BTerj
BTerj New Reader
10/5/15 9:53 p.m.
Just bought a 95 miata on Saturday, commuting to and from work today the stick shift and the plastic transmission tunnel top got abnormally hot. My daughters 92 doesn't get hot at all. Is the trans low on fluid or is it something else?
Thanks Brian
LuxInterior
LuxInterior Reader
10/5/15 10:03 p.m.
I'm guessing that both the upper and lower rubber shift boots are shot and they're letting post-radiator hot air up into the console. If you remove the console and look down near the shifter, I'm pretty sure you'll see pavement. The rubber boots don't last very long on these cars.
outasite
outasite Reader
10/5/15 10:11 p.m.
Shift boots need to be replaced. I experience same symptom w/92 Miata
BTerj
BTerj New Reader
10/5/15 10:28 p.m.
Thanks, I was worried the tranny was going to crap the bed. I can fix it latter.
Brian
Apexcarver
Apexcarver PowerDork
10/6/15 8:35 a.m.
Thats also directly above the cat, so you have exhaust heat coming up through the boot
KyAllroad
KyAllroad SuperDork
10/6/15 8:54 a.m.
It's a good time to pull the shifter, check it for grooves and wear and change the turret oil. Your shift feel will improve greatly.
LuxInterior
LuxInterior Reader
10/6/15 9:06 a.m.
And, replace the worn shifter bushings while you're in there
T6CulNPVWpauQajeSkphdrfvM4BmCjBXzzokqHp0iSF6DgFWv7ECzW271fUZvoF6
