Brokeback
Brokeback New Reader
4/28/13 5:23 p.m.
So I went to set the timing on my miata for the first time, and got the timing light hooked up and such. I noticed that the coils are sparking normally on cyl 3 and 4, but 1 and 2 are doing a weird little rythmn. ie 3 and 4 fire twice every .5 seconds ( as an example, its actually faster lol) but 1 and 2 fires 3 times in those .5 seconds.
Things I've done:
swapped wires on each coil, it followed the coil and not the wire. the passenger side of each coil seems to be doing the triple firing thing.
new plugs/wires - no change
tested ignitor (igniter?) - seems to be fine compared to measurements on miata.net for resistances
cleaned and checked grounds - no improvement
At this point do I replace the coils, ignitor, or both? Appreciate any help!
PseudoSport
PseudoSport HalfDork
4/29/13 1:03 p.m.
All the weird ignition and misfire issues on my 1991 Miata were due to a bad Crank Angle Sensor.
Brokeback
4/29/13 1:22 p.m.
In reply to PseudoSport:
What sort of symptoms did you have? Just wondering if they're similar. AFAIK, the ignition system goes like this (well, the part I'm interested in):
signal from ignitor goes to coil #1 (2 and 3 cylinders), second signal from ignitor to coil #2 (1 and 4 cylinders).
On each coil, one of the plugs fires different than the other plug on that same coil.
Could be wrong, but if I understand correctly seems like the ECU and thus the CAS don't have anything to do with the different results from the two plugs on each coil.
MmLzn76rS0hmpqxp0ahbWNLsEt2kfMH4eJTtFOJjZFSWGSDgkg20QGVdTdXXfXxK
