The first hillclimb of the year is scheduled for May 3-4 and I have a bit to do to the car to get ready. I did such a great job starting really really really early at the end of the 2024 season, ordered parts, and then didn’t do everything.
Now I have a month to get ready and a few challenges that I cannot solve myself (like new seat mounts and skid plate mounts)
Just catching you up on the past two weeks.
Engine out to install the replacement 02M transmission. Had a spare on the shelf that is 100% race ready. Swapped over transmission mount, installed Nothing Leaves Stock (NLS) slave cylinder spacer kit, new slave cylinder, and mounted it to the engine.
I would enthusiastically tell you “Done!” but this is something I could have done back in October 2024.
While engine is out, I cleaned up the exhaust V-band clamps and noticed the flange that held on the external waste gate was loose.
This means the turbo wasn’t seeing all the pressure (slower spooling) and the waste gate was not seeing it either (risk of overboosting). I know I didn’t see any overboosting. Replaced the bolt and back in action.
Here is the old hydraulic timing belt tensor setup.
The internet tells me these are prone to failure... I never had an issue... so I installed the Integrated Engineering manual timing belt tensioner. Essentially bringing 1980s Rabbit technology to a 2000-era car.
Installed with new Gates timing belt. The yellow mark on the top of the timing belt on cam sprocket was to help me move it over one tooth to dial in the timing.
Next on the list... new wheel studs. This is the set that I purchased from 034 Motorsports in 2010.
They were getting a little old and I like the design of the new bullet nose 034 Motorsport wheel studs.
I was having a challenge with understanding the usable length of the stud... the rotor face to the end of the threaded stud, so I had to digest the information on the 034 site and come up with my own visual to help me understand what I wanted.
These are their 65mm model... my goal was to get longer (next size up is 75mm); seems I ended up with the same length.
The old style used an allen wrench center for installation and the new requires the double nut. It was a little harder to install on a car that had its control arm and axle hanging.
Installed and looking pretty. I also purchased another set of the Gorilla lug nuts as I would not have had a replacement if I lost one at the track. Cheap insurance.
Wife is out of town this week, dancing girls are too expensive, so going to get a lot accomplished.
