Today was install day! A friend came over to give me a hand with the exhaust, as taking the stock one off and putting the APR one on is kinda a two person job for the rear mufflers. I also threw on the Neuspeed rear swaybar at the same time as getting to it is much easier with the exhaust off.
First you need to remove the wiring harness going to the exhaust valve motors. These were a PITA and I actually dropped the rear mufflers a bit by loosening the 13mm bolts holding the rear hangers onto the car. That way I could see the wiring harness connectors a lot better. Pull out the grey tab, then push it down and pull the connector off.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582318319_apr-exhaust-stock-valves-wiring-harness-off_mmthumb.jpg)
Now take off the 4 13mm bolts holding the small crossmember in place just behind the downpipe. Now loosen the 2 13mm nuts on the exhuast clamp and slide it forward onto the downpipe. This will let the downpipe dangle off the exhaust.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582318473_apr-exhaust-stock-downpipe-drooping_mmthumb.jpg)
Ok, now pop the exhaust off the two hangers in the tunnel and remove the two 13mm bolts holding the rear exhaust hangers onto the chassis and drop the entire exhaust.
Swap the muffler valve motors and rear hangers over to the APR exhaust.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582318534_apr-exhaust-stock-valves-and-hangers-installed_mmthumb.jpg)
You're supposed to be able to access the stock rear swaybar endlinks with them in place but there was no way. You have to hold the inside of them with a Triple square 6 and then turn the nut off. No space for my rachet, so I choose to remove the swaybar with the endlinks on it.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582318612_neuspeed-rear-swaybar-install-stock-end-links_mmthumb.jpg)
The endlinks are held in with a 13mm bolt on either side, then remove the swaybar brackets with a 10 triple square. Rotate the old bar out of the car. Swap over the swaybar bushing brackets and endlinks onto the new Neuspeed bar.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582318683_neuspeed-rear-swaybar-vs-stock_mmthumb.jpg)
Rotate the Neuspeed bar back into place and get the endlinks lined up and put the 13mm bolts back in. This was a bit of a PITA. Tighten all the bolts down and you're done. The Neuspeed bar has two setting but the endlinks really only lined up easily with the inner (or most stiff) setting on the bar, so that's where I set it.
Back onto the APR exhaust install...
Put the rear APR muffler up into place, with the 13mm bolts on loosely.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582318785_apr-exhaust-rear-mufflers_mmthumb.jpg)
Put the APR midpipe on making sure you've got the clamps in place and set the stock hangers in place. Look at that Neuspeed rear swaybar, mmmm, delicious!
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582318823_apr-exhaust-mid-pipe_mmthumb.jpg)
Put all the clamps on and tighten them down from front to rear. Reinstall the cross brace.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582318884_apr-exhaust-entireity_mmthumb.jpg)
We spent a large amount of time getting the tips as symmetrically placed as we could, looks good!
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582318918_apr-exhaust-installed_mmthumb.jpg)
And I think it sounds great! Not too loud, doesn't drone at all.
Last thing is a gas pedal spacer. Heel/toeing the car is kinda difficult as the gas pedal is just a bit low. WCT makes this cool spacer that drops right in, takes 2-3 minutes to install.
Here's the spacer.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582319055_wct-pedal-spacer_mmthumb.jpg)
Here's the bolt you remove
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582322158_wct-pedal-spacer-install-1_mmthumb.jpg)
Put the spacer in place
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582322174_wct-pedal-spacer-install-2_mmthumb.jpg)
Put the bolt back in and you're done. I can't believe the amount of difference this made! So much easier to heel toe now...
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/02/21/1582322203_wct-pedal-spacer-install-3_mmthumb.jpg)
