Shavarsh
Shavarsh Dork
12/9/24 1:32 p.m.
The shocks feel great. We competed in an SCCA road rally this weekend, and the "float" and bouncing in the front end are greatly reduced. I'm sure some more shock tuning will continue to improve things. Right now I am running compression:10 rebound:14.
That being said, the front certainly still needs a sway bar. The shocks feel much better, but aren't a replacement for the missing sway bar. I'm debating using a mustang ii, TCI mustang ii, or splined bar for the front. The mustang ii option shown on a previous page is certainly the easiest, but weighs a ton.
Shavarsh
Shavarsh Dork
12/17/24 2:41 p.m.
Here are a couple pictures from a wild weekend camping near the Salton Sea.
Bombay drive in:
Slab City:
The car ran great, and we were able to improve the timing table and acceleration enrichment tuning while bombing through the canyons. These tires are a night and day difference from the old all seasons. A rough estimation of mpg came out to 16.5. Could be worse!
Shavarsh
Shavarsh Dork
1/21/25 1:25 p.m.
So, there is a track day this weekend. The proper response? Start a project...
I've been collecting front sway bars in the hopes that I can find a Goldilocks option. The latest is a hollow 26mm bar from the front of a C4 Corvette:
Of course, it came off of a Corvette, so it has some weirdness:
The bushings are easily pressed out though. We can figure out end links once in place. Here are rough dimensions for those looking for them:
If we mock up the bar in place it wants to live where the power steering cooler is. We can find a home for that later.
The bushings that came with the bar are old and worn out. The issue here is that they don't work very well to hold the mounting brackets straight for welding. So instead tack the upper brackets to a square tube to hold everything straight.
The observant among us may notice the brake lines are gone in the last picture. They were in the way... 4 days to go.
Shavarsh
Shavarsh Dork
1/21/25 2:48 p.m.
After adding some support and welding we have frame mounts:
I've been spending too much time with the TIG welder. My MIG skills are rusty, nothing a lick of paint can't take care of:
Dusterbd13
Dusterbd13 MegaDork
1/21/25 3:33 p.m.
So, the thin vertical strips are just compression reinforcement for the horizontal mount plate, right?
Did you weld both sides of the verticals?
Shavarsh
Shavarsh Dork
1/21/25 3:51 p.m.
Duster, yes those are just reinforcement, and they are only welded on 1 side. The whole mount is made of 14ga, which is pretty light for the application. It would be stronger with a plate bridging all the verticals and enclosing the mount. However with the current time crunch this solution should be good enough. Thankfully, if this isn't strong enough it'll be easy to cut off and replace.
1/21/25 3:59 p.m.
In reply to Shavarsh :
When I adapted C4 front bar to rear of MonZora, I pushed those end bushings out and welded some sleeves in the holes, and used end links from C5 rear. Eventually I cut the end links, rotated the ends to neutral positions as-installed, then sleeved and welded them.
scroll down to 4/3/2024
Shavarsh
Shavarsh Dork
1/22/25 3:44 p.m.
That's the plan Angry, glad to hear it's been successfully implemented. Here is my first attempt from a couple weeks ago:
I've got some ideas to lower the profile. The main concern for me is footprint.
Shavarsh
Shavarsh Dork
1/22/25 3:47 p.m.
So, once the sway bar was mounted, I needed to take care of the power steering cooler. While playing around I found that if one of the mounting tabs were angled back it might clear everything in it's current mounting position. No time was wasted:
I'll admit it's starting to look a bit messy under here at this point. Also the clearances are tight, but they are there. I am pleased enough with this solution to move on. 3 days to go.
Shavarsh
Shavarsh Dork
1/27/25 4:15 p.m.
Alright, a bit of recap. Now that the bar was mounted we needed links. A bit of machining and welding later:
The spacer portion was a bit too long so 2 solutions: precision grinding, and trimmed bolt heads.
Then the links were finished:
wawazat
wawazat SuperDork
1/27/25 4:56 p.m.
Handheld precision grinding is a method even us ham-fisted types can use! laugh
Dusterbd13
Dusterbd13 MegaDork
1/27/25 5:49 p.m.
From an engineering perspective, why wouldn't you have welded a stud in there? Instead of Shaving down the bolt head? Would have give you more clearance in my mind, but there's got to be a reason you didn't do it
Shavarsh
Shavarsh Dork
1/27/25 6:10 p.m.
Duster, that's a great idea, and is likely a stronger setup. This was the first solution that came to mind and I was time limited. However, I do think the bolt heads at <.180" tall are lower profile than the stud and nut combo. Also turning down the OD of the bolt head allowed for greater articulation than a nut (also why a button head screw was used instead of socket cap or hex).
Dusterbd13
Dusterbd13 MegaDork
1/28/25 6:02 a.m.
Ahhh!
I was thi king somewhere else on the clearance issue. Like the backside of the blade of the sway bar to the spring....
Shavarsh
Shavarsh Dork
1/28/25 3:50 p.m.
