edwardh80
edwardh80 Reader
8/8/16 7:10 p.m.
Picture linky dinky's no worky
Ben_Modified
Ben_Modified Reader
8/8/16 8:17 p.m.
In reply to edwardh80:
sorry, the mandatory switch from picasa to google photos is causing problems for me. i will have to switch to another photo site and try again.
Ben_Modified
Ben_Modified Reader
8/8/16 9:34 p.m.
<img src="20141216_164959" />
Ben_Modified
Ben_Modified Reader
8/8/16 9:57 p.m.
<img src="20160114_174332
I had this vehicle mostly assembled and fitted prior to shipping the body off for sandblasting. The project stalled for a couple of years and now it is back on track. This is a photo prior to sandblasting.
<img src="IMAG0541" />
<img src="20160713_164753" />
While I had it apart, I swapped out the automatic trans for a 5 speed
<img src="20160719_172124" />
<img src="20160720_150040" />
The Build Videos are Here:
Ben_Modified
Ben_Modified Reader
8/10/16 5:59 p.m.
<img src="20160810_172035
Ben_Modified
Ben_Modified Reader
8/13/16 10:09 a.m.
Ben_Modified
Ben_Modified Reader
8/15/16 5:35 p.m.
Modified the Headers to fit the new engine position
<img src="20160811_102057" />
<img src="20160815_150754" />
<img src="20160815_150838" />
<img src="20160815_150850" />
My Build Videos on YouTube
Ben_Modified
Ben_Modified Reader
8/24/16 6:44 p.m.
New driveshaft came in. Fits very well
<img src="20160819_140109" />
Started fitting the driveshaft tunnel made from repurposed vw parts. Had to drill and air hammer off some left overs
<img src="20160823_161531" />
Checking the bench seat for tunnel clearance
<img src="20160823_164337" />
Also cut out a large rust hole and welded in new metal
<img src="20160824_171433" />
<img src="20160824_171706" />
All of the Projects
Ben_Modified
Ben_Modified Reader
8/25/16 10:18 p.m.
Ben_Modified
Ben_Modified Reader
9/6/16 7:55 p.m.
Cut out rusted metal and fabricated and replaced the lower sections of the drivers door both inner and outer
<img src="20160831_150138" />
<img src="20160831_150243" />
Started with a paper template
<img src="20160904_115242" />
Bent up an outer panel and ran it thru the shrinker to give it the same curve as the door.
<img src="20160904_125434" />
Coming together
<img src="20160904_125321" />
This is the remains of the inner door with the new flat sheet metal and a section of rod to shape it around
<img src="20160906_093839" />
Working it around the rod
<img src="20160906_095356" />
<img src="20160906_095850" />
Drove a piece of flat stock into the panel to make it more square like the original
<img src="20160906_101151" />
<img src="20160906_101229" />
New and old
<img src="20160906_101331" />
Inner section tacked in
<img src="20160906_112444" />
Welded in and primed
<img src="20160906_173834" />
Just needs a small skim coat of body filler over the seam and a few drain holes in the bottom
<img src="20160906_173923" />
My other Projects
Ben_Modified
Ben_Modified Reader
9/7/16 9:26 p.m.
The door is done.
<img src="20160907_162707" />
My other Projects
Ben_Modified
Ben_Modified Reader
9/11/16 1:04 p.m.
Rust repairs are done on both doors.
<img src="20160911_100341" />
Prior to removing the doors, I drilled a small hole thru the hinges, the body and the backing plates to make re-assembly and alignment easier. With the help of just a floor jack and a couple of drill bits, I was able to re-install and align the doors by myself. After tightening them down, both doors shut properly on the first try!
<img src="20160911_091623" />
<img src="20160911_120029" />
My other Projects
Ben_Modified
Ben_Modified Reader
9/16/16 4:30 a.m.
Kia_Racer
Kia_Racer SuperDork
9/16/16 6:25 a.m.
Cool
Ben_Modified
Ben_Modified Reader
11/17/16 6:46 a.m.
Currently replacing all the brake lines and the master cylinder
<img src="20161116_154847" />
<img src="20161116_154905" />
My Project Videos
Ben_Modified
Ben_Modified Reader
11/17/16 5:52 p.m.
Added another crossmember to the frame today
<img src="20161117_115715" />
<img src="20161117_164610" />
BenModified.com
Ben_Modified
Ben_Modified Reader
5/19/17 5:48 a.m.
Ben_Modified
Ben_Modified Reader
6/3/17 10:52 a.m.
Progress on the wheel tubs <img src="20170602_170753_resized" /> My Build Vidoes
mblommel
mblommel HalfDork
6/3/17 11:38 a.m.
Your projects give me all sorts of bad ideas.
Thanks for sharing the awesomeness.
Ben_Modified
Ben_Modified Reader
6/5/17 5:26 a.m.
mblommel wrote: Your projects give me all sorts of bad ideas. Thanks for sharing the awesomeness.
After all, the only good ideas are bad ideas!
JGRAHAM
JGRAHAM Reader
6/5/17 6:59 a.m.
I've really enjoyed all of your great builds. Many thanks for bringing us along on the projects!
TeamEvil
TeamEvil Dork
6/5/17 9:08 a.m.
Coming out sweet and doing it the right way !
I had one with a shortened/narrowed Cutlass chassis, it was never right. From the spring rates to the steering, from the belly-button 350/350 to the Detroit Locker rear end. Just a terrible mis-match of parts with a Beetle body on top.
It was kind of ol skool watching what you did with the lower door sheet metal. good doors are about three bucks each around here for the late model Beetles, we mostly cut them up for the good, good German sheetmetal. You need anything late model Beetle related for the build, be sure to get in touch, OK? I probably have what you need and will make a gift of it just to see it being used by someone.
Great start, great thread ! ! !
TC
759NRNG
759NRNG Reader
6/5/17 9:08 a.m.
What's German for 'topolino' ? Another one of your epic freakin' buildz...YEA!!!!
Ben_Modified
Ben_Modified Reader
6/5/17 5:43 p.m.
JGRAHAM wrote: I've really enjoyed all of your great builds. Many thanks for bringing us along on the projects!
Thanks, glad you are enjoying them!
Ben_Modified
Ben_Modified Reader
6/5/17 6:09 p.m.
TeamEvil wrote: Coming out sweet and doing it the right way ! I had one with a shortened/narrowed Cutlass chassis, it was never right. From the spring rates to the steering, from the belly-button 350/350 to the Detroit Locker rear end. Just a terrible mis-match of parts with a Beetle body on top. It was kind of ol skool watching what you did with the lower door sheet metal. good doors are about three bucks each around here for the late model Beetles, we mostly cut them up for the good, good German sheetmetal. You need anything late model Beetle related for the build, be sure to get in touch, OK? I probably have what you need and will make a gift of it just to see it being used by someone. Great start, great thread ! ! ! TC
Great, I appreciate it!
oa4nGuMPwgcoKbEGRLBMqJuVJ4ZSkA9da3p96T40p3kPZ3Kcs30LN8vUaNYGIhKN
