AngryCorvair
AngryCorvair MegaDork
3/16/20 3:05 p.m.
In reply to SkinnyG :
Another entertaining and informative video. Thanks for shooting and narrating that!
SkinnyG
SkinnyG UltraDork
3/16/20 9:19 p.m.
Thanks man!
-8 and -6 fuel line arrived.
FPR never arrived, was lost in shipping and I got a refund. Will have to re-order.
GoLucky
GoLucky Reader
3/16/20 10:28 p.m.
Did you use MiG wire as TIG filler?
SkinnyG
SkinnyG UltraDork
3/16/20 10:43 p.m.
I had never welded stainless before, so this was a new experience.
I started with 1/16" filler, but switched to 0.030" MIG wire to weld.  I found 1/16" was too much for the size of the puddle.
GoLucky
GoLucky Reader
3/17/20 11:43 a.m.
Pretty cool.
SkinnyG (Forum Supporter)
SkinnyG (Forum Supporter) UltraDork
5/16/20 7:19 p.m.
Well, the covid teaching really got in the way of anything on the '61.
As I started digging my rut for online teaching and helping kids while working from home, I needed a stress reduction plan - I was not able to maintain the level of video production I was doing, all the while trying to come up with an entire shop course for shop kids with no shop.  I was stressing out, and starting to unravel.
I did end up finding a balance, where kids were working on projects, and I could step back and "escape" in-between emails from students, and demo videos to help them out.
And, since rust patch panels were starting to arrive for the '61, I needed a new sheet metal brake.
Oh, I built a 36" one earlier, to make rocker panels for the V8 Firefly, but it really was a piece of crap.
This one is certainly an upgrade, but took a whole lot longer to produce:
caseyjones (Forum Supporter)
caseyjones (Forum Supporter) New Reader
5/16/20 10:35 p.m.
Amazing...
Ben_Modified
Ben_Modified HalfDork
5/17/20 2:30 a.m.
Wow, very nice!
Wow! Very nice!
Edit: Great minds think alike. Seriously, that's a beaut.
5/25/20 6:29 p.m.
School has been a horrific amount of work, and things sat still for a couple months.
Then I was able to settle in, and get back at it.
Figuring how to mount the A/C Condenser (tacked in), and I am able to slip the transmission cooler between the Condenser and the Intercooler.  Wrecked my big 1-3/8" step drill.  Well, it was wrecked to begin with, as it appears they made it out of non-carbon steel.  Ended up clamping the brackets down in the mill and just using a hole saw.  Did I mention I made my own dimple dies?
Crackers
Crackers SuperDork
5/26/20 12:05 p.m.
SkinnyG said:
I was not happy with those motor mounts.  I am very happy with these motor mounts.
Driver's side welded and installed, passenger side ready to be tacked.
So I'm still trying to catch up on this one, but I had to pause to comment on this. I basically came up with the exact same solution last week for a project where the strut tower is tied into the cross member except my lower mount at the cross member is bolted so I can drop the cross member with the engine in place to remove the pan without pulling the engine.
5/26/20 7:39 p.m.
Oil cooler mounted. And modified the high pressure AC fitting to be 2" longer, and re-located the port to make it accessible, but I need to find the correct tap to put it back together.  I think it's 6mmx0.75....
5/27/20 11:43 p.m.
3-bar "truck-style" MAP sensor, plus threaded IAT sensor, arrived from EFI Source. Yay!
Nothing happened in the shop, though, as I was prepping next week's assignments for the cherubs.  I don't know about your own kids, but I'm getting about 5% to 10% return from my students at this point.  I'm riding my own kids like rented mules.
Mezzanine
Mezzanine Dork
5/28/20 1:15 p.m.
I've heard the return rate is pretty low in our district too. And same here: I take time off work every day to flog my daughter through her math and other school work, but I feel like it's a losing battle right now.
Love the brake; that thing is serious business.
5/28/20 10:06 p.m.
Lengthened the cold side of the evaporator connection today.
Also bought some -6 fittings for the oil coolers and power steering lines.
5/30/20 6:53 p.m.
And fitted as here:
The lengthened 2" Condenser outlet got shortened 1/4":
I also tried my first foray into Silicone Bronze Welding with TIG, putting -6 JIC fittings (same angle as AN) on the power steering cooler. Seemed surprisingly easy.
The 3-BAR "Truck" MAP sensor is part #12623671 from EFI-Source.  Not sure if they had it custom made, or if it's an OEM fitment elsewhere, but I figured I'd put the number up so I can find it again when I need it.
