Jumper K. Balls
Jumper K. Balls UberDork
3/22/16 1:08 p.m.
Yes I know calling a 31 year old car modern is laughable, but in my defense my last daily was 53 years old and before that 45.
My good buddy Ransom bought this car a year and a half ago. He brought it to me and I rebuilt the shift linkage, complete suspension refresh, redid the back half of the wiring harness and a few other things. His GF didn't care for it, he had too many other projects and too little space and right at the time when the Falcon decided it needed some in depth work, he made me an offer I couldn't refuse.
I took the train to Portland, we grabbed lunch and a few beers and got to his house where it had been sitting for a month or more
It was sidelined by a broken clutch pedal bracket. A few hours of wrenching and hanging out with one of my favorite people that I rarely get to see I replaced the offending part
And I drove it 120 miles home that night. Despite non functioning heat it was the most comfortable I have been in a car in a while. I really like old BMW's. They just feel "right"
The next day was cleaning it out. Ransom apologized profusely for its state never having tried to clean it. Under the seats was a treasure trove of french fries and bottle rockets. The fireworks were all duds (yes I tried)
The drivers seat was tan, whilst the rest of the interior was black. Some vinyl and leather "dye" fixed that
Significantly cleaner interior. More than good enough for now
The antenna was broken. Normally I wouldn't care but it was the source of a major trunk leak and therefore a major bad odor. I knew I had had a new power antenna in the garage for over a decade. Managed to find it and it is identical to the broken unit. Easy fix!
The car has the euro headlights and grilles. The reflectors are in pretty bad shape and will need to be sorted. Light output is miserable
Sadly the holders are very different from a standard 7" H4. No luck swapping them out for the Hellas I have laying around.
I spent a few hours sorting out the window switched and got all the glass moving up and down. Then the passenger rear made a clunk and stopped. The sash had pulled away from the glass.
Someone had tried to fix it with superglue at some point. There is a proper fix for this. Window setting tape. It is a soft, malleable and tacky rubber strip. It is what they were put together with at the factory.
Comes in different thicknesses.
Cut strips, wrap it around the glass, lightly lube the outside with window cleaner and press the sash back in place. Once the glass cleaner has dried it isn't coming apart without more force than a regulator can exert.
Bought the grimoire
In the trunk was a few spares
Holy cow Ransom. That is some stash! Indicative of needed maintenance.
So here it is in daily mode
The skirts are coming off. I realize they are rare M-tech pieces, but I just don't like them. I will be selling them off to some other E28 enthusiast to fund a euro bumper purchase. I have to deal with that Hapsburg jaw
Other bits have been acquired to deal with the worst of the bodywork
So that is that. Looks like I will be doing the oil pan and timing cover gaskets soon. Upgrades will happen in time as well.
RossD
RossD UltimaDork
3/22/16 1:12 p.m.
Love it.
Huckleberry
Huckleberry MegaDork
3/22/16 1:18 p.m.
I had a 535is 5sp... wonderful car. A real pleasure to travel long distances at high velocities. Great in the snow. Huge glass canopy to see out of - just "right" like you said.
T-Boned to death at 265k miles...
Slippery
Slippery Dork
3/22/16 1:33 p.m.
Subscribed. I am not a fan of the sideskirts either.
Woody
Woody MegaDork
3/22/16 1:36 p.m.
Very nice car!
Try removing the headlights, pour in some 90% isopropyl alcohol and swish it around in there. Then pour it out and let them dry out. It really brightened up the reflectors on my 911.
Slippery
Slippery Dork
3/22/16 1:38 p.m.
Here is some inspiration.
This
plus euro bumpers
chandlerGTi
chandlerGTi UberDork
3/22/16 5:44 p.m.
I've had four e28s, one M5 for about 6 hours (lol) but my favorite was a 450k mile 528e. That thing could not be killed.
oldtin
oldtin PowerDork
3/22/16 6:43 p.m.
My favorite car I've owned besides the Ac 911
dropstep
dropstep Dork
3/22/16 7:51 p.m.
Thats modern too me! I think these and the volvos of that era look really good.
Jumper K. Balls
3/22/16 8:13 p.m.
Looks a little less portly now. Although the air dam and bumper are even more out of balance.
Jumper K. Balls
3/28/16 10:10 a.m.
Yesterday went from "I'll put the car on the lift and see where that oil leak is coming from" to "I guess I will pull the radiator and swap out the water pump, hoses, fan clutch and a few other things since I am in here"
I didn't realize it was a holiday so getting oil and coolant became a slight issue since the Napa my shop shares a parking lot with was closed.
