Carl Heideman
Carl Heideman
10/2/20 8:43 a.m.
It’s going to happen sooner or later.
Something in your engine will break, wear out or require an upgrade, forcing you to—gulp—pull a cylinder head. This job can be quite overwhelming and complex, especially if you’re working with an overhead-cam engine, but it&r…
Jerry From LA
Jerry From LA SuperDork
10/24/20 12:21 a.m.
My first engine rebuild was a FIAT 1600 twincam.  My V-8 buddies were giving me props since the head was in three pieces (the cam stands were separate) and the at-that-time exotic cambelt.  However, I found it a lot less intimidating than figuring optimum pushrod length for  proper rocker tip wear patterns on the valve stem.  All I had to deal with were bucket tappets which were relatively foolproof.
Jerry From LA
10/24/20 12:34 a.m.
Also, I think it would be a great help to people if you showed them your method for tying up the timing chain and how you maintained and checked the cam timing afterwards.
frenchyd
frenchyd PowerDork
10/24/20 9:42 a.m.
In reply to Jerry From LA :
Jaguar V12's are terrifying because there are two heads and this whole mess of tubes and wires.  ( the fuel line is even air conditioned to prevent vapor lock)
   But once you get into it it's simple and straight forward.  With a bonus.  Jaguar builds a simple stand that holds the timing chain clear so you don't  have to replace the timing chain.
Jaguar has used the same cam guage since 1948. It's right in the tool kit. Put the engine on TDC #1 slide the cam guage over to confirm timing and you are done. If you want they have notches in the timing gear that gives you a 2&1/2 degree change every notch and if you want less than that reverse the timing gear and you have 1&1/4 degree change.
Vajingo
Vajingo Reader
10/26/20 12:00 a.m.
Half the engines I've met, it's been easier to just pull the engine and replace it with a junkyard engine.
call junkyard>find engine> it's already pulled on arrival>truck home>pull old engine (which involved nearly everything the head removal almost had)>install new engine. Drink beer.
or...
Spend hours cross shopping parts, prices, availability, and finally order parts>parts arrive (hopefully) weeks later>Oh look, the wrong parts were sent>back to the beginning> pull nearly everything required to pull the whole engine>Take head to machine shop>cross fingers it doesnt get screwed up>weeks later, go to install parts>Oh, look, some of the parts got destroyed/missing/incorrect. Drink beer, but NOW complain.
Vigo (Forum Supporter)
Vigo (Forum Supporter) MegaDork
10/26/20 10:45 a.m.
I cant remember if this was the first head i pulled but the first engine i rebuilt was at 16y/o, and I couldn't find a single thing wrong with it to explain the knocking noise it made until... i got to bolting on the CRACKED FLEXPLATE!! angry I had pulled it without noticing the cracks because there was a shim plate over it that covered the crack. Upon reassembly, i realized how much big of a rabbit hole i'd gone down over a misdiagnosis.
So that was a good learning experience. If i could go back, i probably wouldn't change a thing. I still get to say i rebuilt my first engine when i was 16. I spent a total of ~$120, not counting the $16 flexplate.. blush
jimgood
jimgood Reader
5/30/22 2:07 p.m.
Do you disconnect fuel lines when priming the oil system for the first start up? I have no experience with engine rebuilding but I had an interesting issue with my mower when I went to start it for the first time this season.
Because I've had bad luck with starter switches, I replaced the start position in my mower with a separate start button. And it will kick the starter over without the key on (that was the simplest way to wire it).
My luck trajectory continued with that button. I decided to "prime the oil system" for the first start of the season. But the button got stuck in the depressed position and I ran around like an idiot trying to get it unstuck. So the starter ran for possibly 2 full minutes while I fumbled around.
But that's really just the back story. Once I got that resolved, I got the mower started and it immediately started blowing huge amounts of smoke and would not run right. I did some research and found that the long cranking period with no spark might have caused wet fuel to gather in the cylinders and seep past the rings and into the crankcase. This was easily confirmed by pulling the dipstick and taking a whiff. So the oil became seriously diluted with fuel. When it finally started up, that caused the smoking. I changed the oil and it cleared up.
So, do you disconnect the fuel lines or otherwise disable the fuel system while cranking then engine to prime the oil system?
BimmerMaven
BimmerMaven New Reader
5/30/22 4:02 p.m.
In reply to Vajingo :
I agree.
This dirty engine with crumbly rubber hoses is obviously not a beloved car for this owner...so, the cost effective plan is a used swap.  Some engines are cheaper than gaskets and sundries.
For your special car, start with a used engine and take your time,..
BimmerMaven
5/30/22 4:02 p.m.
I agree.
frenchyd
frenchyd MegaDork
5/30/22 10:42 p.m.
or...
I don't know which engines you work on. However the cracked hose on the intake would be something easily missed and doesn't indicated serious neglect.  Not worth risking a used engine of unknown maintenance or usage.
  Replacing a valve isn't very complicated and it's straight forward to re-shim the clearance.   Head off it's less than 1/2 hour to do the whole exhaust side and probably worth doing the intake  side which should only take 15-20 min.
     As far as Jaguars go which I'm most familiar with.  The bottom end of a V12 is so robust it rarely ever would need refreshing.  The top end is extremely durable too except more vulnerable to mistakes. Easy to improperly fill the radiator and be short coolant. You actually have to read the owners manual to do it properly.
  Or leaves and trash between the radiator and A/C  blocks most air from going through.
    Vacuum hoses split with age and heat.   Or timing off.  Again the owners manual tells you the distributor needs oil periodically and if it doesn't get it the advance freezes resulting in timing off causing overheating.
     Ferrari, Aston Martin, Jaguar, and other high end cars need more than a typical DIY guy does. But when they depreciate so quickly that's the service level they typically get.
  On the other hand plenty of guys read the manuals and find out ownership can be a very inexpensive thing if they do the work properly and themselves.
wspohn
wspohn SuperDork
5/31/22 12:25 p.m.
I LIKE OHC engines!
I have played around with old (Jaguar, Lamborghini, MG) with no issues as well as new (Ecotec etc.)
One thing I have trouble getting over - the look of a vintage DOHC engine with the angled cam covers just looks ..right to me. The flat top style (which I understand reduces casting and machining costs) just doesn't look as nice.  Who was the first to do that?  First one I recall was the Lotus twin cam from the early 60s.
fearlesfil
fearlesfil New Reader
5/31/22 3:29 p.m.
Per ARP, head studs should be removed, and reinstalled after the head is resting on the gasket/block. This prevents head studs from picking up aluminum in their threads as the head is installed, which can throw off torque settings.
BDzJJ9KibUtp20pnsx7lBG1vu1JCeSrmo8M4UflhlLPuyrnFvRHW6TXDpt43ADUB