Ah yes, the clearance issue is about the knuckle hitting the bolt heads at full lock during suspension droop. Last modification before the track day was front brake lines. The existing hard lines have been adapted quite a few times, and are a maze of metric and American converters and lines. I decided to go full soft line. So convert to -3an at the master, and run the lines all the way to the caliper:
This is the only decent picture I have, but the new lines have cleaned things up nicely. After a thorough bleed with the Motive we had a decent pedal again.
Shavarsh
Shavarsh Dork
1/30/25 3:08 p.m.
Finally, late night before the track day, we got a test drive around the block. Then back up at 3am to head to the track.
The track day was epic, here are a couple more pictures:
The car exhibited understeer at the limit, which is totally new behavior, showing the sway bar is doing its job. The brakes were generally up to the task but every 3-4 laps the pedal would start to get long until a few cool down corners. We also found the limits of the fuel cell setup. The car will start to starve in the corners, but only once the gauge is reading empty. I am extremely pleased about this. The forces experienced during these track sessions are the highest the car has seen, and the oil pan baffles, and fuel pump basket worked flawlessly. With the 200tw tires and other recent improvements to the car it felt genuinely fast. At night we camped in the paddock, and the wife drove the next day.
After another day wringing out the car, we packed it back up and drove home without issue.
Piguin
Piguin Reader
1/30/25 6:38 p.m.
Glad to see that the modifications worked.
Car is looking gooooooood
Shavarsh
Shavarsh Dork
2/14/25 12:37 p.m.
Let's see if we can make the filler neck a bit more user friendly.
Shavarsh
Shavarsh Dork
2/18/25 12:10 p.m.
Maybe better? We will know after welding and installing.
akylekoz
akylekoz UberDork
2/19/25 6:47 a.m.
I love a good Pinto Bean, keep cooking on this.
Shavarsh
Shavarsh Dork
2/20/25 8:54 a.m.
After a bit of time welding we have a filler neck again:
It's not my best work, but I had to weld quickly to keep the purge gas to a minimum. I also laser cut this insert to aim the nozzle. A couple of small tacks hold it in place.
Finally back in place:
I can't explain how stoked I was at the gas station. I can hold the pump at full throttle without kicking off early. When it does kick off, the tank is full and there is no overflowing. Given, this is a sample size of 1, and my local pump is fairly slow. Next I'll find a faster pump to try. Time to burn some dinos.
Shavarsh
Shavarsh Dork
3/18/25 3:06 p.m.
The filler neck continues to make me happy. No issues yet.
I was waiting to change the rear sway bar until I could attend a local autocross with the front bar installed to see if understeer would be less of an issue than at the track. Understeer was still an issue, so I picked up a Flyin Miata rear bar for an NB. I got a great deal from a fellow GRMr, and it was a pleasure to meet up. Unfortunately, it doesn't fit. The kick out between the bushings interferes with my fuel cell cage. On the hunt for a bar without that kink currently.
Picture from autocross (Thanks Ken Suzuki! @slow_car_slow)
Shavarsh
Shavarsh Dork
3/24/25 12:11 p.m.
Rear bars in order: stock, Flyin Miata, Whiteline
Next the Whiteline installed, you can see where the clearance is tight to the fuel cell cage. Too tight for the FM bar:
I also flipped the links, this put both joints in better positions.
Shavarsh
Shavarsh Dork
4/2/25 1:53 p.m.
Alright, we have a leak at the water neck again... time to try a new housing. I've decided to give this reproduction thermostat housing a shot. It is lightweight aluminum, and the reviews caution not to over tighten the bolts or it will snap the flange. This is because it has a raised boss around the water ports that should encourage sealing. Right now I am running it with a dry felpro gasket, no sealer. So far, so good.
Shavarsh
Shavarsh Dork
4/9/25 4:03 p.m.
In preparation for the Del Mar GoodGuys autocross, I decided to finish converting all of the brake lines on the car to stainless braided lines. With the front already complete, focus shifted to the rear.
New parts (new master cylinder not shown):
The conversion to full soft lines was not necessary, but I wanted the master connections to be soft lines, and to upgrade the modified junkyard miata rear hoses. When factoring in the needed adapters to keep a section of hard line running between the soft lines, I decided to replace everything.
After replacing the front bleeders (which were stuck) the brakes were bled and test driven. There was a slight improvement in pedal feel, but not as much as I had hoped. However, the master being connected with soft lines is very useful for a couple of reasons. First, the drivers side exhaust manifold is captured by the extended mount for the brakes. This system was very time intensive to remove without being able to get the master out of the way. Second, having the master easily removable has made troubleshooting the brake linkage and booster far easier.
The only things I haven't replaced at this point are the calipers and booster. I'm also wondering if my cheap ceramic pads could be part of the issue. If you have ideas that might help the brake feel, I am open to suggestions.
OKNtoLjP36tUMlt5wivXoDnyM2uTRFiRX7f16WNhQhaXA5cHzCjM7onucHQT9jVx
