any RX axle was an upgrade. I bent the RX2 axle in it when I flipped it. I'm almost 100% sure the RX2 and the RX3 axles are the same. I've also got a welded open diff as well as a few other diffs for it.
therealpinto
therealpinto HalfDork
12/1/23 8:35 a.m.
What do the regulations say?
Looking at the MkI/II Ford Econoboxs, Volvo 240 and other things successful in rallying, a well setup live axle in a 4-link seems to be a good bet. But that is dependant on having access to suitable live axles.
For an IRS a Miata swap sounds like something to consider?
fidelity101
12/1/23 9:24 a.m.
RWD (open 2 wheel drive)has the best regulations:
the IRS idea is 2 fold, I would only do it if I went AWD. Just doesn't make sense RWD given how easy an Ford Econobox 4 link setup is. The problem with that setup and AWD is I can't find 4.444 gears for it as I would plan to use subaru parts to make it AWD.
this is where the IRS comes in to play, I have so many FC spare parts and access to even more should need be. I can use just that rear suspension system - its not the greatest but it does work and I have lots of spares and all the rally part of it figured out.
Random thoughts about FC suspension design. - RX7Club.com ...
the big issue with this rear suspension, which I have discovered with the rx7, is the diff - I blew the diff on old all seasons so the pinion is weak but I can rectify this with a s1 rx8 diff which is widely accessible, possibly axles too but I have demonstrated that FC axles spline into the Rx8/miata hub.
since the diff wont be the long pinion most of the subframe in the middle is dead space
if AWD it can be STI front so I can keep 5x114.3 bolt pattern and off the shelf rally parts, rear is already pretty sorted and if I move attachments around I don't see why I cant get 8+" of travel out of the rear whereas I already 7 or 8" right now in the FC.
Minimum weight becomes an issue (2900lbs) but thats only ARA's problem because they need to subaru competitive (shots fired) whereas NASA is 2375lb based on the displacement.
therefore I need 250+HP and NA would be tough to move that much mass around and add more drive axles to the mix
just kinda spitballin now likely situation is FC front end and 8.8 4 link rear, sorting out title stuff now so I dont get carried away, otherwise I'll just slap together a carb'd 13b and put a cheap floor in it and tow it to rallycross because if I can't road legal it, it doesn't matter.
fidelity101
12/15/23 1:15 p.m.
good news everyone, we have a title!
  • For it to be a rally car it needs to be road legal
  • for it to be road legal I need to register it
  • for me to register it I needed a title
  • for me to get a title I needed to:
    • Form of ownership (MI)
    • Form/witnessed by police officer (VIN verification)
    • Surety bond ($100)
    • Certified Michigan Appraisal ($385)
    • pay tax on the value + title fee ($137)
    • wait 2 weeks for title to get mailed
    • Bill of sale from purchase
This only works on cars valued under 2500, this is more common on pleasurecraft things like bikes/ATVs/boats etc apparently but still feasible.
project is a go!
12/15/23 2:21 p.m.
i did this process to get MI title for my '61 corvair station wagon.  the cop was kind of a car guy, and commented something to the effect of "no worries with being under the value cap here!"
fidelity101
12/15/23 3:25 p.m.
yeah unfortunately since I bought it out of state they needed the verification value anyways which was a pricey appraisal for someone to overvalue my car for a quick google search of the only other rx3s for sale but whatever it was what was needed and I got the job done. I dont think I needed the surety bond for this but i didn't want to go to the SoS office a 4th time...
the cop that verified the VIN for me was a local cop and thought it was funny, " you want me just to sign this and fill this small section out? okay!" he was also giving me E36 M3 for "does your SWMBO know about this??" haha
fidelity101
10/28/24 3:30 p.m.
okay well its time for an update, its about a year later and I am finally "started"
the idea was; tear into it and come up with some sort of plan of attack.
throw out a lot of zip ties and general trash/debris inside the car, remove the fuel tank and gut the engine bay as I'm sure none of this will be retained and I really needed to see what good metal I have to work with.
that helped highlight the plan, I need to get a good 3d scan of the floor and chassis space and I can get tubes and sections fabricated as I rebuild the car. I'm not that great of a welder and this will be beyond my comfort of safety zone, IE building a whole car so I will do my best to get things in place and prep then call in reinforcements when needed. However with the rx7 repair ahead but for me to get the floor/engine bay area I need to remove everything - maybe I will get myself something nice for christmas to solve this then.
luckily there are still some cab corners with metal and the firewall has a lot of clean good metal as does the trans tunnel and rear tower area which is promising.
so right now I am working on removing the dashboard and associated pieces, the fuel tank has been removed and maybe shortly the rear axle is going to come out then it will be ready to scanning or hold off on scanning until I can add some rocker material on which will get tied to the cage and ultimately help build the car around. once I have a few hard points in place it will be easier to math up the round and square tubes needed and get local shops to supply some components and put the jigsaw in place as I cut away at the rust and rot.
fidelity101
10/29/24 10:12 a.m.
