PMRacing
PMRacing SuperDork
8/30/17 10:07 a.m.
Can I use motor oil for an air compressor? It has a 2 piston Montgomary Ward pump on a Speedaire tank. When I moved my compressor to the loft it leaked a bit and i need to change the oil anyway. I have a ton of motor oil around and don't want to buy anything if I dont have to. Thanks!
rob_lewis
rob_lewis UltraDork
8/30/17 10:16 a.m.
From what I've been told you need to use compressor oil. The detergents in motor oil will cause it to foam up and leak out.
-Rob
Pushrod
Pushrod New Reader
8/30/17 10:21 a.m.
What he said.
PMRacing
PMRacing SuperDork
8/30/17 10:26 a.m.
Damn. I can't be a cheap E36 M3. Thank you!
iceracer
iceracer UltimaDork
8/30/17 11:13 a.m.
Engine oils have anti-foaming addatives. Compressor oils don't get as hot as ICE oil.
Ranger50
Ranger50 UltimaDork
8/30/17 11:17 a.m.
Anywhere that sells compressors should have oil. It's less than $10/qt and you probably won't use the whole qt.
spitfirebill
spitfirebill UltimaDork
8/30/17 11:33 a.m.
I buy Campbell Hausfeld oil at HD. I don't recall it being very expensive.
dculberson
dculberson PowerDork
8/30/17 1:52 p.m.
It's labeled SAE 30ND for non detergent. They have it at napa and other decent parts houses.
Zomby Woof
Zomby Woof PowerDork
8/30/17 2:04 p.m.
Equivalent viscosity hydraulic oil will do the job as well.
Dr. Hess
Dr. Hess MegaDork
8/30/17 2:27 p.m.
Don't buy the synthetic kind. I tried it and my compressor made all kind of funny noises on it.
BrokenYugo
BrokenYugo MegaDork
8/30/17 3:30 p.m.
This is a case where non detergent oil is actually applicable, I think it has something to do with engine oil additives gunking up the valves.
SaltyDog
SaltyDog New Reader
8/30/17 3:35 p.m.
+1 for SAE30 ND Been running it in my IR compressor for close to 30 years with no issues.
maschinenbau
maschinenbau HalfDork
8/30/17 3:45 p.m.
My brand new Kobalt 6hp 2 piston compressor lists "Mobil 1 synthetic 10W-30" right in the owner's manual. It says don't use regular (conventional?) because it can cause valve deposits.
plain92
plain92 New Reader
8/30/17 4:23 p.m.
When you think about how many cars are on the road, and what an engine oil has to be able to do, chances are most any car engine oil is going to be adequate for your compressor. Straight 30 weight non-detergent is also known as 'regular cheap oil' more or less IMHO. Not exactly expensive to buy the correctly labeled quart of compressor oil, and there's a nice rabbit hole you can go down with oil discussion, but you're probably doing more than a lot of people just by changing the oil.
vVeyRJ9QHZZcA1Ne6MAZaSse73bWa1jBmk4zUcrXEcepi05byZRqfhEIHVynNTX0
