Curmudgeon
Curmudgeon SuperDork
1/27/11 8:28 p.m.
I have been racking my (admittedly miniscule) brain trying to think of something RWD which used an aluminum differential housing. Or even a 4WD front housing. Anybody know of anything? It would of course help if it were reasonably readily available.
Rob_Mopar
Rob_Mopar HalfDork
1/27/11 8:50 p.m.
Didn't some Jeeps use a Dana 35 with a cast aluminum center on the front? I could be wrong.
Schmidlap
Schmidlap HalfDork
1/27/11 8:53 p.m.
Google says Explorers, Rangers, Pontiac Montanas (and assumably it's corporate twins), and the Jeep ZJ (93-98 Grand Cherokee with a Dana 44) had aluminum differential housings. I don't know if I trust random internet postings but you might want to look at those vehicles.
Bob
P.S.
Is assumably a word?
motomoron
motomoron HalfDork
1/27/11 8:53 p.m.
Differential housing, or 3rd member?
Sprites/Midgets for example have a cute little aluminum diff housing w/ a wee scale model of a proper ring n' pinion. 3.7, 3.9, 4.1, 4.55 at least.
I've got the 3.9 in the car now and have a 4.55 w/ a De-troit locker. Breaks axles like bread sticks.
mr2peak
mr2peak Reader
1/27/11 8:56 p.m.
I believe the word you're looking for is "presumably"
Or alternatively:
"I assume"
WilberM3
WilberM3 HalfDork
1/27/11 8:57 p.m.
v8 grand cherokees had a rear dana 44 with an aluminum center section.
dont know if all vipers have it, but it sounds like there are aluminum housed diffs here: http://www.mopartsracing.com/parts/viper.html
ST_ZX2
ST_ZX2 Reader
1/27/11 9:02 p.m.
Alfa Romeo
AquaHusky
AquaHusky Reader
1/27/11 9:17 p.m.
Aren't the front diff housings aluminium on the AWD/4WD GM offerings? Those weird looking cases that split down the center....
bluesideup
bluesideup Reader
1/27/11 9:21 p.m.
Just the third member is aluminum on the 96-98 ZJs with the D44a. They also have rear disc brakes. The 93-95 V8 ZJs have a steel D35 and some of those also have rear discs (Limited models).
oldtin
oldtin Dork
1/27/11 9:45 p.m.
lincoln mk viii - irs aluminum housing ford 8.8
patgizz
patgizz SuperDork
1/27/11 9:49 p.m.
thought the housing on the lincoln was iron, the one from my thunderbird was.
the front axles of the s10 and derivatives are aluminum housings.
DavidinDurango
DavidinDurango New Reader
1/27/11 10:12 p.m.
Believe my LSC Lincoln has alum 8.8 IRS.
oldtin
oldtin Dork
1/27/11 10:18 p.m.
93-1998 lincoln marks have alum 8.8 housings. Internals aren't compatible with non irs stuff.
thatsnowinnebago
thatsnowinnebago Dork
1/27/11 11:24 p.m.
I think the rear axle on the newest Troopers was some kind of Al centered D44 hybrid thingy but I'm not positive.
Strizzo
Strizzo SuperDork
1/28/11 12:10 a.m.
housing on the r180 front diff in xterra/frontier/v6 pathfinders is cast aluminum, and it sucks. ARB quit developing the locker for it because the case couldn't hold up to the stress.
doc_speeder
doc_speeder Reader
1/28/11 12:19 a.m.
Cadillac CTS, CTS-V, Pontiac Solstice, Saturn Sky
mr2peak
mr2peak Reader
1/28/11 3:28 a.m.
Could really be noticeable on a 7 build...
44Dwarf
44Dwarf Dork
1/28/11 5:05 a.m.
Subaru
Will
Will HalfDork
1/28/11 6:02 a.m.
99-04 Cobra, Gen 2 Explorer, 93-98 Mark 8.
bravenrace
bravenrace SuperDork
1/28/11 6:17 a.m.
Pontiac Solstice.
Blitzed306
Blitzed306 Reader
1/28/11 2:16 p.m.
IRS T birds had iron center sections, the Marks had aluminum
Bobzilla
Bobzilla Dork
1/28/11 3:18 p.m.
C4 vettes had either D36 or D44 Aluminum rear diff's.
erohslc
erohslc Reader
1/28/11 6:54 p.m.
Aren't the big Nissan housings aluminum? (R200, etc.) What about BMW? Merkur (Sierra). You can buy aftermarket Ford 9" aluminum housings.
Curmudgeon
1/28/11 8:25 p.m.
mr2peak wrote: Could really be noticeable on a 7 build...
That's sorta what I was thinkin'....
Thanks for all the answers! Lots to chew on here.
Curmudgeon
1/28/11 8:28 p.m.
Strizzo wrote: housing on the r180 front diff in xterra/frontier/v6 pathfinders is cast aluminum, and it sucks. ARB quit developing the locker for it because the case couldn't hold up to the stress.
For what I'm thinking of, this might be the best bet; it won't be under anywhere near the stresses of a 4x4. Anyone have an idea if the guts are interchangeable with other R180's?
C6youBi9CszzNWrlAktBTBfpDWb914hBHDqJmvvVqM5tqrce6jPJN8SdCCX5Zu6k