The current cage is far from legal or safe and will be removed eventually but right now its handy giving it rigidity to hold things in place while I work from and possibly anchor to.
see? there is metal. I want to add some structural rockers from square tube and use the ends as pin stands then I can get the car on car casters w the pin stands and begin working on the middle/rear and remove the old axle/suspension setup prior to 3d scanning.
next to real metal is a lot of this though...
but honestly after looking through this, seeing the rx7 cut up, seeing new cars and section cuts. Its very visible to see the progress in how we have built automobiles over the years. We have come a long way, this looks fairly straight forward whereas there are a lot more overlapping pieces to the FC to build the structure its no wonder everyone got really hurt in old car crashes and cars got mangled easily. there is a lot of evidence of 'offs; with this car but holy cow every bolt under the dash is spotless and came out effortless, even the steering box bolts came out and still showed plating, it was nuts how much was so rusty and so much other was perfectly fine/great condition.
The diff tunnel, top of the driveshaft tunnel, and the cross bar piece are solid and have some strength that can help hold this car together. the whole gas tank area is good as are the structural part of the rear wheel tubs and shock towers but the spare tire wheel well is pretty rotted and misc corners of the body.
engine bay is mostly gutted and soon I can mockup a dummy block and trans and see what room I have to work with.
the beauty of this car being so similar to the UK Ford Ford ES COR T (why does it keep changing it to econobox) coupes this solves some of my fabrication needs:
I can rebuild the rear of the car to suit my needs with these parts basically, the middle will be a variant of a floor drop, the front will be drifty boi special of trailer fenders and tubular front end to cut out the rot and hold up the body panels/cooling/lighting functions and round out the engine bay.
¯\_(ツ)_/¯
¯\_(ツ)_/¯ UltimaDork
10/29/24 10:22 a.m.
Glad to see you digging into this.
fidelity101
10/29/24 10:39 a.m.
me too, I needed to know what I was really working with to do anything - right now the rx7 is on hold and this costs me nothing but time which is nice because I need to escape to the garage some evenings for some personal papa time lately.
I will keep preparing this for 3d scan and dolly mode where its safe to work on and focus on an established baseline, when that happens I will probably get the rx7 fixed but I need to visit the potential donor car then have the cage repair/additions completed as i don't budget for one of those likely until the new year.
golfduke
golfduke Dork
10/29/24 10:40 a.m.
I love RX3's.  Following along intently!
fidelity101
11/8/24 11:01 a.m.
considering how rotted this car is, some of the fasteners are simply flawless:
some rusted bolts have obviously snapped upon removal but many come out showing the plating still and perfectly fine, many bolts are coming loose with little to no fuss. Right now I am working to remove the dashboard and associated interior wiring and work towards a bare shell. I want to retain the top part of the dash and the brackets seemingly let me while I gut the underside.
I've also started to spitball an idea of documenting the history of this car, via a podcast. I need to reach out to Alan and Ann Jordan and go from there but meanwhile here is a pic of the car in its most recent rally (that I can find so far) the 1997 STPR event:
http://www.comicozzie.com/gallery2/v/1997/ST/ST97-153.jpg.html
Shavarsh
Shavarsh Dork
11/8/24 12:57 p.m.
This thing is rad. Looking forward to seeing what you do with it. If you decide to go live axle I would try to use something lighter than the shortened 8.8. They are strong, but very heavy for a lightweight car.
fidelity101
11/8/24 3:07 p.m.
I know there are other options but for parts availability and options the 8.8 is hard to beat and I can get it in 5x114.3 wheel pattern and not limited to motorsport LSDs. The heavyness is a bit worrysome but not really, would be nice to not think about it. People already have 8.8 fords in the back of rx3's already for drag racing with big power numbers and swear by it. What would be a comparable option(s)?
Right now I am leaning heavily towards lots of FC parts and applied lessons learned because I've spent the past 20years with FCs i don't know what else to do with this information and hoardes of parts. Since the roll on the rx7 people have reached out to me send me local listings, offer parts, provide parts cars as donors/sacrifices its been pretty wild.
I've seen a few miata IRS swaps for the rx3 which would be good option too but I think the backwards direction for rally. smaller wheel bearings sounds like high wear and risk item. the miata diff mounts are on the wrong side to so it can complicate things, its been a thought but not a very serious one.
Shavarsh
Shavarsh Dork
11/8/24 6:22 p.m.
Agreed 8.8 is hard to beat on paper. I put one in my pinto (shortened explorer), ran it for years, and eventually replaced it with miata irs (with 8.8 diff) because of terrible ride quality (lots of extraneous factors could have caused the poor ride though). I remember looking at Ford 7.5 and Toyota small truck axles (like a mini 9") among others. Obviously the 8.8 won at the time though. YMMV
The devil you know (FC parts) sounds like a great way to go from here. Unless part of the fun is a new learning curve.
PnEhYHsUROL0EsHBtE7fcBj6iTQcQzCmgRpqMAGWtLtUhavjQJbzq8nHgdsnUyfL
