rustyvw
rustyvw Dork
7/24/22 9:05 p.m.
So, this is my newest project.  It's a 1962 Jag Mk2, that currently has no brakes and doesn't run.  The last time is was on the road was 1996 according to the sticker on the windshield.  The story from the seller is that it was parked then because of a bad master cylinder.  It came from New York, and it must have been garage kept from new, because there are only a couple rust spots behind the front tires.  The paint looks way better in pictures than it does in person, but it's old lacquer so it adds to the vintage look of it.  The biggest issue at the moment is that there is no fuel tank, and the brakes are all disassembled.
I picked it up on Friday and the steering coupler broke as I was unloading it from the trailer.  I'm sure that's a sign of what I'm in for with this one.
Now I've got to hurry up and move ahead with the Sonett and Beetle projects so I can focus on this one.
7/24/22 9:50 p.m.
One of the prettiest sedans ever.
03Panther
03Panther UberDork
7/24/22 10:25 p.m.
Put a SBC in!!!angel devil
No, just kidding! I love it. Beautiful body lines, and that color looks fantastic.
1988RedT2
1988RedT2 MegaDork
7/25/22 10:21 a.m.
It is truly a thing of beauty.
One of the very first Matchbox cars I can remember from childhood was a Jaguar Mark II sedan.  It was red, and the hood opened.  I wonder if that affected my opinion of them?
wspohn
wspohn SuperDork
7/25/22 10:30 a.m.
Great cars, but if they are rusty, best to walk on by!  I really enjoyed mine!
jr02518
jr02518 HalfDork
7/25/22 11:13 a.m.
As to the brakes, the wrong brake fluid will cause no end of issues with the rubber in the system.  The rear end suspension will fall out of the car with just a few fasteners, this make rebuilding it much easier. As long as you can avoid doing any body and paint work before you get it back on the road, do it.
On the motor, getting the distributor rebuild will confirm the advance system is working and the shaft is not gimbaling in the housing. If it is the dwell on the points will float allover and the motor will never run right.  No one lubes these things and they suffer.
TurnerX19
TurnerX19 UltraDork
7/25/22 11:36 a.m.
In reply to jr02518 :
This is a Mark 2 with a live axle rear, no need to drop it to do the brakes.
frenchyd
frenchyd MegaDork
7/25/22 11:53 a.m.
Use Moss motors for parts, although Rock Auto has had some common parts in the past.  Welsh auto, Bill Terry of Terry's Jags
  But do not use the Jaguar dealerships.  Not unless you are Bill Gates  or Warren Buffet.
eastpark
eastpark HalfDork
7/25/22 4:09 p.m.
Nice! Use the retropower cars folks for inspiration:
https://youtu.be/ljWQJv1-pwY
rustyvw
rustyvw Dork
7/25/22 7:20 p.m.
In reply to wspohn :
This one is super solid.  There is a little rust in the front fenders behind the wheels.
spitfirebill
spitfirebill MegaDork
7/25/22 7:49 p.m.
This would be my ultimate fantasy car for a DD.
Noddaz
Noddaz PowerDork
7/26/22 8:24 a.m.
That is indeed a beautiful sedan!
And no, SBC or LS is NOT the answer here.
03Panther
03Panther UberDork
7/26/22 10:57 a.m.
In reply to Noddaz :
A late model; eh, put what ya want in. They ain't particularly special.
THIS is special!
my SBC comment was 100% joke. Beautiful car
Apexcarver
Apexcarver UltimaDork
7/26/22 11:18 a.m.
Congrats, I have a passing want to do one of these someday. Sweet car.
Tim Suddard
Tim Suddard Publisher
7/28/22 10:10 a.m.
Great car! Thanks for sharing it.
rustyvw
rustyvw Dork
7/28/22 7:09 p.m.
Great news!  I put a battery in it last night, and all the electrics worked.  Lights, signals, wipers, washer, most everything.  I hit the start button and it spun over, so I hit it with some starting fluid and it fired up.  It still needs a fuel pump, gas tank and a good check of the cooling system, but it's a good sign and a step in the right direction.
Apexcarver
7/29/22 8:34 a.m.
Best tip I have for battling Lucas.  As long as your wires arent crunchy, cleaning connections and applying dielectric grease gets you a LONG way.
HundredDollarCar
HundredDollarCar Reader
8/2/22 2:12 p.m.
Following with much interest.  Curious; Did you do anything to prep the cylinder bores before spinning the starter?
wspohn
wspohn SuperDork
8/3/22 3:21 p.m.
That is also my routine approach. Once you do that they old stuff seems to stand up as well as modern rubber sealed connections.  It seems a bit much to condemn 50-60 year old electrics because they didn't use what we do as  matter of routine today. Plus you are doing a future owner a favour - many Lucas looms have been damaged when people just yard on wires that have been in situ for decades and - surprise - they stick and something (often the soldered lug at the end of the wire) gives up the battle.
Note - do NOT use it for ignition modules. That calls for the white heat sink grease that is heat conductive to save the modules from burning out.
rustyvw
rustyvw Dork
8/6/22 5:11 p.m.
In reply to HundredDollarCar :
The previous owner had oiled everything up and it full of brand new oil.  I was told the previous owner had a friend bore scope it, and it's super clean inside.  From the conversations we had, I believe him.
8/18/22 9:14 a.m.
Nice score. Terrific color. Please keep us posted on the progress.
californiamilleghia
californiamilleghia UltraDork
8/18/22 2:50 p.m.
There was a low rider Jag like this at the swap meet last weekend ,
had hydraulics to lower it , nice flat paint and classic pin stripping ,
Sorry no photos ,  It went past me and my camera was in the truck.
cdowd (Forum Supporter)
cdowd (Forum Supporter) Dork
8/18/22 3:14 p.m.
The sounds from the big straight 6 are awesome!  Is this a 3.8?
rustyvw
rustyvw Dork
5/11/23 9:01 p.m.
I realized that I haven't updated in a while, I have been slowly tinkering on the Jag when I have the time.  I jacked up the front and realized the subframe mounts had come apart and the whole subframe was just hanging.  Gravity was literally holding the car together.  Out came the whole front suspension for a rebuild.
I had accumulated all the parts over the past few weeks, I just haven't found the time.  Thanks to a knee injury that has kept me home the past couple days, the front is back together.  New bushings, ball joints, shocks, and brakes.
Hopefully I can get it painted and installed by Sunday.  Then it's on to the rear.
Noddaz
Noddaz PowerDork
5/11/23 9:22 p.m.
Most excellent!
JVYSQ58lHXbU4OXQzfmOj3N38Uu8lNevr6RKcUREstrAhLy6Orc75slvekjFZqf1
