Finally got around to doing some minor things;
Replaced the broken arm rest cubby hinge. I find I use it to help get my fat butt in and out of the car, so it didn't stand a chance.
Replaced the broken cup holder. Not sure how long it will last, but it will be nice to have a place to set a cup of coffee when I'm headed to the track, etc.
Inner shift lever boot was missing. So i pocked one up from Only944 since the foam insulation is half-missing and the heat coming up is noticeable. Whe it was smoking, it would come up through the shifter area. That was disconcerting.
New rear hatch lock grommet. It wasn't causing a leak, but I was working back there anyway.
New hatch pin bushings from Only944.com. So much quieter now! Considering how noisy the exhaust is, the fact that you can hear the hatch rattling is a good indication of how annoying that must be on a stock car!
Installed the rear wiper motor and arm. It rains here a lot and that big back window is nearly impossible to see out of when it is wet and quite frankly it's not a race car, it's a GT car for me, so a little comfort is a good thing.
Speaking of comfort, I swapped the steering wheel for a D-shaped wheel. The stock wheel was starting to lose the cover, was making it difficult to get in and out of the car and the airbags and horn weren't working anyway.
After the swap, I drove it to Flying Pie to get pizza and it feels pretty good, once you get used to the thicker grip and shape. I think I'm going to space it back further though since I feel like my arms are a bit further extended than I'd like. I'll try to find the proper multifunction switch plate so I can get my horn back again.
I did sell a bunch of stuff on eBay so I could order up a S2 transaxle since the gearing is better suited to my use of the car.
I need to refresh the internals, so that will be an adventure and I'm looking to it! I'm looking into doing an Audi V8 limited slip swap while I'm at it, we'll see if I can source one that isn't borked or too expensive. There's also the possibility for a 5th gear swap and adding a strengthening plate and a short shifter kit. If I can get it all together, hopefully it will be a pretty kick butt solution for the car.
Stay tuned!
