Ben_Modified
Ben_Modified Reader
12/1/16 7:12 p.m.
Set up the subframes to ride height on clamped on some heavy angle iron to square up their orientation to each other.
<img src="20161201_160600_resized" />
BenModified.com
chandlerGTi
chandlerGTi UberDork
12/2/16 12:11 p.m.
From the first post "don't expect any rapid progress on this, im only collecting parts". Lol
JamesMcD
JamesMcD Dork
12/2/16 12:20 p.m.
I LOVE THIS. The forum needs more micro-car content.
NOHOME PowerDork
12/2/16 1:11 p.m.
Mr. Modified seems to work in a different space-time continuum than I do. Can you imagine if he did a "Quick" build?
JamesMcD
JamesMcD Dork
12/2/16 1:21 p.m.
I think it has to do with him not being afflicted with analysis paralysis.
ebonyandivory
ebonyandivory UltraDork
12/2/16 1:58 p.m.
He puts together parts from (entirely/wildly) different vehicles with such matter-of-fact-ish-ness-ity it's like it's supposed to be an obvious choice.
"Duh Derek, you didn't think of chopping a DJ-5 down the middle and making a mid-engine Mitsubishi Hi-Jet with a 383 Stroker with direct drive and no transmission?"
Ben_Modified
Ben_Modified Reader
12/2/16 7:12 p.m.
chandlerGTi wrote: From the first post "don't expect any rapid progress on this, im only collecting parts". Lol
JamesMcD wrote: I LOVE THIS. The forum needs more micro-car content.
NOHOME wrote: Mr. Modified seems to work in a different space-time continuum than I do. Can you imagine if he did a "Quick" build?
ebonyandivory wrote: He puts together parts from (entirely/wildly) different vehicles with such matter-of-fact-ish-ness-ity it's like it's supposed to be an obvious choice. "Duh Derek, you didn't think of chopping a DJ-5 down the middle and making a mid-engine Mitsubishi Hi-Jet with a 383 Stroker with direct drive and no transmission?"
Thanks guys, I appreciate the encouragement!
NOHOME PowerDork
12/2/16 7:25 p.m.
JamesMcD wrote: I think it has to do with him not being afflicted with analysis paralysis.
You have a point there. The Minion who hangs around my shop is a "Get 'er done" person, while I like to ponder the possibilities. The Minion claims that I am more in love with the problem than the solution!
petegossett
petegossett UltimaDork
12/2/16 7:38 p.m.
This. I don't see the solution - I see every possible solution, regardless of how berkeleying absurd they may be, or at least the ones I can identify. Then I work out the risk/reward for each iteration.
Ben_Modified
Ben_Modified Reader
12/4/16 6:48 p.m.
Got a Miata e-brake handle and cables <img src="20161203_165857_resized_1" />
Also got my hands on an Limited Slip Diff
<img src="20161203_165850_resized_1" />
Cut the mounting ears off the housing
<img src="20161204_075128_resized_1" />
Trimmed off the part I don't need
<img src="20161204_093953_resized_1" />
And a blurry photo of the new mount locations
<img src="20161204_163503_resized" />
Underside view of the diff in place
<img src="20161204_163653_resized" />
The leftover bits will be used for gusset material. Just needs to be welded together now. The plan for the missing torque arm is to rubber mount the nose with a custom bracket using the torque arm bolt holes. If I need extra support I can make a bracket which you utilize the chunk mounting bolts. From what I have read, these pre 94 lsd are not the most reliable but my hope is that based on the fact that it will be propelling 800 fewer pounds with similar engine torque, that it will hold up. So yes, going with shaft drive and sideways mounted engine.
BenModified.com
Ben_Modified
Ben_Modified Reader
12/6/16 7:55 p.m.
I dug the Bianchina out of storage today!
<img src="20161206_172729_resized_1" />
Under the hood
<img src="20161206_172718_resized_1" />
With a mid engine setup, the car should have a good sized trunk
<img src="20161206_172654_resized_1" />
The initial welding is done on the revised diff mounting. Next, cut gussets from the leftovers and weld in.
<img src="20161206_173247_resized_1" />
Turns out the replacement upright had a very worn wheel bearing. swapped it out with help of a friends bearing press
<img src="20161206_173253_resized_1" />
BenModified.com
Ben_Modified
Ben_Modified Reader
12/7/16 4:35 a.m.
Ben_Modified
Ben_Modified Reader
12/7/16 6:57 p.m.
