kevlarcorolla
kevlarcorolla New Reader
9/21/10 3:26 p.m.
Thanks for the info Keith,car felt very skatey at both ends of the pressures used-too be honest with all that was going I didn't notice a difference between them.I simply left it at the 25lbs after bumping it up and focused on driving the car.The lack of heat was so obvious I didn't even pull the pyrometer out its case. Thanks jstein,I picked up a set of used keizers on the weekend for next years tires-just need to settle on the brand.I only run on asphalt so I need a very soft compound to work I think,not sure which of the R25b hoosiers,the R160 goodyear or one of the soft hill climb compounds from Avon are the way to go.
Jensenman
Jensenman SuperDork
9/21/10 6:57 p.m.
kevlarcorolla wrote: 1st autox yesterday,very little grip from the 710's with a pressure range from 15 to 25psi.Tires barely warm to the touch after a run and no stone/grit retention. http://www.youtube.com/watch?v=v00QPY2exHo
Per, I think this thing accelerates harder than the LeGrand. Very nice work, kevlarcorolla!
kevlarcorolla
9/22/10 5:25 p.m.
In reply to Jensenman: Thanks,not sure how Per has his geared but I'm down at least 25hp to him and I think I'm heavier to boot.Those poor 710's spun all the way thru 1st even though I was actually trying to peddle it somewhat,with the tires on it its geared for a right around 120mph and with the 20" slicks for next year it should be 115mph.
kevlarcorolla
10/20/10 7:42 p.m.
A fellow competitor snapped this at the last event,even colder than the 1st event.Car was ok and set ftd by about 3 seconds on the hockey pucks.
0B8IHnDqzZgN9kG2shRET5IDixLeA7QKnuvpCFvlvl5nrU8D9o8GFWB3cA5yQMtU
