DeadSkunk
DeadSkunk UltraDork
6/13/16 7:21 a.m.
I've got an old TE27 Corolla ITC race car. It came with 6x13 Diamond racing wheels and 205/60/13 Toyo RA1 tires. The tire/wheel combo weighs 26 lb. The car also has a caster rod, similar to later Corollas, but the sway bar is located at the fire wall and passes through a tube right above the transmission bell housing. I had never seen it done that way before.
6/13/16 8:10 a.m.
Woody wrote: Are you going to race it? Anywhere? Yes? Then join NASA for $45 and then buy a set of Konig wheels with you nifty NASA discount.
Also look at Konig Dial-ins, 12lbs each and well under $600 per set. That's what I'm saving up to put on the Corolla.
m154cSRqDecAhleFo3CKQnetAtUUc6F65uASnZjCpi0hVWsCkmPrhVWullSsDMQe
