glueguy (Forum Supporter)
glueguy (Forum Supporter) Dork
3/30/24 2:05 a.m.
2002 GTI with Audi TT control arms.  The sway bar links 'almost' line up.  In normal life I would use rod ends and make the end links.  Trying to minimize the budget hit, what are the cheap ways to make an adjustable end link?
3/30/24 2:11 a.m.
Modify standard links into adjustable?
Edit: I wouldn't worry about the strength of these at all either. A lot of modern cars come with very flimsy-looking plastic sway bar links.
APEowner
APEowner UltraDork
3/30/24 3:24 a.m.
They don't need to be adjustable, they just need to be adjusted.  You could do something like cut the long one and weld it or use a larger fastener in an offset hole, or possible move the mount on the control arms.
Apexcarver
Apexcarver MegaDork
3/30/24 9:46 a.m.
I don't have a challenge car, so this is just curiosity...
I have a big coffee can full of used rod ends from my f500. They aren't broken or seized, just too worn for use on mission critical suspension links on a roadrace formula car. What would fmv look like on that?
Olemiss540
Olemiss540 Dork
3/30/24 12:34 p.m.
Just cut it in half, thread it and put a turn buckle in the middle?
Dusterbd13-michael
Dusterbd13-michael MegaDork
3/30/24 12:51 p.m.
https://www.kartek.com/parts/fk-rod-ends-38-right-hand-thread-38-hole-cm6-economy-male-heim-joints.html
Male and female. 10 bucks a side. Done.
D4Xim9PFnDL9USbrxP6PRsPRZsSeBg1hRHF78Nir6G8YHVIFhQOG9yjyMNFIwZFn