5/31/20 8:55 p.m.
I cut off the end of the PS Pump line, and Silicon-Bronze-Welded -6AN to the end. Also installed the Fox-Mustang-Rack -6AN fitting adapters (Unisteer #8026070):
Added Hydroboost -6AN adapters (Earls #961955ERL and #961956ERL) to the Hydroboost unit:
I was also a little concerned about the PS reservoir return being so close to the exhaust manifold, so I cut it out, plugged the hole (what my finger points to), and Silicon-Bronze-Welded it to the front side with another -6AN fitting (shown here completed):
My LQ4 engine is from an Express 3500 van, but did not come with the remote reservoir, and just buying a reservoir was cheaper.  I did have to do a lot of re-shaping to the bracket to make an acceptable fit.  At the time, I wasn't sure if I was going to do the turbo crossover in front of the engine or not, and the placement of the reservoir was a concern.  I ended up not, and it is what it is.
Front view, with radiator, AC condenser, trans cooler, intercooler, and (not shown) PS cooler under the AC and trans cooler:
SkinnyG (Forum Supporter) UberDork
6/3/20 7:13 p.m.
I had Princess Auto make up the hydraulic lines.  Was half almost a third the price of doing it all in fancy braided line. I Bronze-Welded -6AN fittings to the return at the pump, and I Bronze-Welded a -6AN fitting to the shortened return barb at the Hydroboost so I can run hydraulic lines for return too, for a more aestheticly pleasing spaghetti-collection of hoses. I will be getting the HB return hose shortened 2".
Lines to the P/S cooler under the rad:
6/8/20 11:37 p.m.
I had one hydroboost line shortened 2". Rearranged some of the other lines to fit better.
I dug up the factory LS thermostatic oil-cooler adapter, disassembled the unit, dug out the original hardline (sheared by the wreckers who pulled it), drilled and tapped 1/2" NPT for -10AN (need to pick up another fitting).  I'll use the oil cooler I didn't use on the V8 Firefly.
IN and OUT are on the left; threaded end up top is the plug to hold the thermostatic valve
Also added an IAT bung as well as a Methanol Injection bung.
Also, since I am running -8AN fuel line to the fuel rail, I am going to use the remote oil filter mount from the V8 Firefly oil cooler kit as a fuel filter holder, with a WIX 33382.
6/9/20 10:10 a.m.
The more I look at the guts of the oil cooler adapter, the less I think it's thermostatic, and more a pressure relief valve if the cooler is plugged or the oil is jello.
Crackers
Crackers SuperDork
6/9/20 11:24 a.m.
Jello makes for a terrible lubricant.
ClemSparks
ClemSparks UltimaDork
6/11/20 2:20 p.m.
Add CoolWhip...should help a bit.
6/14/20 7:20 p.m.
Ran into a snag - because I started drilling and threading for 3/8"NPT fittings and then changed my mind and went 1/2"NPT so I could run -10AN hose for the oil cooler, the fittings were now too close together to assemble.  This would not do.
So I ran a plug in through one, and drilled (at an angle) and tapped the end of the oil cooler block to relocate the fitting.
Also ported the mother-loving mess inside to make it flow decent.
6/15/20 2:43 p.m.
Fabricated an oil sender adapter so I could feed the turbo.
The LS uses a 16mm x 1.5 thread and a sealing washer. I turned half of some 1" steel down to 5/8" and threaded it, then bored the other end and threaded it as well, then drilled and tapped 1/8"NPT at an angle such that I can easily thread the adapter and sensor into the block, then thread an 1/8"NPT 45° in there to better reach the turbo feed.
Image once the paint dries.
Also put the rad in to measure fan clearance.  I have just under 4" to the stub of where the fan clutch was, so I'm going to need a thin electric.  But, if I can find one, I should be able to squeeze the engine oil cooler behind that.
If I can't find one I like, I could probably relocate the trans cooler, run a thinner rad-spacer-back-inator and gain maybe another 1/2" of fan room.
6/15/20 7:25 p.m.
Also fabricated a bracket for the AC Drier.  This will nestle neatly in the crook of the turbo compressor piping, right beside the radiator.  Made out of some 2-1/2" exhaust pipe and some 1/2" square tube.
bwqrnIUw06boh4UUxjpMXx9qF6a4tlz3zjTN0ihUmLdz2ftLfFJm9koSwl3GnpjW
