Tk8398
HalfDork
7/7/22 1:38 a.m.
That oil separator plate ddavidv mentioned was plastic for some years and warps. Subaru had a kit with a metal plate and some new mounting screws as an upgrade. It works well.
MegaDork
7/7/22 9:23 a.m.
It's a Subaru, I'd be more concerned if it wasn't leaking oil
-A former Subaru owner.
How many quarts per 1000 miles? All old engines leak oil. The decision to fix is based upon the quantity.
Tk8398
HalfDork
7/7/22 10:50 a.m.
I don't really have to add more than a quart of oil between changes. It's difficult to tell once it's cooked on the exhaust but I honestly think it's gear oil. I can't tell for sure though.
That engine had ~98k miles when I put it in, and I changed the oil separator plate (replaced with the metal one), the o ring on the smaller plate also visible in that picture, the cam seals and o rings except for the one seal that requires removing the cam, a new oil pan, removed and resealed the oil pump and replaced the front seal, new valve cover gaskets, and I believe that's it. The only potential places to leak oil that I didn't change were the rear main seal and one cam seal. That was enough to make it go from billowing clouds of oil smoke to actually stop leaking for a while.
When I pulled the old engine out it still had the original transmission with like 400k on it that was totally worn out, so I replaced it with a used one with 180k which didn't leak, but the second gear was so bad that it shifted about the same whether or not you used the clutch and had chunks of metal in the oil when I finally took it out. When I took it apart again to change the transmission the engine still showed no signs of leaks, and I put another transmission in that had about 260k that shifted fine, but it leaked in the same place this one appears to (from the seam next to the drain plug).
Once the amount of smoke blowing in the dash vents got to the point I couldn't stand it, I swapped this current transmission in (from a car with 180k miles) and again checked the engine for leaks while it was out and didn't see any, but now it's back to leaking as bad or worse than it was before I took it apart the last time.
I don't really have to add oil or gear oil regularly, but it just smells too bad to keep using like this. If it is in fact the transmission, it appears to be that good transmissions will be the limiting factor in keeping this car on the road and I need a different car. I have another engine with under 90k miles and lots of other parts and there isn't anything else really wrong with the car, but finding a 25 year old transmission with under 180k miles probably isn't going to happen. I know I will need to get a newer car at some point soon anyway because used parts are getting harder to find and Subaru has discontinued a lot of the parts for these in the last few years, but I can't really work on a car much newer than this one myself and cars that are new enough to not need work are $$$$$ right now if you can even find what you are looking for at all.
In reply to Tk8398 :
I do apologize. I really didn't do a very good job of reading your original post. I do hope you find a solution. Good luck!
Aspen
HalfDork
7/7/22 1:53 p.m.
Build a little tray that diverts oil from dripping onto the exhaust pipe.
The downside of clamshell style transmissions is that they flex and warp and eventually will leak, assuming that said flexing and warping does not lead to trans death first, because clamshell designs are the weakest setup.
Tk8398
HalfDork
7/8/22 10:52 a.m.
The best I can tell is that it leaks from the seam next to the trans drain plug in the middle of this picture. I mainly posted this because I was hoping I was missing something that would be easier to fix. If that's in fact what it is, there is no real way to fix it permanently. There's no particular issue with space or money to keep this car around until I'm 100% sure I am done working on it, but finding a replacement right now is far from ideal.
