Sometimes you can’t just clean up the engine bay, and a repaint is the only answer. Although this sounds like a recipe for a long job involving an engine hoist and a couple of your best friends, if you work smartly and methodically you can do an engine bay repaint without pulling the drivetra…
Remember, aluminum foil is one of your best friends for masking off oddball shapes.
That sounds like it could be a tip I might need soon.
Good article, thank you.
Followed this procedure on a similar car, and MGC, some years ago. Pulled the engine and trans as it really needed a rear main seal replaced. Another of those little details one takes care of in such a project.
dougie
Reader
9/25/20 11:42 p.m.
I've done that exercise a few times......
That new, freshly-torqued intake manifold gasket means better, smoother performance from idle to redline too.