Diff mounts are gusseted and welded
<img src="20161207_172937_resized_1" />
BenModified.com
NOHOME PowerDork
12/7/16 7:03 p.m.
Was all the alloy welding done with the spool gun? Did you pre-heat the casting before welding?
Ben_Modified
Ben_Modified Reader
12/7/16 8:50 p.m.
spool gun, yes pre-heat, no
but we did tack in various locations then welded in the small gussets in the center first. By the time we got to welding in the large gussets the entire piece was good and warm
Ben_Modified
Ben_Modified Reader
12/8/16 4:45 p.m.
progress
<img src="20161208_104115_resized" />
petegossett
12/8/16 7:44 p.m.
In reply to Ben_Modified:
Wow, amazing work, as always!
Ben_Modified
Ben_Modified Reader
12/12/16 6:06 p.m.
petegossett wrote: In reply to Ben_Modified: Wow, amazing work, as always!
Thank You!
I pulled an old project apart today to get to this
<img src="20161212_170317" />
It was powering an old reverse trike. The wiring harness is already lengthened and it has a geo metro radiator and built in electric fan
<img src="20161212_170401" />
It is only a 600cc but it will do for now. The plan is to mount the engine on a cradle that can be unbolted from the tube chassis so that a larger engine later will be easy. The bike has 100 hp @ 12,000 rpm and 46 tq @ 10,500. It is free at this point and complete so it only makes sense to use it for now. The diff is nearly completely mounted, photos soon. Also found the perfect set of tires, 165/50-14. Same overall diameter as the oem 12's and V rated for $48 each! Achilles Economist ATK r
My Other Projects
jimbob_racing
jimbob_racing Dork
12/12/16 6:14 p.m.
Wow. Terrific project!
Ben_Modified
Ben_Modified Reader
12/13/16 6:23 p.m.
jimbob_racing wrote: Wow. Terrific project!
Thanks!
Today I finished up the rear subframe mods and diff mounts. I used a couple of leaf spring bushings and thick wall tubing to make up a front diff mount
<img src="20161213_125751_resized_1" /> <img src="20161213_125842_resized_1" />
View from the underside
<img src="20161213_140957_resized_1" />
Had to trim the retaining plates for the large carrier mounts
<img src="20161213_135446_resized_1" />
Complete
<img src="20161213_141029_resized_1" /> <img src="20161213_140937_resized_1" />
View from the front
<img src="20161213_141013_resized_1" />
I added a collar and some extra plating to the carrier mounting bolts along with making the (new) bolts removable. The collars will also serve as a point to tie in tubing.
<img src="20161213_133830_resized_1" />
My Project Videos
Ben_Modified
Ben_Modified Reader
12/13/16 6:49 p.m.
Also, started on the frame. Both rocker panels are completely rotten and as the fenders are not removable and are rotten on the bottom, I am using a section of 14 ga 4x4" square tube to replace the entire section. The square tube strongly resembles the shape of the rocker!
<img src="20161213_171038_resized_1" />
Rocker from underneath
<img src="20161213_171055_resized_1" />
Shaping the sq tube
<img src="20161213_171522_resized_1" /> <img src="20161213_163958_resized_1" />
I am going to incorporate a 4" inch body drop while I'm at it.
<img src="20161213_171735_resized_1" /> <img src="20161213_171800_resized_1" />
My Project Videos are here:
Ben_Modified
Ben_Modified Reader
12/15/16 7:26 p.m.
Got some work done on the frame today.
<img src="20161215_154639" />
Ben_Modified
Ben_Modified Reader
12/16/16 2:02 p.m.
Tires came in! Also got a great deal on some new but slightly wider factory style Miata wheels. 14 x 6.
<img src="20161216_135651" />
165/50-14....same overall dimensions as stock Bianchina tires..20 1/2"
Lof8
Lof8 HalfDork
12/16/16 2:17 p.m.
Ben, you build some awesome stuff! Do you ever sell off the completed projects or just have em piled in a shop?
Ben_Modified
Ben_Modified Reader
12/16/16 5:23 p.m.
Lof8 wrote: Ben, you build some awesome stuff! Do you ever sell off the completed projects or just have em piled in a shop?
Thanks, I do sell them from time to time. The V8 Bug Volksrod will be sold when it is done and road tested for a couple months.
iivmezLmHoo6CwBCgn2bx06SR2FvzsXGUQinZbdaeKOl6ORYJBb8pVmcH1e9aD94
