Catatafish
Catatafish Reader
11/30/14 2:44 a.m.
I'm looking for a newer nice dd, and it looks like you can get an 07 bmw 335i with around 120,000km for ~$15000. 300hp, 300tq, sounds like a lot of power for the money. Opinions?
spork
spork New Reader
11/30/14 3:59 a.m.
Common problems : drive belt tensioners fold over causing the belts to walk off. Lifespan of the electric water pump is about 50,000 miles and its expensive. Wastewater rattle, usually the rear one. It's annoying. Lots of one time use aluminubolts. That said, make mine a blue coupe. Oh, check for open recalls.
Stealthtercel
Stealthtercel Dork
11/30/14 6:40 a.m.
Sorry, you lost me: "wastewater rattle"?
Mr_Clutch42
Mr_Clutch42 Dork
11/30/14 6:51 a.m.
I would suggest a diesel. One of my autocross buddies has one and his is reliable. They are also the best looking 3-series car made. They are big and wide for autocross purposes, however. The interior felt a little cheap, which is disappointing. They are probably great for a DD.
spork
spork New Reader
11/30/14 11:13 a.m.
In reply to Stealthtercel:
Sorry, my phone keyboard is a jerk. The waste gates rattle. You can usually hear them inside and outside the car, just off idle.
Stealthtercel
Stealthtercel Dork
11/30/14 11:52 a.m.
Oh, OK, that makes sense. Thanks.
PseudoSport
PseudoSport Dork
11/30/14 5:15 p.m.
Fuel injectors are another common issue. Dealer just quoted me $1200 to replace and code 3 injectors on my 135i.
calteg
calteg HalfDork
11/30/14 5:35 p.m.
the 300hp/300tq is likely under rated
drdisque
drdisque New Reader
11/30/14 7:33 p.m.
Also, a lot of the high pressure fuel pumps on the early cars were defective, but likely most of them out there by now have either been replaced or are not defective.
mr2peak
mr2peak HalfDork
12/1/14 3:41 a.m.
My friend's 135i had an issue with a coil pack. Had to replace all of them because of software issues when replacing just the faulty unit.
Awesome car though
gmUgUFC9zZX9mQxTxHcKKgPj6oc1nCADpzoU075fXYKXoGV9aqdpJNlFrJE5t1cS