That cooling system is the most difficult to bleed thing I have worked with in a while. I wound up having to drill a small hole in the thermostat to get it to function.
The new fan clutch certainly sounds different. I guess the old one was indeed bad.
Acme Lab Rat
Acme Lab Rat Reader
3/28/16 10:38 a.m.
Best car I ever owned was my '87 535i. Smooth as butter engine, wonderfully comfortable car, great road manners. Yours needs more shadowline trim!
stuart in mn
stuart in mn UltimaDork
3/28/16 10:57 a.m.
I assume you know about the mye28.com forum, it's pretty much the epicenter of e28 knowledge.
Your heater problem (if you haven't fixed it already) is most likely the heater control valve on the firewall. There are repair kits available for it that are a lot cheaper than replacing the whole thing but quality is variable, some kits work well and others fail quickly.
The Mtech side skirts are part of the M535i body kit, they are certainly worth some $$. I agree that they don't look that great by themselves, but are good with the entire setup (my summer daily driver is an M535i.)
Jumper K. Balls
3/28/16 11:09 a.m.
The PO replaced the heater control mono valve and I did as well. Still no heat above idle. The core has a slight leak (coolant smell in the cabin) so I plan on swapping that out in the next few days.
I have read that the mono valve has to be assembled with the sleeve in a particular orientation to work correctly. That doesn't make a lot of sense to me from my initial inspection of how it works but I will pop it open and double check. I reassembled it the way it came apart.
And I am not shadowlining it. I dig the chrome. I would rather highlight its late 70's/early 80's styling than modernize it.
Sadly all I have been able to find are OE painted and composite reproduction euro bumpers. Chrome would be my preference there too.
stuart in mn
3/28/16 1:39 p.m.
Euro bumpers show up every so often for sale, but since these cars are 30 years old the pickings have gotten pretty thin and prices have gone up. A front bumper in fair shape just sold for $300 on mye28.
Jumper K. Balls
3/28/16 2:49 p.m.
I have been holding out for originals but will probably end up ordering these
http://www.classiceuroparts.com/product/bmw-e28-euro-front-bumper/
Marjorie Suddard
3/28/16 3:09 p.m.
Love it. I've been daily driving mine for 8 years. As others have said, it cannot be killed, and no car better walks the knife edge between “modern” and “classic.” Here it is passing Tom's Trooper:
RossD
RossD UltimaDork
3/28/16 3:11 p.m.
In reply to Marjorie Suddard:
I see what you did there.
Marjorie Suddard
3/28/16 3:16 p.m.
In reply to RossD:
Shhh, you weren't supposed to see that. Only, uh, shot I had handy.
brad131a4
brad131a4 Reader
3/28/16 3:41 p.m.
Wow Marjorie that's looking a little like anger management is in order.
driver109x
driver109x HalfDork
3/28/16 3:50 p.m.
I have the exact same color '87 535is 5spd...except for the side skirt and euro headlights. But mine has completely peeled out it's clear coat on the hood, half on the roof and rear trunk and has 340xxx miles on it.
Dusterbd13
Dusterbd13 PowerDork
3/28/16 4:27 p.m.
If you can get the style of bumper you want cheap enough in not chrome, wrap it in Chrome vinyl. Looks pretty good from the few I've seen.
Jumper K. Balls
4/16/16 12:36 a.m.
Scored some H&R sports off Craigslist today!
Jumper K. Balls
4/23/16 10:31 p.m.
Scope creep. I have a real problem with it. Ransom told me that a past inspection had a recommendation of replacing the drivers front caliper. After a few weeks I noticed the car did indeed veer left under hard braking. Cool. Easy fix right?
Not even sure how or if I made the decision but the next thing I know I have a pile of parts on the shelf.
Got some late 90's 530i calipers and carriers from the junkyard, rebuild kits for them, new rotors and pads for all four corners. These rotors are 20mm larger than stock. Here is the thing. I had zero complaints about the brakes. Actually I thought they were awesome. Why did I eschew the $40 fix and spend $250 on a brake upgrade I didn't even think I needed?
Anyway. It all bolted straight on. Easy as can be. The backing plates even look more correct.
Front
And while I was in there it got the H&R sport springs and new strut bearings
Sitting a bit closer to the ground. Ride quality is unaffected. Car feels crisper around the bends but it is still executive class smooth.
Jumper K. Balls
4/24/16 7:33 p.m.
Here it is after 20 miles of suspension settling and with the C pillar sail panels finally installed. Front bumper has been tucked.
I might still get some drop hats to bring the front end down a hair more.
mq1dngenSXDoHPfg8EcXEpXtjl5TUBCSoeKqs1beB1M3PAoCunpGtQ7smWh5U4Ga
