markwemple
markwemple UberDork
3/23/18 5:32 p.m.
Replaced all the brake lines, hard and soft on my 03 7.3 F-250, and bled the brakes. The brakes still feel a bit soft and the abs light never goes off. FWIW, this wasn't a problem before the line change. Ideas??
enginenerd
enginenerd Reader
3/23/18 5:38 p.m.
Probably stating the obvious here but I'd probably start by double checking none of the wheel speed sensors got damaged accidently. Then I'd look and see if the factory service manual requires any kind of cycling of the ABS pump when bleeding the brakes or replacing lines. I've struggled with a few early 2000's Ford ABS systems.
APEowner
APEowner HalfDork
3/23/18 5:42 p.m.
It sounds like you've still got some air in the system but I don't recall ever having an ABS light from that.  If the ABS light is on there should be a code stored which might give you a clue.
93gsxturbo
93gsxturbo Dork
3/24/18 9:45 a.m.
Did you unplug any of the wheel sensors during the process and/or forget to plug them back in and/or turn the key on with them disconnected, even if you didnt start the engine?  If so, you will need to clear out the codes.
That being said you are gonna need a code reader anyway to reset the light so I would find one and see what the problem is vs guessing over the internet.
markwemple
markwemple UberDork
3/24/18 12:54 p.m.
The joy of being in the middle of a move. I'll be reading codes today.
Streetwiseguy
Streetwiseguy UltimaDork
3/24/18 1:18 p.m.
Just orange abs light, or red brake failure light as well?  Red implies a hydraulic I'm balance and that will trigger the abs light.
4wal or Rwal? If rwal Ford might still have a combination valve with a switch in it, and Ford never made it self center very well after a brake line failure.
dean1484
dean1484 MegaDork
3/24/18 4:17 p.m.
Does that have the sensor on the dif in the rear or is it individual wheels.  The one on the dif is a known problem. Also the abs motor could be going south. If you were working around it the plug that powers it corrodes and a small bump will make it fault.
Donebrokeit
Donebrokeit SuperDork
3/24/18 5:14 p.m.
Mark, check the wire running to the rear sensor as I have seen a few sensors replace due to the wire chafing on the hose and frame.
Paul
markwemple
markwemple UberDork
3/24/18 5:37 p.m.
Scanned it. My reader found no codes. Light went off after reading it. Isn't acting like air in the lines. Can't pump them up. Also, there is a hum that becomes louder when the brakes are applied. It also becomes louder when you steer it. THe pedal will go almost to the floor, but it will stop my loaded 12,000 pound trailer (yes, I'm using it to move) with brake balance set to minimum. (I'm using it on max to not stress out the brakes). So it must be in the pump or a relationship between the pump and the steering pump?? Does the steering pum provide power to the brakes, or is there a shared circuit somehow??
markwemple
markwemple UberDork
3/24/18 5:38 p.m.
Oh, 4wd. Off road package, FWIW.
93gsxturbo
93gsxturbo Dork
3/24/18 6:37 p.m.
The hum is your power steering pump and normal...may be old or low fluid though
markwemple
markwemple UberDork
3/24/18 7:18 p.m.
Doesn't sound like the normal Ford power steering pump noise. And, it gets louder when I'm applying the brakes.
93gsxturbo
93gsxturbo Dork
3/25/18 8:37 a.m.
As a man who has owned two 02 Powerstrokes, yes the hum is power steering pump and its probably low on fluid or old fluid.  Its a hydroboost system so pressing on the brake pedal loads up the system.  I daily drove an 02 for 5 years with a leaky return hose, it would leak down about every 3 months and I would have to add more fluid.  Could always tell when it needed more because it would get really loud sitting at intersections with your foot on the brake.  Pull into the gas station, add half a quart, and pull out quiet as a church.
markwemple
markwemple UberDork
3/25/18 11:58 a.m.
Cool. I'll double  check the power steering. Weird, though, as doesn't have that normal Ford PS sound. LOL, Ford's almost always seem to have a little PS noise, even when almost new.
iceracer
iceracer UltimaDork
3/25/18 12:36 p.m.
ABS pump/motor could be the source of the hum.
Donebrokeit
4/1/18 10:09 a.m.
Mark, might want to check the steel brake line behind the fuel tank as I just blew mine out yesterday. The truck stops much better now than it has since last fall after replacing the right rear brake hose.
Paul
k1jhiWuB9OnfGX7Zg2OJmktW9JwbsKHDPtJR4inP6rldUfu8MtGqObihkQ1LJlbl
