OFracing
OFracing New Reader
2/25/09 11:44 a.m.
I want to get rid of some surface rust on LBC and seal the metal before I paint it. In the past I've ground / sanded as much rust as I could see, primed the metal and put on the top coats. I've heard that there are good and bad rust sealers out there to apply before I prime but I've never used of them.
Anyone have info on the Good, the Bad and the Useless?
thanks
mike
dougie
dougie New Reader
2/25/09 3:54 p.m.
Mike,
I've used Por 15 through the years with good success. They make a seam sealer also, which is just a thicker version. Great stuff just don't get it on your skin, you'll have to where it off. Eastwood also makes a good line of products to address LBC rust.
http://www.por15.com/
Doug
wlkelley3
wlkelley3 HalfDork
2/25/09 5:32 p.m.
I've used some of the cheaper, over the counter stuff like extend and neverust stuff. If sealed with a good paint job after it seems to work fine. At least so far. If it's under the car or floorboards, I have seen bedliner work will also, especially when used with rust treatment. Por15 is probably the best you can get though.
bikesnrovers
bikesnrovers Reader
2/26/09 9:09 a.m.
POR 15 get my vote.
OFracing
OFracing New Reader
2/26/09 9:50 a.m.
Looks like POR is the answer.
Thanks
mike
Sownman
Sownman New Reader
2/26/09 10:15 a.m.
You might want to read this thread from an Alpine discussion group.
http://www.sunbeamalpine.org/forum/showthread.php?t=9610&highlight=rust
Steve
MrUfTAqLidcV6x0SkLgU8caHPx8FWjXl9haY5meedgMDn2FGw6EAx8fdM8VZ9d49
