3 4 5 6
aussiesmg
aussiesmg MegaDork
5/26/14 10:57 p.m.
For a 1984 unibody it is surprisingly rigid, jacked one side of the rear today and 3 wheels left the ground.
Spent the afternoon dialing in the: shocks, rear control arms and panhard, found some real gains
We did locate a clunk in the rear, seems the pinion in the axle is moving up and down, that is not good. Rebuilding the center with 3.63 gears (Mazda 626), new clutches and bearings.
aussiesmg
aussiesmg MegaDork
5/29/14 9:50 p.m.
Sorting out the gauges and found the electric fan to be locked up, swapping in another as we speak.
aussiesmg
aussiesmg MegaDork
5/30/14 10:37 p.m.
aussiesmg
aussiesmg MegaDork
6/12/14 1:04 p.m.
Rebuilding the rear center section, no more pinion slop, much more LSD, grunt grunt.
Going to a 3.63 ration ring and pinion, from an early RWD 626 no less. The OEM 3.9 center will be rebuilt as a spare.
Thanks go to Chuck McMillion for this one.
aussiesmg
aussiesmg MegaDork
6/12/14 11:12 p.m.
Can you say tight
aussiesmg
aussiesmg MegaDork
6/15/14 4:49 p.m.
and in it goes
aussiesmg
aussiesmg MegaDork
6/16/14 8:32 p.m.
Drove it home, the diff is a huge improvement, night and day, especially as it no longer clunks during every gear change.
BTW the drive was sans exhaust as one of the clamps broke, oh crap I am in love, I need electric cut outs on this thing.
aussiesmg
aussiesmg MegaDork
6/30/14 10:39 p.m.
An assortment of minor fixes have made some serious gains in ride and handling as well as drivability. They include, several poorly attached wires and fittings, changing the shock adjustments, doing an oil change, sorting the suspension and tightening some bolts that worked loose, installing a better breathing air filter, reinstalling the exhaust (not sure that made it better), fitting a shift boot.
All of these and a few other improvements have made the car better and better, small steps making a big impact.
Soon it is paint, I have chosen a color
aussiesmg
aussiesmg MegaDork
7/22/14 7:06 p.m.
We had a small disaster, ripped the custom upper control arms out of the car so...
Out with the broken parts
aussiesmg
aussiesmg MegaDork
7/22/14 7:09 p.m.
and in with some new
removing some rust along the way, rebuilding the factory crossmember with steel box tube and strengthening up the whole area so it doesn't part company again
aussiesmg
aussiesmg MegaDork
7/27/14 4:06 p.m.
Framing started
aussiesmg
aussiesmg MegaDork
8/2/14 11:01 p.m.
Progress
Dusterbd13
Dusterbd13 Dork
8/3/14 4:25 p.m.
Is he welding without a shirt? That hurts just thinking about it.
grafmiata
grafmiata SuperDork
8/3/14 5:00 p.m.
Dusterbd13 wrote: Is he welding without a shirt? That hurts just thinking about it.
He's a punk-ass 21 year-old... He will learn in time.
aussiesmg
aussiesmg MegaDork
8/4/14 3:00 p.m.
A box of NOS may have turned up at the Compound this week...
aussiesmg
aussiesmg MegaDork
8/5/14 10:18 p.m.
Bit by bit
aussiesmg
aussiesmg MegaDork
8/17/14 3:28 p.m.
Steady progress, still repairing the inner fender well rust areas, fuel tank out, cleaned and new sender installed, re routed fuel lines, started to install Naws.
aussiesmg
aussiesmg MegaDork
8/22/14 9:17 p.m.
Rust repair, damn, that was worse than it appeared to be.
chandlerGTi
chandlerGTi SuperDork
8/23/14 6:35 a.m.
I still can't believe that it bent the unibody brace that way. Awesome display of power. It's going to hook up so much better now!
aussiesmg
aussiesmg MegaDork
8/25/14 8:28 p.m.
Oops, I guess we need a shortblock, one step forward and two steps back
http://grassrootsmotorsports.com/forum/grm/aw-crap-thats-not-right-sbf-content/90117/page1/
aussiesmg
aussiesmg MegaDork
8/25/14 9:45 p.m.
Replacement located, road trip this weekend
aussiesmg
aussiesmg MegaDork
8/25/14 10:29 p.m.
Woah, two rods broken and crank might be snapped as well
aussiesmg
aussiesmg MegaDork
8/25/14 11:31 p.m.
Nope not good at all
aussiesmg
aussiesmg MegaDork
8/25/14 11:40 p.m.
The replacement
Dusterbd13
Dusterbd13 Dork
8/26/14 5:47 a.m.
I got nothing on that. Damn good show! Can we get the full details on what happened?
3 4 5 6
nPPAd9pS0SWk1kVwhtHhQaxeSxdu1meopGzyyBIwVZ4cjxX5Xe8jlEtTb4Qe9pIf
