Tim Suddard
Tim Suddard Publisher Emeritus
3/28/24 10:18 a.m.
Every car needs a throttle pedal, and the Sprite’s is pretty conventional: A metal rod attaches at one end to a to a throttle pedal hinged at the floor. And at the top end, a cable is attached to run to the throttle.
We ordered a new pedal from Moss Motors, and the cable came …
JimGruber
JimGruber New Reader
4/6/24 2:33 p.m.
Tim,
Loving your finished Bugeye Sprite. Are you planning on doing a performance improvement article with the Supercharger and 5 Speed installed? Would make a good follow up article.
For my '60 BE Rebuild, I deleted the mechanical fan and installed a 10" fan as a pusher in front of the radiator. If I had not had a radiator already full of coolant I believe it would have fit behind the radiator and minus mechanical fan would fit fine. I use a Revotec fan controller in the lower radiator hose set to comr on at 190 degrees. I run a 160 degree thermostat and the engine normally runs around 175. At a stop light the Electric Fan kicks on, and when I pull into the garage the fan will run for 2-3 minutes when I shut off the engine. I also wired in a switch below the dash to switch on the fan manually. This setup works just fine for me during Tampa, FL Summer heat.
Bugeye Guy has a nice accelerator pedal that bolts to the accelerator linkage and allows you to have a smooth carpet and no need to bolt it to the floor. Also avoids another place for dirt and grit to accumulate under your right foot.
Jim Gruber
Apollo Beach, FL
QsdHCqRtSvD9ujVe2x1j9Qjhg0Gi7ffxw1EK0mhICrDKdy2pjo76Yn997KDhuUPO
