stan_d
stan_d Dork
9/7/14 12:07 p.m.
I am using these on my challenge car. How bad would it be to drive them down? Not a lot of space in the car to haul extra tires. Or would it be better on non driven axel for trip that way I only haul 2.
Gearheadotaku
Gearheadotaku PowerDork
9/7/14 2:06 p.m.
how far are you going? How old are the tires?
stan_d
stan_d Dork
9/7/14 3:55 p.m.
Looks like from 03 have been in storage no direct sunlight.
stan_d
stan_d Dork
9/7/14 3:58 p.m.
Looks like 1000 mi down and 1000 mi back
Opti
Opti Reader
9/7/14 5:19 p.m.
Most tire manufacturers say do not use a 10 year old tire, yokohama included.
stan_d
stan_d Dork
9/8/14 10:00 a.m.
These tire look perfect zero dry rot. I have some tires that are less than 3yrs old and have dry rot now. The advans are not as soft as they were though. I need to use them up.
Streetwiseguy
Streetwiseguy UberDork
9/8/14 1:46 p.m.
I ran a set from 01 a couple of weeks ago. They were still unused in 2011, and I've run them a couple times since then...They were great.
Giant Purple Snorklewacker
9/8/14 2:01 p.m.
I used to use those as track tires back around the time those were made. They were loud, darty and would make you think you had 4 bad wheel bearings when they were new if you couldn't get them hot.
I imagine the street manners are not significantly improved with time.
Vigo PowerDork
9/8/14 2:03 p.m.
If they were stored indoors they are probably fine to use as far as safety. I doubt they will perform as-new but I would definitely try them if I already had them sitting around.
stan_d
stan_d Dork
9/9/14 8:35 a.m.
Took the tires for a test drive. I think they are too hard to be of any advantage. the car breaks traction from first to second gear change in a auto.
FCSW9cfClIIYlgmAOC2977IMboVob1Ab8IJsc2cVX1nBTdRJ6LFb0ikvdyXBe62f
