5 6 7
barefootcyborg5000
barefootcyborg5000 UltimaDork
9/27/23 1:51 a.m.
More of the "do the thing" please.
gumby
gumby Dork
10/2/23 7:56 a.m.
No plan survives first contact with aftermarket parts.
Started pulling parts off the original engine to swap over. Oil pan, timing cover, valve covers. Lots of tedious cleaning and old gasket removal drug this process out. Stock valve covers didn't clear the adjustable rockers, not a surprise and I had the taller chrome ones ready. Upper intake hit the taller valve covers because of course it would. Phenolic spacer ordered.
Next I spent an hour massaging the cheap headers for tool clearance at the head flanges. They sent small diameter hardware, but that is worthless if you still can't put a wrench on them...
I eventually got them bolted up and noticed the left collector sitting really close to the block
Grabbing my y-pipe, I confirmed the angles don't match anyway. Yoinked the headers back off the engine and hung the original manifolds. Sigh.
Once the engine was complete enough to install, I popped the new frame mounts in the cradle. Ya know, the parts that started this whole mess?
The threaded inserts were coarse, unlike OEM, necessitating a hardware run. Then, on the first attempt to stab the engine, I found the engine side brackets crashing into the metal parts of the frame mounts before engaging the rubber bits! After lifting the engine back out and attacking the new frame mounts with a grinder I was able to set the engine all the way down.
One bolt is still not quite aligned, but it was getting late and I had to call it. I'll be back.
gumby
gumby Dork
10/6/23 8:11 p.m.
Engine in, trans in, everything on the bottom side buttoned up.
10/6/23 9:47 p.m.
In reply to gumby :
Dang, that's a fat front bar
Indy - Guy
Indy - Guy UltimaDork
10/7/23 8:19 p.m.
That's what she said
gumby
gumby Dork
10/14/23 8:47 p.m.
Have run into several interferences with mixing and matching parts, and one big ooops
No radiator or coolant installed yet.
The big connector on the alternator charging harness crumbled as I was repositioning it.
The sn95 oil pressure sender function is reversed from my dash light.
But, it's alive !
gumby
gumby SuperDork
5/19/24 7:11 p.m.
7mos with the motor swapped, and everything has been peachy. It still ain't fast, but the extra HP sure did wake things up.
Last month I started the car to drive home from work and it was idling low/rough and chuggin black smoke. ECT or MAP failure likely. NOPE, rodent sabotage of the MAP wiring!
Last week the clutch pedal started creaking and popping. I pulled it apart today and found the pin holding the pushrod clevis badly worn, and the clevis hole wallered out.
I came back here to remember how long it has been since the T5 swap was completed; so there's you an update.
gumby
gumby SuperDork
12/23/24 7:44 a.m.
This is such a fantastic daily that I decided to tempt ruin with another gear swap.
I have, more or less recently, acquired some parts for other projects which included extras like a set of 4.10's and another v8 T5, so
I narrowly averted the while-I'm-in-here's when a snapped exhaust manifold stud could have forced my hand into installing the headers I backed away from during the engine swap(and subsequent new y-pipe construction). Amazingly, the broken portion unthreaded from the manifold without incident
The test drive last night and drive to work this morning both revealed major improvements in seat of the pants subjective qualities. Bog after shifts is gone. Cabin noise is actually lower at 70mph cruise despite the increased rpm. Any change in mpg's will be a concern for future me, today I am a happy camper.
DON'T FEAR THE GEAR
Indy - Guy
12/23/24 9:22 a.m.
gumby said:
..... Amazingly, the broken portion unthreaded from the manifold without incident
Loweguy5
Loweguy5 Dork
12/23/24 10:01 p.m.
That wagon is...perfect...
gumby
gumby SuperDork
1/31/25 7:48 a.m.
Maybe so, but my automotive ADHD can be cruel and +4yrs with the same DD is a very long time.
A cracked wheel about a year ago allowed some bad thoughts to begin festering. I came up empty on an identical replacement and had it repaired, but repairing cast aluminum wheels is rarely a forever fix...Right about when I noticed the clear on the wheels was failing to the point of shabbiness, I got a flat on that same wheel. The repair had failed, and my head was deep into "time to make a change" territory.
I resisted the urges to start completely over on a new DD and sifted thru potential solutions to my wheel dilemma. Just the wheels. Just wheels. Wheels.
5 6 7
fvVsmNK4JOtzDEjkeiuzOdfFEo89V1DVFVjiUPODO9TKX3Z6KfauGtMXD317QCHG
