EvanB wrote:
I'm interested in how those will work. I have access to very cheap self drilling screws and some junk rally tires.
They worked excellent.
Results? they worked, AWESOME! However, they were pretty average on snow because the gravel tires are too hard for snow traction so you had to floor it to dig into the ice everywhere. With the warm weather the ice was quite grippy and the heavy melted packing snow was grippy for snow tires.
a couple of fun action shots:
Here is a better picture of the interior:
and then I got friendly with the machine shop staff at work and they milled me some new steering wheel hub spacers, 1" and .5" out of aluminum now I can toss out that heavy steel one that didn't have the correct pattern on it.
ALL THE ERGONOMICS!!!!
Next up?
I HAVE NO IDEA WHAT I AM DOING!
I can rebuild a rotary engine but I am pretty dumb when it comes to setting backlash on a differential. it is time to overhaul the differential's LSD unit. no more limited to slipping differential (is the goal).
Initial tear down was good ( on the spare LSD ) gears and bearings looked fantastic! However, all of my friction plates were about ,05mm undersized standard but still above the "limit" as mazda labels it. My thrust washers were at the limit of wear.
I'll be honest, I thought a clutch type differential used clutches and plates like some fancy flywheel clutch setup or whats in an auto trans, I was not expected a bunch of metal discs with various grooves. I did find some minor scoring on a few friction discs but overall looked like normal wear.
Then, after that - source a 15.2:1 power steering rack and then de-power it & install into the car. Current non P/S model is 20.4:1 and I find myself chasing the wheel too much, time to quicken it.
After that? May be EFI consideration time, I am at the limit of this carb and new carb is EFI money territory... (megasquirt)
Considering I already have S5 NA upper/lower fuel rails, S4 NA injectors w/ pigtails, S4 Intake manifold (w/ block off plates) and about 11 crank angle sensors (don't ask) There already is an aeromotive adjustable FPR and walbro 255lph for my fuel system so converting back would be simple.
OR toss in a stock NA harness/ecu setup on there and Rtek it?
Still much to think about but in the mean time I would rather just focus on seat time.
