3 4 5
TR7
TR7 Reader
9/30/24 10:48 a.m.
In reply to nlevine :
Why not tracking the 924?
nlevine
nlevine HalfDork
9/30/24 10:26 p.m.
In reply to TR7 :
could track the 924s, and performance should be comparable to an E30 - it's just that the level of work required to make it a reliable-ish track car is beyond what it would take to be a good street car. There are also newer platforms that can do double-duty with fewer compromises and have much higher performance envelopes out-of-the-box.
nlevine
nlevine HalfDork
10/24/24 1:14 p.m.
A nice fall-commute photo opp...
irish44j (Forum Supporter)
10/24/24 6:02 p.m.
My 924S is running like crap these days - i'm in troubleshooting mode and suspect I might have jumped timing by a tooth somehow. I was gonna do timing belts this winter anyhow so not too worried, but didn't drive it as much this summer/fall due to lousy idle and stuff.
Side note: if you are looking for any more of the phone dial wheels, I have a set just sitting in my shed (well, one is my full-size spare in the car). So if you want another set for winter, track, or whatever I'm sure we could make a deal.
nlevine
nlevine HalfDork
10/25/24 6:38 a.m.
In reply to irish44j (Forum Supporter) :
Bummer that the car's not running right. I'm debating dropping the entire drivetrain on mine over the winter to fix various things - I can't fit the whole car into the garage, but I could bring it inside in bits and pieces :-)
Thanks for the wheel offer. I've been half looking for 4 front wheels from a 986 Boxster for a square 17" set-up as performance tire selection for the stock 15s are kind of limited...
10/26/24 12:22 a.m.
IDK if you follow my thread, but I'm running a staggered 911 d90 (16") set with 205s up front and 225s in the rear and I really like the handling/grip balance with that setup (and it looks great IMO). Only downside is no ability to rotate, but I don't drive a ton of miles so not an issue for me.
nlevine
nlevine HalfDork
1/1/25 3:33 p.m.
Haven't started-up the car in a bit, and since we've had rain the last few days that has washed all the salt off the road, I figured it was a good time for a drive to start the year. Happy New Year everybody.
rebelgtp
rebelgtp UberDork
1/1/25 4:48 p.m.
Happy new year! I was hoping to take mine out today but woke up to snow and ice today. At least I got to drive it over the weekend.
rebelgtp
rebelgtp UberDork
1/1/25 4:49 p.m.
I really like the look of your wheels and tire setup I am hoping I might be able to dig up an affordable set of those wheels.
nlevine
nlevine HalfDork
3/29/25 6:20 a.m.
Decided to fix what ails the car.
Took the day off yesterday and got started.
The car has not been starting easily over the winter. I thought it was the battery, but it wasn't charging once I got it running, so the first order of business was to pull the alternator and have it tested. The guy at Autozone said that I was the first person in a year who has come in to test an alternator. Mine is crusty-enough to be original to the car, and it failed, so that went to the top of the shopping list. Can't find any Bosch re-built units anywhere, so I may try a Rock Auto special (I don't know that I want to rebuild my own).
Underside of the engine is totally wet, so along with the other known issues with the car, it looks like an oil pan gasket is in order as well.
Wanted to get an order placed before imported parts prices go up, so I've got the following on order:
  • Water pump/timing belt kit (pump, thermostat, belts, rollers, some oil seals, etc)
  • Oil pan gasket and hardware
  • Torque tube bearings
Thinking about dropping the engine and drivetrain out of the car entirely for better access to all of the components, as the whole back-end needs to come out to pull the torque tube, and I need to lower the subframe any way to get the oil pan out. Should be a fun spring of wrenching. Thoughts?
nlevine
nlevine HalfDork
4/4/25 1:34 p.m.
A journey of a thousand miles begins with a single step, and all that...
Replaced the grommet around the rear lock cylinder. Gotta start somewhere this spring...
rebelgtp
rebelgtp UberDork
4/4/25 1:57 p.m.
It's the little things. The other day I replaced the missing knob for the side mirror controller on my car. If this weekend is decent I am going to try and get out and at the very least wash my car.
nlevine
nlevine HalfDork
4/14/25 7:29 p.m.
Nice, shiny, and new,
but still not charging...
...and it sounds even worse than the one that came out.
Fortunately, the return window is still open. Maybe I will have to hunt down a real Bosch...
orthoxstice
orthoxstice Reader
4/15/25 8:17 a.m.
I took the generator from my '67 Volvo to an old rebuild shop in the area and for $100 had it turned into a factory-fresh Bosch unit completely gone through by a guy that looks like he'd been doing them since Eisenhower was president. Not sure if you have anything like that in the area, but I recommend it!
nlevine
nlevine HalfDork
4/15/25 10:26 a.m.
In reply to orthoxstice :
I'm going to start looking around for a rebuilder in my area, or maybe even look into re-building it myself (could be a good indoor rainy-day activity when I can't work on the car outside).
Recon1342
Recon1342 UltraDork
4/15/25 12:40 p.m.
I'd take the original alternator to a rebuilder. There's bound to be one nearby...
nlevine
nlevine HalfDork
4/23/25 9:14 a.m.
The work begins with dropping the exhaust so I can get to the torque tube (and it needs to come off anyway if I drop the engine). Happy that the down-pipe bolts came out without anything breaking (even though I plan to replace the bolts on assembly).
Also scored a set of 4 17x7 "twists" for a good price. I was looking for a square set-up, and the guy I bought them from said he got them from a buddy who races, which is how he ended up with 4 of the same width (certainly the rubber build-up inside the wheels supports the racing-use story). Planning ahead for more sporting uses of the car when it goes back together.
TED_fiestaHP
TED_fiestaHP HalfDork
4/23/25 12:08 p.m.
  The alternator has a small wire, that basically turn's it on.  Disconnect that wire, then with the key in the on position, does that wire get 12 volts?   If the dash warning light is burned out, that circuit won't work.  There is a light and a diode, light should come on if power goes the wrong way.  But without the light, the alternator won't get the start up power it needs.
nlevine
nlevine HalfDork
5/5/25 1:38 p.m.
Pulled the rest of the exhaust out of the car in preparation for pulling the torque tube. It could be me, but those welds do not look "factory"...
3 4 5
sqFDzRirUv26mOmWfNV3mgkgn8PF5hucpfJhY7FLVP6419DyuAMwBSeRRAsxAiIb
